Q on JK factory sub - JeepForum.com
post #1 of 6 Old 11-14-2006, 12:09 PM Thread Starter
shredX
Q on JK factory sub
I have the base radio, but noticed I have a wiring harness by the right rear roll bar.
I went to the dealer & verified that harness plugs into the sub.
My question: Is the sub powered? It appears to be a simple pug'n'play. One one of the other forums I thought I had read there is an amp somewhere under the dash. If I don't have that amp, I assume I can not have the sub.
Thanks in advance.
Plug'n'play would be sweeeet.
07 JK Unlimited X ~ Stone White & grey int ~ 4X4 ~ Trac-loc LSD ~ Tow w/ 4.10 ~ Power package ~ S package ~ Freedom Top ~ 16x7 w/ BFG AT 265/75/R16 ~ base radio w/ Sirius Sportster ~ Thule rack
shredX is offline
post #2 of 6 Old 11-14-2006, 12:34 PM
infosponge
infosponge's Avatar
My understanding was that the base radio on the X does not have the amp, but I could be wrong.
infosponge is offline
post #3 of 6 Old 11-14-2006, 03:34 PM
jeepdude_to
I believe the amp is wired in somewhere in/around the box enclosing the sub...
Jeep Green Rubicon
jeepdude_to is offline
post #4 of 6 Old 11-14-2006, 04:38 PM
MD23
I have an X with the sub. It was part of the pkg w/6 disc changer and 6 speakers.
Unfortunately, I can't help with the original question . Hopefully this helps.
MD23 is offline
post #5 of 6 Old 11-14-2006, 06:35 PM
infosponge
infosponge's Avatar
Right, you don't get the amp without the upgraded Infinity stereo system.
post #6 of 6 Old 11-14-2006, 07:53 PM Thread Starter
shredX
So, even w/ the wire harness I'm out of luck.
Bummer.
shredX is offline
Factory or Factory Option Rims? 90yjkrawler YJ Wrangler Technical Forum 10 04-07-2012 11:25 PM
Has anyone wired factory foglights without the factory wiring harness, etc? Canadian-Bear JK Wrangler Technical Forum 3 07-12-2009 05:14 PM
Min. Factory caster and Max. Factory toe-in???? 97casteeltj TJ Wrangler Technical Forum 12 08-28-2008 11:14 AM
whats the difference b/t a factory service manual and factory service workshop manual Johnny World YJ Wrangler Technical Forum 3 03-15-2006 01:01 PM
Factory Hardtop for Jeep w/out Factory switches and harness?? PADI_Pro TJ Wrangler Technical Forum 4 06-07-2003 06:51 AM
