Programing a third key for 2011 Wrangler JK - Page 2 - JeepForum.com
post #16 of 48 Old 01-23-2011, 11:30 AM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Don't get the transmission hot oil TSB recall done. I've got this code update, and now I cannot program a RFID key. I will have to take it to a dealer to fix the code.
2009 JK Rubicon
Shrockworks Mid-width, Warn 9.5Ti; Skid Row Engine Skid, LCA & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Diff Skids, 11,000# Pull-Pal. Uniden 520XL CB; 1" Front & 1/2" Coil Spacer Rear; Aeroforce Interceptor, Valentine 1.
Moab - TJ-4/2006, TJ-5/2008, 4/2009, 5/2011, 4/2013, 5/2016, 4/2017
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
Thunderstrike is offline
post #17 of 48 Old 01-30-2011, 07:55 AM
Eightbit
I have an 07 JKU Rubicon, I had that TSB done in November. I programmed 2 keys yesterday no problem. I got them off eBay for $7 each. My local hardware store cut them for $1 each. I tried both keys before programming them. They started the jeep and it died after a few seconds, it did not lock the computer. There is both good and bad information in this thread, so your results may vary.
Eightbit is offline
post #18 of 48 Old 06-19-2011, 05:15 AM
mabar
2011 JK Wrangler
Lots of aftermarket places sell transponder chip keys to fit JK Wranglers. Many are under $25. You have to have the key cut to match your key at your local hardware store.
Self-programming directions are in your owner's manual.
Google:
jk wrangler transponder key
Mabar
2011, 2-Door Rubicon
The Bigger the Government, the Smaller the Citizen
mabar is offline
post #19 of 48 Old 06-19-2011, 08:30 AM
Deuskid
good information to know. subscribed.
Deuskid is offline
post #20 of 48 Old 06-19-2011, 08:45 AM
chopperbobby
2010 JK Wrangler
I had a non transponder key cut for my 2010. I tried to start the jeep with it. it will start but shuts off. Did this a few times. Nothing happened. Put in my transponder key and started right up.
chopperbobby is offline
post #21 of 48 Old 06-19-2011, 10:20 AM
mabar
2011 JK Wrangler
A non-transponder key will open the doors and start the engine, but the engine will shut down after a few seconds.
Mabar
mabar is offline
post #22 of 48 Old 02-15-2012, 08:08 PM
Zoider
1995 XJ Cherokee
I recently purchased an 07 JK that came with only one key. The dealer wants $140 for another key. Is there a way to program a new key with only one key in my possession? Perhaps use the same key twice?
Zoider is offline
post #23 of 48 Old 02-15-2012, 08:19 PM
AROSETO
2005 TJ Rubicon 2dr. Khaki Dual top, 4" OME springs w/33" BFG MTs on 16" MotoMetals, Superlift rear adj. Trackbar & JKS front adj., Currie currectlync steering setup, Russel braided Stainless 4" extended brake lines, ARB bull bar w/ Smittybilt XRC8 winch, Garvin Wilderness swing away tire carrier/bumper system w/ trailrack and gas can holders, KC slimlites 130W windshield mounted, Outlaw door hinge mounted mirrors, JKS sway bar discos, TW doublecardan DS, JKS Adj. CA., 4-Hi locker switch mod.
2012 Jeep JK Sport 2dr. Sahara Tan 6sp.
Past Jeeps: 78 Golden Eagle CJ7 304, 85 CJ7 4.2L and 95 YJ 4.0L
AROSETO is offline
post #24 of 48 Old 02-15-2012, 08:37 PM
Eightbit
No, but if that $140 includes some exorbitant cost for the key, you could buy your key from somewhere else pay a buck or two at the hardware store to have it cut and you would only have to pay the dealer for the cost of programming the key.
Eightbit is offline
post #25 of 48 Old 02-16-2012, 05:57 AM
mabar
2011 JK Wrangler
Our local hardware store has the programming equipment to program transponder keys.
Check with your local hardware store or locksmith.
Mabar
mabar is offline
post #26 of 48 Old 02-16-2012, 06:19 AM
Deuskid
Can a new key be programmed from an 'original' and then a 3rd?
Scenario: Buy Jeep w/ 2 keys. Program 3rd key using the manual system. One of the original keys is subsequently lost/destroyed. Now have 1 original and 1 spare.
Can the remaining keys perform the same function as the 2 originals?
I know this sounds far fetched but I have 3 adult sons and a number of grandsons and lost keys are inevitable.
Thanks,
john
Deuskid is offline
post #27 of 48 Old 02-16-2012, 06:28 AM
mabar
2011 JK Wrangler
Thanks,
john
Short answer: YES
Long answer: As long as you have ANY two working transponder chip keys, either original keys or replacement keys, you can self-program additional keys.
Directions are in your owner's manuals.
Good place to get inexpensive, Made in the USA chip keys here:
Transponder chip keys for Wrangler, Patriot, Compass & Liberty
Mabar
mabar is offline
post #28 of 48 Old 02-16-2012, 03:25 PM
Deuskid
Originally Posted by mabar View Post
Short answer: YES
Mabar
Excellent, best answer possible. Thanks
Deuskid is offline
post #29 of 48 Old 02-16-2012, 04:45 PM
chopperbobby
2010 JK Wrangler
ace hardware 50 bucks. cut and programed.
post #30 of 48 Old 05-17-2012, 09:54 AM
webwidejosh
Second or third key?
I've found no option to do the 2nd key except the dealer.
webwidejosh is offline
2011 Wrangler Incentives? Kroelec JK Wrangler Technical Forum 16 01-12-2011 03:46 PM
thinking about a 2011 wrangler beaky73 Wrangler General Discussion 5 01-08-2011 04:03 PM
2011 WRANGLER pricing flybynav1965 Wrangler General Discussion 1 11-22-2010 05:33 PM
Build your 2011 Wrangler Rob_P JK Wrangler Technical Forum 10 09-10-2010 10:24 AM
2011 Wrangler Pictures zoomy97acr JK Wrangler Technical Forum 59 09-07-2010 06:28 AM
