Question on amplifier power wire placement 2012 wrangler - JeepForum.com
post #1 of 3 Old 09-14-2013, 03:29 PM Thread Starter
rgincajun
Quick question,
I've been doing research on installing my amp/sub combo from my last vehicle. Keep in mind mine does not have the infinity system.
Only thing I have left to figure out is where to run the power cord for the amp. I've read on a post that there is a rubber grommet under the brake cylinder, I just checked and didn't see it. I'm thinking it may have to do with mine having the 3.6?
Where can I run the power wire without drilling through the firewall?
rgincajun is offline
post #2 of 3 Old 09-15-2013, 07:45 AM
Vin
Follow that big loom at the top of the rear of the engine compartment. I'm pretty sure wires branch off that and go through that opening at the Master Cylinder.
Vin is offline
post #3 of 3 Old 09-15-2013, 09:21 AM Thread Starter
rgincajun
Thanks!
I got to looking again and its not quite a rubber grommet like I was thinking, but some insulation on the outside with some plastic on the inside. I should be able to punch through that and run it through. I'm glad to finally get some bass in the factory system. After that I think the sound will be good.
