Question and opinion on lift options. - JeepForum.com
post #1 of 15 Old 10-28-2011, 06:20 PM Thread Starter
neverhide34
2011 JK Wrangler
I have a 2011 Rubi and I just bought a house so my spending capabilities have been stunned for a good while. I've had it since April and want to keep it stock no longer. Since I need to keep spending to a minimum I have made a partial decision on a lift and want someones opinion.
I have narrowed it down to 2 lifts. AEV 2.0 spacer lift. Or Teraflex 2.5 Performance budget boost.
And if I choose Teraflex, it gives me the option of buying the kit that includes the Teraflex 9550 shocks. Is it worth replacing the shocks? Or will the stock red rubi shocks still offer the same performance/flex I can expect when I disconnect the sway bar.
Tires will stay stock until tread indicates otherwise. Then I will invest in 33's. I wheel frequently in WV. Nothing crazy yet. I am aware that irresponsible wheeling with a short lift will equate to damages. I will get a more superior lift, 35's, and gears when funds become available. For now this will have to do.
Any info will be appreciated. Thanks in advance.
Keep Calm, Chive On
neverhide34 is offline
post #2 of 15 Old 10-28-2011, 07:06 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Anytime you lift, you need to match shocks to the lift, either with new, longer shocks, or brackets that lower the shock mount...to not do this risks destruction of the stock shock as it is not long enough when you are fully articulated down at the wheel (esp if you have your sway bar disconnected).
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 15 Old 10-28-2011, 07:10 PM
gwar11d2
2009 JK Wrangler
Hmm.... What is your budget for tires and the lift? Both budget lifts you mentioned are good. I have the TF spring lift with the 9550 shocks and they are really nice. My opinion is they you should wheel the stock rubi and save for a spring lift from aev, TF, OME, RK, etc. the bug bit me hard in the beginning but I kept saving until I could afford the next step. Now I am almost close to what I want...except now I want bumpers and a winch and a lot more. Best thing really to do is dump the house and put all the extra money in the jeep
09 JK Jeep Green Sahara Unlimited / Teraflex 2.5" Spring-Shocks / 35's x 16" Level 8 Trackers/ Aussie Locker Front / 5:13's
My Build Thread:
gwar11d2 is offline
post #4 of 15 Old 10-28-2011, 07:34 PM Thread Starter
neverhide34
2011 JK Wrangler
Ha good call just live with the in-laws and mod my Jeep. But really..
Like I said. Tires will stay factory Mud Terrain BFG until tread indicates upgrade. So no new tires until about next year. The Teraflex Budget boost with shocks would be around 600 including shipping so that would be ideal.
the bug got me and I feel like I should do something to cure the itch. At least for a little while.
Keep Calm, Chive On
post #5 of 15 Old 10-28-2011, 07:39 PM Thread Starter
neverhide34
2011 JK Wrangler
Thanks for the input. I will take this into consideration.
Keep Calm, Chive On
post #6 of 15 Old 10-28-2011, 08:03 PM
gwar11d2
2009 JK Wrangler
700-800 can get you the TF Spring lift with Shocks. Jason at krawl offroad or Dave at north ridge 4x4 can hook you up. There are a few other good lifts in this range, you doing the install yourself? That can save coin as well.
My Build Thread:
gwar11d2 is offline
post #7 of 15 Old 10-28-2011, 08:12 PM Thread Starter
neverhide34
2011 JK Wrangler
Good catch and thanks. I'll be going with this. For spring lifts I had the 3.5 AEV NTH Degree but it's a pretty penny. I will be doing the work although I have never done lift kits, however I have done a Daystar leveling kid on a Ram so at least I know what it looks like.
Keep Calm, Chive On
post #8 of 15 Old 10-28-2011, 08:18 PM
gwar11d2
2009 JK Wrangler
TF is fairly easy. And you can do 35s when you're ready. Let me know if you need help. I was in the same boat as you a few months back and even ran the stock 32s for a while. Local jeep clubs can probably also give you a hand wrenching. Details in my sig if you want to see pics. I'm running 34s and can tackle some pretty hard trails.
My Build Thread:
gwar11d2 is offline
post #9 of 15 Old 10-28-2011, 08:52 PM Thread Starter
neverhide34
2011 JK Wrangler
That's an awesome build thread in your signature. Made up my mind with the 2.5 in spring lift. I would like to go with the 3 in but might as well save a couple hundred more for the AEV 3.5. Dammit... Now I'm in another predicament. Teraflex 3 in or AEV 3.5. My mind just wonders for miles.
Keep Calm, Chive On
post #10 of 15 Old 10-28-2011, 09:01 PM
ArticRubi
Arrogant SOB
ArticRubi's Avatar
Throw in the Rock Krawler 3.5" mid-arm flex kit to your search too. $1200 for lift plus cost of shocks....puts it right in line with the 3.5 AEV lift.
Need parts? Need product advice? Contact Jason at
ArticRubi is offline
post #11 of 15 Old 10-28-2011, 09:08 PM
gwar11d2
2009 JK Wrangler
Yah I was hours away from getting the rock krawler 2.5 until I was given an offer I couldn't refuse on the teraflex kit. 3.5 is a lot in my opinion
My Build Thread:
gwar11d2 is offline
post #12 of 15 Old 10-28-2011, 09:11 PM Thread Starter
neverhide34
2011 JK Wrangler
Will look into it. So many options...
Keep Calm, Chive On
post #13 of 15 Old 10-28-2011, 09:13 PM
ArticRubi
Arrogant SOB
ArticRubi's Avatar
This is true. If you go 3.5" you will eventually need to upgrade your driveshafts. A 2.5" coil spring kit is a great option, and very capable compared to stock.
post #14 of 15 Old 10-28-2011, 09:27 PM Thread Starter
neverhide34
2011 JK Wrangler
2.5 it is then. Thanks guys, you've all been real helpful. Seems I'll give rock krawler a look. If not then teraflex will be my next investment.
Keep Calm, Chive On
post #15 of 15 Old 10-28-2011, 09:44 PM
gwar11d2
2009 JK Wrangler
Awesome keep us updated!
My Build Thread:
gwar11d2 is offline
aev , lift , teraflex
another lift question/opinion??? wildride89 Wrangler General Discussion 2 03-21-2010 01:01 PM
lift kit w/ body lift - need advice/opinion coldyj YJ Wrangler Technical Forum 13 03-24-2009 02:34 PM
i need a lift opinion? rsoffar YJ Wrangler Technical Forum 7 03-10-2005 12:32 PM
yj lift need opinion. rsoffar YJ Wrangler Technical Forum 2 03-04-2005 12:32 AM
Anyone have an opinion on this lift kit? Jeepgofast YJ Wrangler Technical Forum 7 09-14-2004 02:43 AM
