Push starting - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Push starting
Savvy/Currie Aluminum Control ArmsROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO December Specials at Jeephut.com
Unread 12-13-2014, 06:35 PM   #1
Jeeper84
1979 CJ5
Push starting
I've attempted to start my 15 JK from a roll, but it doesn't seem to be working. Can these Jeeps be started from a roll? I've also noticed that the clutch needs to be depressed to start it. None of my previous manual Jeeps needed that.
Jeeper84 is offline   Reply With Quote Quick reply to this message
Unread 12-13-2014, 06:56 PM   #2
ronjenx
ronjenx's Avatar
In the Owner's Manual, it says you have a clutch switch that prevents the engine from cranking unless the clutch is depressed to the floor.
That switch will prevent the starter from cranking the engine. It should not prevent you from push starting by popping the clutch.
The switch is disabled in 4lo so if you're stalled in mud/water, so you don't have to push the clutch to crank it over.
What gear are you in when you try to push start it?
2008 JKU Rubicon
42RLE Auto
ronjenx is offline   Reply With Quote Quick reply to this message
Unread 12-13-2014, 08:08 PM   #3
SLADE
I don't have a problem drift starting my 2013.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline   Reply With Quote Quick reply to this message
Unread 12-13-2014, 08:45 PM   #4
Moezer
2015 JK Wrangler
I tried it on my 2014 u need a really big rolling start Lol first gear it press the clutch and get a nice roll release the clutch and the jeep should stop in its track and fire up and goes again
Moezer is offline   Reply With Quote Quick reply to this message
Unread 12-13-2014, 09:59 PM   #5
442Wrangler
In like Flynn.
442Wrangler's Avatar
Like someone else reccomended use a higher gear (2nd or 3rd) and get a good start, preferably down a hill. The JK will pop start, I've done it two or three times.
2008 JK Rubicon
-255/80/17 BFG KM2s, 16/59 JKU springs, 2013 Rubi rims, RC stubby hybrid front bumper, XRC8 winch with synthetic line, RR evap skid, and more to come
1998 TJ Sahara Sold
-3.25" RC spring lift, Eagle alloys 125s, 33x12.5x15 Cooper STTs, XRC8 winch with stock bumper mount
1994 YJ SE Sold
-4" RC spring lift, 33x12.5x15 Firestone M/Ts, Eagle alloys 125, and a 4 cylinder to boot
1960 Willys Wagon
-Going to be restored and painted Omaha Orange
"I would rather wake up in the middle of nowhere than in any city on earth."
-Steve McQueen
Male RN Jeep Club #1
442Wrangler is offline   Reply With Quote Quick reply to this message
Unread 12-13-2014, 10:18 PM   #6
Jeeper84
1979 CJ5
It makes sense to try a higher gear. It's awesome that the clutch switch is disabled in 4lo. Thanks, guys!
Unread 12-13-2014, 10:21 PM   #7
Jeeper84
1979 CJ5
I should have figured it would be more difficult to roll start than my old honda (I could do it in reverse at 3mph), but I didn't want to damage anything if it weren't possible on the Jeep for some reason.
Unread 12-14-2014, 01:40 AM   #8
AveCat
I do it every once in awhile.
2012 Wrangler JK 3.6 W/ 6 Speed bought 2/15/13
Go look at my photos!
AveCat is offline   Reply With Quote Quick reply to this message
Unread 12-14-2014, 06:54 AM   #9
Prot
Prot's Avatar
2014 JK Wrangler
If you have to push start a 2015, you've got issues.
2014 Copperhead Pearl Unlimited Sahara in progress
Prot is offline   Reply With Quote Quick reply to this message
Unread 12-14-2014, 07:06 AM   #10
SLADE
I'll drift the Jeep around the house and start it around back at 4AM when I'm leaving for work to avoid starting it beside the window where my wife and baby are sleeping. I usually park out front but occasionally I'll forget to move it the night before. By the time I let up on the clutch and the motor fires up, I'm gone and nobody is woken up.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
Unread 12-16-2014, 06:48 AM   #11
paul84043
Push starting a 4400 pound Jeep is going to be just a tiny bit different than my old '76 celica where I could actually stick my foot out and push it backwards with enough force to pop it.
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline   Reply With Quote Quick reply to this message
Unread 12-16-2014, 08:35 AM   #12
JIMBOX
That's funny-
I don't have any reason to "push start" my JKUR-
Maybe you'll need a different exercise program-
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is offline   Reply With Quote Quick reply to this message
