push pin removal on skid plate - JeepForum.com
post #1 of 11 Old 07-27-2013, 10:52 AM Thread Starter
rfjeeper
What's the easiest way to remove those plastic push pins that hold front skid plate to bumper,I want to replace old bumper with a newer one,do you just have to destroy pins to get out or is there a trick to removing them
rfjeeper is offline
post #2 of 11 Old 07-27-2013, 11:10 AM
TheMercenary556
I hooked mine on a stump then backed up, came right off...
TheMercenary556 is offline
post #3 of 11 Old 07-27-2013, 11:31 AM Thread Starter
rfjeeper
Haha never thought of that!!
rfjeeper is offline
post #4 of 11 Old 07-27-2013, 11:43 AM
ncb
Use the tip of a knife or very small screwdriver to apply pressure under the core (middle) of the fastener. Turn counter clockwise and remove core. Remove outer portion of fastener and you're done. Takes a bit of finesse. The alternative is to break them. Most make removal way to difficult.
Edit-it's been a while since I removed the air dam. Do the fasteners have a philips head on the core or is it flat? If it's flat you have to pop out the core of the fastener with a small screwdriver.
ncb is offline
post #5 of 11 Old 07-27-2013, 12:31 PM Thread Starter
rfjeeper
Philips head
rfjeeper is offline
post #6 of 11 Old 07-27-2013, 12:38 PM
ncb
With out pushing too hard with a screwdriver remove the philips head core while prying it upward.
ncb is offline
post #7 of 11 Old 07-27-2013, 12:39 PM
ncb
Or get all caveman on it and rip that ****er off.
ncb is offline
post #8 of 11 Old 07-27-2013, 12:53 PM
222Doc
222Doc's Avatar
Most people loose that first time on a off road adventure that is more than a dirt road, followed by the SS shock. They do rip off by hand as well as do the fenders for the most part.
Once you pull that lower air deflector the hood will flutter more.
222Doc is online now
post #9 of 11 Old 07-27-2013, 04:02 PM Thread Starter
rfjeeper
Sounds like I better invest in better hood latches cause I'm ready to rip that SOB off
rfjeeper is offline
post #10 of 11 Old 07-27-2013, 07:06 PM
Deadhead88
2010 JK Wrangler
Took mine off and am running the smittybuilt xrc bumper and srx flat fenders and no hood flutter unless its just a brutal head wind. Still going to get the drake latches one of these days though
Stock 2010 rubicon
Soft top
Half doors
Deadhead88 is offline
post #11 of 11 Old 08-05-2013, 11:04 AM
Afmcronnie
Just turn the Phillips head screw out and pop the pin. I've put my lightbar on my last 2 JK's. Trashed the first set of pins, bought new ones for the 2nd JK and got them out and back in with no problem. They are cheap. If you DO trash them, just drill them out, like a rivit.
Afmcronnie is offline
