Questions about Tuffy Security Deck Enclosure - Page 2 - JeepForum.com
post #16 of 16 Old 04-03-2013, 11:45 AM
Matt The Hammer
I just installed one of these. Picked it up used off C-list. It seals tight. I installed mine on top of the OEM carpet in the back. The only bolted in parts are the side brackets to the body tub. The top lifts out easily with the rear door open and the vertical panel behind the seats simply screws to the brackets using thumb screws. So you can mostly take this out - less the side brackets - in 5 minutes.
2013 JKU
1995 YJ
Matt The Hammer is offline
Anyone with the Tuffy Security Deck Enclosure? ag8080 JK Wrangler Technical Forum 32 06-06-2016 10:06 AM
TUFFY TJ LJ & YJ SECURITY DECK ENCLOSURE - Anyone have this? VanBCguy TJ Wrangler Technical Forum 115 04-13-2016 08:23 PM
Tuffy security deck enclosure & speaker relocation DBA2GO JK Wrangler Technical Forum 0 08-03-2011 03:39 PM
Initial Thoughts on Tuffy Cargo Security Deck Enclosure Ajaxxx JK Wrangler Technical Forum 14 07-21-2010 12:11 PM
