Problem with Rough Country Lift. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Problem with Rough Country Lift.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 01-25-2011, 03:15 PM   #1
ArmyFireFighter
yesterday I noticed that the rubber isolation mount that sits above the rear coil and under the 2.5" coil spacer had slipped over the edge of the spacer. It doesn't sound all that bad, but I have clearly lost some lift and the isolation mount is not centered over the spacer as it should be. And the Isolation mount is obviously not going to last long in the akward postition its in.
I called Rough Country and they were less than helpful. After some persistence on my part, they asked me to email them some pics of the problem to forward to R & D. "no problem" I thought, figuring they would respond to the email. After a day I recieved no response. So I called yet again hopeing they had a solution to the problem. I spoke to the same guy again and today was told that the R & D department was going to bring in a vehicle with the lift on it "to see if it would be an issue."
RC seems to be comfortable with me having to disassemble the kit and reposition the isolation mount everytime it slips. I explained to them over the phone that I was not okay with the idea.
I am still less than convinced that Rough Country is willing to provide a solution to the problem I am having with their product.
ArmyFireFighter is offline   Reply With Quote
Unread 01-25-2011, 03:34 PM   #2
RCXTREME
RCXTREME's Avatar
Has the coil come unseated on the lower mount? Looks as if it has shifted off the lower mount and has the spacer twisted.
RCXTREME is offline   Reply With Quote
Unread 01-25-2011, 03:46 PM   #3
ArmyFireFighter
Thanks for the response. I did just confirm that the coil is seated properly on the lower mount. The coil top and rubber isolation mount appears to have "slipped" off and up the spacer.
Unread 01-26-2011, 10:35 AM   #4
ArmyFireFighter
A buddy took a look at it today, confirmed that the isolators a pretty well shot. Dissapointed.
Unread 01-26-2011, 10:43 AM   #5
RCXTREME
RCXTREME's Avatar
So is it just that the stock isolator is worn?
Unread 01-26-2011, 11:08 AM   #6
ArmyFireFighter
no, as stated above the isolator has slipped off of the spacer, completely stretching and deforming the spacer. EDIT: There only appeared to be metal on metal contact. my apologies, however the problem is still as stated above.
Unread 01-26-2011, 11:15 AM   #7
ArmyFireFighter
I am curious how you possibly came up with that conclusion based on the photos provided, showing a close up of the top of the coil, isolator and spacer.
"So is it just that the stock isolator is worn?'
This once again is starting to sound like RC is trying to blame a stock component for a design flaw in the spacer.
Unread 01-26-2011, 11:42 AM   #8
jpacosta
2011 JK Wrangler
please keep us posted on this since i just recently installed the same setup and have me somewhat worried here. I checked my springs last night and all is good . Also, have you noticed some sort of sqeaky noises after your install? Barely noticeable but i did here it when i stepped on the brake make the car come to a quick stop. Maybe i just have to spray some silicone lube on the swaybar/ control arms. Im wondering if after driving in snow etc it has developed surface rust or dried something out.
thanks,
jpacosta is offline   Reply With Quote
Unread 01-26-2011, 12:26 PM   #9
RCXTREME
RCXTREME's Avatar
Nobody putting the blame on anybody or anything. Just suggesting and asking. I can definately see how it could wear a spacer out from being off center and rubbing on the coil spacer. Give me a call with your original order # and I have some spacers that are 3/4 you could replace those with. I am here to help you out, so no pointing the blame at anybody just asking.
Unread 01-26-2011, 01:23 PM   #10
1222
Make mine a Jeep!
1222's Avatar
ArmyFireFighter, sounds like you have too much down travel and the spring unseated just enough to let the isolator shift.
1222 is offline   Reply With Quote
Unread 01-26-2011, 01:38 PM   #11
Rescue13
I think 1222 is right. You could have been flexing and there was alot less pressure on the spacer and it shifted a bit.
Rescue13 is offline   Reply With Quote
Unread 01-26-2011, 02:42 PM   #12
paul84043
This was my fist thought as well... I've seen it more than once.
paul84043 is offline   Reply With Quote
Unread 01-26-2011, 02:46 PM   #13
asknight
It's an entry level kit. The only way that problem in the photos can occur is by flexing the suspension enough to unseat the coil spring outside the limitations and intent of the budget boost. This means it's time to upgrade to a set of coil springs for trouble free flexing.
asknight is offline   Reply With Quote
Unread 01-26-2011, 03:04 PM   #14
ArmyFireFighter
I see your points about the flexing, however I have never really "wheeled" all that hard, I only hit what most would consider easy to moderate trails.
RCXtreame I will refrence the order number and give you a call tomorrow morning.
Unread 01-26-2011, 03:18 PM   #15
1222
Make mine a Jeep!
1222's Avatar
If that’s the problem then you don’t have to be wheeling all that hard. Jack it up by the frame and let the rear wheels dangle and see if you can jiggle the springs at all.
