Quick Aux Trans cooler question - JeepForum.com
post #1 of 9 Old 08-16-2014, 04:39 PM Thread Starter
HighandLow
HighandLow's Avatar
2010 JK Wrangler
Just installed my trans cooler Hayden 404
I downloaded the b&m instructions just to use as a go by. B&M suggests flow from bottom to top when mounting on its side. Does it matter either way? Is top to bottom better?
2010 Rubicon, Auto, Stone White, 3.5"Synergy Coils, DL and TR, MetalCloak TB's and CA's Fr/Rr, 37"Coopers 18" Ions , Adams 1310's, G2 5.13 gears, Synergy Sleeves and Gussets, ORF, PSC, JCR, PIAA,Rancho equipped...
HighandLow is offline
post #2 of 9 Old 08-16-2014, 04:50 PM
JIMBOX
NOPE-bottom to top allows the tranny fluid pressure to force the fluid thru the cooler--
If you go top to bottom, airpockets form and cause tranny TRAUMA !
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #3 of 9 Old 08-16-2014, 04:54 PM Thread Starter
HighandLow
HighandLow's Avatar
2010 JK Wrangler
Nice, thanks Jimbo you da man!
post #4 of 9 Old 08-16-2014, 05:04 PM
JohnRodriguez
the reason you do bottom to top is to push the air out of the cooler on start up. if you went from top to bottom, it will make a air pocket in the cooler.
89 Wrangler, 2.5L TBI, D30 Truetrac 4.56 gear front, Super 35 4.56 gears rear, 31" BFG Mud's, 15x9" weld racing pro-stars XP's, 2.5" rancho and 1.25" shackels, superior axles. rear wilwood disc brakes
2008 wrangler x unlimited. Stone white. Motech 5.3L LS Chevy
JohnRodriguez is offline
post #5 of 9 Old 08-16-2014, 05:15 PM
JIMBOX
Thanx my friend-I readit in the Grapevine !
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #6 of 9 Old 08-16-2014, 05:19 PM Thread Starter
HighandLow
HighandLow's Avatar
2010 JK Wrangler
Thanks again to both of you. I did it as per B&M instructions. I'm just glad to be on the winning side of a 50/50 chance for once! I'm no mechanic and it took me less than two hours including a trip to oriely for better hose clamps than Hayden supplied. Easy and inexpensive upgrade.
post #7 of 9 Old 08-16-2014, 05:53 PM
JIMBOX
Sounds good-
Mine is a little more involved, I have a frame mounted (racing) finned aluminum cooler that feeds in the B&M type in front of the radiator-
My tranny has never got over 200 F, even on slow hill climbs/w trailer
Chryslers auto tranny cooling system is actually a tranny warmer
So anything you can do to help the cooling is great-
Good luck
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #8 of 9 Old 08-16-2014, 06:04 PM Thread Starter
HighandLow
HighandLow's Avatar
2010 JK Wrangler
I'd like to put a tranny oil temp gauge in like yours. Was that difficult DIY?
post #9 of 9 Old 08-16-2014, 06:32 PM
JIMBOX
If you've never wired temp transmitters and low voltage receivers before--it's difficult-
SunPro makes the tranny temp gauges 0 to 250 Degree 12VDC and also includes thermal/temp senders that you've gotta insert into either the tranny pan, or one of the coolant hoses-
It's not easy-
most guys nowadays use the superchip/phoneapp--whatever-
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
