push in or dent on door - JeepForum.com
post #1 of 7 Old 03-21-2007, 02:24 PM Thread Starter
plyzie
Does anyone else have a push in or dent on either door behind the bottom hinge of their 2 door jk. I have one on my passenger side door. My dent guy said it is caused by the hinge as it goes away when you open the door. Has anyone found a solution or heard of this?
plyzie is offline
post #2 of 7 Old 03-21-2007, 06:47 PM
luckyjeeper
luckyjeeper's Avatar
it's called oil canning. My TJ had it in front of the hinges on both sides. My JK has it only on the drivers side. I just chalk it up to having a "flat" sided body and the stress the hinge places on the body there. I haven't gotten an answer as to whether adjusting the door will help tho, or if the damage is done. Anyone? No biggie, I barely notice it anyways.
patrick
2007 JK X 2dr. 6spd.
Steel Blue Hardtop
Virescit Vulnere Virtus
luckyjeeper is offline
post #3 of 7 Old 03-21-2007, 06:56 PM
lazerpunk
Our unlimited has it on the passanger side front door only. It's really not that big a deal I figure it might go away after the door seals compress a bit.
'07 Sahara Unlimited, Red Rock Crystal, Auto, Dual Top, MyGig, 18" Wheels, Trailer Tow, Side Airbags.
2012 Unlimited Rubicon, Crush, Auto, Dual Top, 430N w/nav, Max Tow
lazerpunk is offline
post #4 of 7 Old 03-21-2007, 08:08 PM
BigJerm
yep on my JK driver side door. hard to see though so no big to me
07 Jeep Wrangler Unlimited Rubicon
BigJerm is offline
post #5 of 7 Old 03-21-2007, 08:12 PM
tomc121
tomc121
tomc121's Avatar
warp in door skin
Ya My rubi has a dent in passenger door behind hinge.
tomc121 is offline
post #6 of 7 Old 03-21-2007, 09:44 PM
Dirt_sample
My driver door was so bad that it looked like a mirror in a fun house! The dealer had the body shop work on the inside of the door as well as realigned it, it helped but it's not perfect. The 5 Start dealer that I bought it from is incapable of providing any type of professional services, when they can't even bolt the drives seat down (twice to get it right), you know you are in for a long day...I felt with the type of work they do that I should just cut my losses and run, I can only imagine what type of body work they do.
Dirt_sample is offline
post #7 of 7 Old 03-22-2007, 10:28 AM
scottyc
I've got this on the rear passenger door. It's very linear, vertical running down from the back edge of the window past the door handle. Happened the first day I had the Jeep when closing the door with the handle. Now I just push on the metal to shut the doors.
scottyc is offline
Dent from letting door swing all the way bsteeves86 JK Wrangler Technical Forum 19 08-09-2009 11:50 AM
Little Dent... TJoshX TJ Wrangler Technical Forum 12 02-15-2009 10:17 AM
oil pan dent rubiwannabe TJ Wrangler Technical Forum 8 06-01-2008 06:46 AM
Oil pan dent? jclaudii TJ Wrangler Technical Forum 9 09-12-2006 11:07 AM
Clutch easy to push one day, hard to push the next 92 RED YJ IN NJ TJ Wrangler Technical Forum 1 02-24-2004 07:57 PM
