PSC Brawler & Warn issue - JeepForum.com
post #1 of 8 Old 05-06-2013, 11:27 AM Thread Starter
Filthy-Beast
I've got an issue with the black metal loop on the Warn synthetic line, no matter where I connect the hook the black metal piece hits the fairlead. I've tried d-rings and the bar.
How have others solved this?
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #2 of 8 Old 05-06-2013, 11:34 AM
cyberpyrot
buy a rubber isolator you know the round things made just for that issue. love you man!!!!!!
http://images.search.yahoo.com/searc...2=piv-web&vm=r
I have attention defiiiii hey is that a rabbit?
Thought of the day
Trust people who like big butts they cannot lie...
cyberpyrot is offline
post #3 of 8 Old 05-06-2013, 11:38 AM
brianjw
Hook it on somewhere else, or replace the hook with a thimble.
I just installed the zeon 10s on my exp one front bumper and due to the placement of the recovery points, either the hook or the shackle will scrape at the powder coat when snugged up.
I snugged the hook up to the fairlead and scratched it up already. Oops! I'll probably replace the fairlead and put a safety thimble (with a rubber isolator) on the end.
brianjw is offline
post #4 of 8 Old 05-06-2013, 12:39 PM
HOKIES2010
2011 JK Wrangler
I have seen a set up using a OD Tube Clamp that had a D Ring mounted on it. The tube clamp was in positioned on the top middle of the bar and the winch was hooked onto it. You obviously can't use it as a tow point but a taught winch line will hold it in place. I can't remember where I saw it but poly performance sells the clamp with optional mounting tabs.
http://www.polyperformance.com/shop/...mp-p-1727.html
My Build
Couldn't have done it without
HOKIES2010 is offline
post #5 of 8 Old 05-06-2013, 01:18 PM Thread Starter
Filthy-Beast
I saw that also and liked the look. That was my original plan but the bar is not far enough away, the loop still hits.
For Sale:
post #6 of 8 Old 05-06-2013, 05:00 PM
Tanimal
MetalCloak makes a nice cheap solution:
http://www.metalcloak.com/Winch-Hook...unt-p/2205.htm
Edit: Just read your above post but will still keep this post here for reference if people search.
Learning as I go and it's worth every penny!
Tanimal is offline
post #7 of 8 Old 05-06-2013, 08:59 PM
4wdjeepguy
Just switch it out for a safety thimble.
IG: CS_OFFROAD
YOUTUBE: CS OFFROAD
4wdjeepguy is offline
post #8 of 8 Old 05-06-2013, 09:23 PM Thread Starter
Filthy-Beast
The Viking safety thimble I have on my LJ just uses the line and would not fit the metal loop on the Warn line. I was not looking forward to unweaving the new Warn line.
It looks like the Factor 55 thimble might be able to fit the Warn loop. It's pricy though, 149 for the thimble pin and rubber bumper.
For Sale:
