Question about Steering Stabilizer after HD steering install. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Question about Steering Stabilizer after HD steering install.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 07-14-2009, 01:02 PM   #1
Hellbound13
Well I got my HD tie rod and drag link on. (Rubicon Express).
However, now my drag link was hitting my Rough Country SS which was mounted on the driver side.
The only solution I found was to put it back in the stock location, however since the Rough Country SS is so big I had to angle the mount on the tie rod down a little so that the shock end of the SS did not hit the axle mount when I am turned all the way to the right.
My question is, besides it being lower is there any drawback to this? Will it not absorb shock now that the two ends to the steering stabilizer do not sit parallel to each other?
I have attached a pic so you can see what I mean..
Hellbound13 is offline   Reply With Quote
Unread 07-14-2009, 01:30 PM   #2
N2rock
N2rock's Avatar
I would think that as long it still moves freely back/forth, it would be ok. Other than it is now more susceptible to being smacked on a rock.
BTW- it is WAY to clean under there!
for details and info on our JK's, check out http://n2rock.com
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline   Reply With Quote
Unread 07-14-2009, 09:29 PM   #3
Brent_f70
Brent_f70's Avatar
It will work OK until you smack it on something and it rotates up and you cant make left turns....had it happend, luckly it is a quick fix.
But what you really need to do is put on a high steer...move the draglink to the top of the knuckle as seen below. Now everything is protected and I have NO steering issues.
6.7 HEMI, ProRock 60's, Atlas 4 speed t-case, on board air, Teraflex long arm plus ACOS, 37 inch Maxxis Trepadors, 5.38 gears, AEV bumper, Custom AEV hood, Warn 9.5, Nemesis aluminum sliders and fenders, Or-Fab front cage, Poly Performance rear cage, Hutchinson Beadlocks, PJ rear bumper, HD Teraflex track bars, tantrum rock lights, woods shafts, corbeau LG-1 seats, Chaser Trailer........TIME TO PLAY!!! Colorado Jeep Club member #177
Brent_f70 is offline   Reply With Quote
