Question about D rings and mounting bracket - JeepForum.com
post #1 of 12 Old 07-27-2013, 12:25 PM Thread Starter
ironbike
2011 JK Wrangler
I bought and installed the olympic 4x4 d ring mounting bracket, the one with no welds. It measures 3/4" and I also ordered 3/4" d rings but they are way too big to fit on the mounts. They slide back and forth with about 1/2" of space. What am I missing? Should I have gotten 1/2" d rings?
ironbike is offline
post #2 of 12 Old 07-27-2013, 12:47 PM
222Doc
222Doc's Avatar
they are not a tight fit. Left on they rattle. I carry them in my recovery bag with all the other related stuff. I would not use a "smaller" one. Its about being able to hold a jeep. not looks. I never have them on unless we are in recovery mode or strapping is going to happen a lot, for miles.
You could make some rubber spacers to keep them from bouncing around.
222Doc is online now
post #3 of 12 Old 07-27-2013, 01:21 PM Thread Starter
ironbike
2011 JK Wrangler
Humm never thought about rubber spacers. I just thought there was supposed to be a snug fit. These slide back and forth with ease about 1/2"
ironbike is offline
post #4 of 12 Old 07-27-2013, 01:27 PM
sjones26573
Nope. They aren't made for quietness or daily driving. Put them on when you go offroad, take them off when you are onroad.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #5 of 12 Old 07-27-2013, 05:28 PM Thread Starter
ironbike
2011 JK Wrangler
Well I wasn't really going for just look, I want functionality. But these things have so much space in between that they move all over
ironbike is offline
post #6 of 12 Old 07-27-2013, 06:27 PM
SilverStreaker
Get some isolators and you won't have to worry with them again http://www.quadratec.com/products/92144_900X_PG.htm and http://www.quadratec.com/products/92144_1900.htm
My Jeep - 2012 Wrangler Unlimited Sport S
My Wife's Jeep - 2007 Grand Cherokee - only mod - K&N Cold Air Intake system
SilverStreaker is offline
post #7 of 12 Old 07-27-2013, 06:51 PM
jmb6420
Engr. & Mechanic 08 Rubi
jmb6420's Avatar
I went to Lowes and bought some 3/4 rubber grommets. Put one on each side and they don't even think about moving.
Mike
08 Rubicon
"You can't fix stupid" Ron White
ɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
jmb6420 is offline
post #8 of 12 Old 07-27-2013, 06:55 PM Thread Starter
ironbike
2011 JK Wrangler
So yours use to slide from side to side? I will be going to Lowes tomorrow
ironbike is offline
post #9 of 12 Old 07-27-2013, 07:37 PM
jmb6420
jmb6420's Avatar
Yes, also, if you fix your own toilet valves, the rubber washer included with the fluidmaster valve fits the D rings perfectly. Probably any other kit would work too. The rubber washer that fits the hole that goes through the bottom of the toilet to the water supply line.
Mike
08 Rubicon
jmb6420 is offline
post #10 of 12 Old 07-27-2013, 08:06 PM Thread Starter
ironbike
2011 JK Wrangler
Cool I'll check tomorrow and get back to you
Thanks
ironbike is offline
post #11 of 12 Old 07-28-2013, 03:07 PM Thread Starter
ironbike
2011 JK Wrangler
Well thanks for the great idea. Put the grommets on and now it fits snug.
Thanks
ironbike is offline
post #12 of 12 Old 07-28-2013, 04:25 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
3/4 inch heater hose - scraps are free at most autoparts stores...
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
