Pre-Wired Fog Lights? - JeepForum.com
post #1 of 2 Old 09-28-2013, 12:09 PM Thread Starter
jflanagan00
I've read a lot of posts about installing OEM fog lights and people getting to the point where they need to wire slots 11 & 16 in the D Connector of the TIPM and they find that 11 & 16 are already wired. That's where I am. Posts seem to indicate that this means it is pre-wired and there should be connectors somewhere (wheel hub, front bumper etc). Problem is that I cannot find any unaccounted for connectors or any wires of the same color as the wires in 11 & 16. Two questions please:
1. any idea where i should be looking?
2. how do i remove the wires from the D connector to install my wiring harness?
Thanks.
jflanagan00 is offline
post #2 of 2 Old 09-28-2013, 05:26 PM
J33PNSL33P
I wired Oem fogs onto my 07 x that came from the factory without. I believe I found that the slots were taken as well ( at least one of them was) i disconnected them and connected the ones from my wiring harness. I don't remember exactly how the pins come out but It was a PITA to get them in and aligned properly. I took it to the dealer to get the comp flashed once i was done and they work perfect. Good luck, and have patience!
J33PNSL33P is offline
