Pulling a Pontoon Boat - JeepForum.com
post #1 of 7 Old 07-21-2010, 08:09 AM Thread Starter
wengerda
2010 JK Wrangler
Need some advise. I am planning to purchase a 21 footer pontoon boat. Maximum weight on it is approximately 2500lbs. Do you think I can pull this boat with a 2010 Wrangler 4 doors Unlimited. Not planning to drive more than 10 or 15 miles from the marina. Also I am not planning to change the axles.
wengerda is offline
post #2 of 7 Old 07-21-2010, 08:13 AM
BAMAJK
2009 JK Wrangler
Yes, towing capacity on a 4 door is 3500 lbs.
BLUE JEEP #237
BAMAJK is offline
post #3 of 7 Old 07-21-2010, 08:18 AM
OneJeepNewb
if you got the towing package or the auto tranny you are fine. As long as you have the 3:73 gears or better. I wouldn't try it with the 6speed and 3:21 gears.
OneJeepNewb is offline
post #4 of 7 Old 07-21-2010, 10:01 AM
gsaxe
hills
Well my boat+trailer is just under 1000 lb so maybe no comparison, BUT as you can see in the pic I have towed it up and down some big, steep, and long "hills" You should have no probem just in 15 miles.......
AKA Catfish
gsaxe is offline
post #5 of 7 Old 07-21-2010, 10:15 AM
gmorgan
I have a 2 door jk and a 20' pontoon boat and the pontoon is 8' wide you WILL need towing mirrors . I tryed it one time and it was not fun I use my dodge daully to tow it and it's safer
Boat+gear+cooler+boat gas+ people = more than you think
And you have to be able to stop this when some a$$ pulls out in front of you, and you know they will they do it to me , they don't want you to slow them down.
12' jeep 3800lb. pulling a 21' boat +gear = jack kniff
gmorgan is offline
post #6 of 7 Old 07-22-2010, 01:51 PM
gsaxe
yea, don't stop fast....
AKA Catfish
gsaxe is offline
post #7 of 7 Old 07-22-2010, 08:10 PM
USAntigoon
Retired from Forum
I couldn't find your gears as you haven't filled out any details in your profile.
Be sure you have the weight correct..TOTAL weight, includes the loaded pontoon WITH engine, fuel batteries etc.. I am close to 3,000 lbs with my 21 ft pontoon (60 HP Merc Bigfoot, two batteries, 15 gallons fuel and two anchors, plus all the other gear..and last but not least please add the weight of the trailer... (at least another 1,000 lbs)
You might be very marginal...if not over the towing limit..
USAntigoon is offline
JK Wrangler , towing , towing capacity , wrangler
pulling 2500lb boat w/ tj freetj98 TJ Wrangler Technical Forum 16 04-05-2008 07:47 AM
Pulling a boat with my Wrangler ang4jags TJ Wrangler Technical Forum 14 11-12-2007 12:50 PM
pulling a boat BMdeckie TJ Wrangler Technical Forum 4 04-08-2007 04:32 PM
Pulling a Boat KevinOpp TJ Wrangler Technical Forum 2 06-01-2005 05:16 PM
pulling a boat.... Sahara_98 TJ Wrangler Technical Forum 5 06-26-2002 08:02 PM
