Proper Way to Add Coolant - Page 2 - JeepForum.com
post #16 of 33 Old 06-09-2012, 09:36 AM
SoK66
2009 JK Wrangler
The Mopar stuff will set you back about $25 a gallon. Get the NAPA stuff and be happy.
SoK66 is offline
post #17 of 33 Old 06-09-2012, 10:20 AM
Jiblet
Also, it comes 50/50 or full strength, so the prices vary.
Zerex G-05 is the same as the MOPAR stuff.
Jiblet is offline
post #18 of 33 Old 06-10-2012, 10:02 AM
LIJeepJC
Originally Posted by lostsock
So don't add water to the coolant before adding it to the reservour bottle?
You can but I use the 50/50% blend so I domg
LIJeepJC is offline
post #19 of 33 Old 06-10-2012, 10:18 AM
kalsig
2010 JK Wrangler
Just a side note. If you do mix your own, use distilled water.
kalsig is offline
post #20 of 33 Old 06-10-2012, 11:26 AM
Crimbshaw188
Originally Posted by Jiblet
yes, the JK uses the HOAT coolant. but it's not that hard to find around here.
Any G-05 will do. Is it hard to find in your area?
Yes!! Only place is the dealer. And if you got to the parts store they try to sell you regular 50/50 prestone
Crimbshaw188 is offline
post #21 of 33 Old 06-10-2012, 11:45 AM
JBTJ
Did you try NAPA auto parts?
JBTJ is offline
post #22 of 33 Old 06-10-2012, 05:37 PM
wilywillie
Originally Posted by smcutter View Post
The heaters in the JK's are pretty insanely awesome when they're working right.
Ain't that the truth!
I'm just here for the gasoline. --Max
wilywillie is offline
post #23 of 33 Old 06-10-2012, 09:11 PM
Jiblet
You could toast marshmallows with mine!
Jiblet is offline
post #24 of 33 Old 06-13-2012, 08:04 AM Thread Starter
lostsock
Originally Posted by lostsock View Post
On a side note, is it normal for the coolant reservoir to be that low at 76k miles? I just purchased this jeep a few weeks ago and noticed that the coolant was low. Its also not blowing out any hot air when I have it cranked up to the max, and the temperature gauge seems to flucuate from the mid point to nearly the red, which may be caused by too little coolant (i hope).
Cheers
**Update** The source of the leak ended up being a bad coolant intake gasket. After replacing that and refilling the coolant, no more leaks and lava hot heat!!
lostsock is offline
post #25 of 33 Old 11-06-2012, 12:05 PM
db8
Is it tremendously important to use distilled water for the 50/50 part?
db8 is offline
post #26 of 33 Old 11-06-2012, 10:38 PM
daggo66
2009 JK Wrangler
Just buy the premixed kind and be done with it.
Tom
daggo66 is offline
post #27 of 33 Old 11-07-2012, 06:54 AM
ronjenx
ronjenx's Avatar
Yes. You want water with no chemicals or minerals in it.
ronjenx is online now
post #28 of 33 Old 11-07-2012, 09:45 AM
Godholio
If you use tap water the minerals and crap will collect in the system. The smallest passages are in the radiator, so that's where most of it will collect, clogging it. It's not the end of the world if you topped it off, but don't make it a habit because eventually it'll come back and bite you in the form of an overheating engine and most likely a new radiator. Either buy the 50/50 premixed or mix it yourself with distilled water...I haven't actually compared the prices to see which is cheaper.
Water actually does the cooling, not antifreeze...that's just a chemical to assist in heat transfer and to raise the boiling point and lower the freezing point.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #29 of 33 Old 11-07-2012, 12:16 PM
fitzz47
I believe the 2013 jk calls for OAT antifreeze
2015 GC Attitude Black
2015 Wrangler Sahara Hydro Blue
fitzz47 is offline
post #30 of 33 Old 11-07-2012, 12:25 PM
Jiblet
Absolutely correct. 2013s use a new and differently formulated OAT.
Not the HOAT of the 2007-1012s JKs and not the OAT of older formulas.
Be aware!
Jiblet is offline
coolant , Coolant leak
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Sweet Coolant Smell but No Coolant Leak? JB73 TJ Wrangler Technical Forum 4 11-07-2010 11:56 PM
I see coolant I smell Coolant But can't find leak. MrB TJ Wrangler Technical Forum 23 07-18-2010 07:33 PM
huge coolant leak/ creamy coolant?? 11Bgixx TJ Wrangler Technical Forum 17 01-11-2010 10:24 AM
Looking for proper name Scramblinlife TJ Wrangler Technical Forum 2 08-31-2009 08:36 PM
Can anyone tell me the proper PSI for 30/9.50 BFG AT ? Pkibugu TJ Wrangler Technical Forum 1 08-14-2003 12:47 AM
