Power loss from 35's? & pwr mods - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Power loss from 35's? & pwr mods
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 07-30-2013, 01:17 AM   #76
TRAUMAhead
2010 JK Wrangler
Originally Posted by HappyTrails View Post
Rock-Rocker, I would not worry about the pinion being too small. At 4.88 the pinion is still very thick.
I am running 5.38's and have snapped the rear D44 axle shaft, but the pinion did just fine. Honestly, I have rarely heard of anyone snapping a pinion, even 5.38's. Others may have different stories, though. Usually, it is the axle shaft that goes first. You should be fine with 4.88's, unless you are attacking Moab like a monster truck on Red Bull & Crack.
What gear brand did you go with? And did you upgraded the axle shaft? Getting regeared Wednesday, 5.38s, still deciding between Motive and Yukon. Running 35s now, going 37s when these wear out.
TRAUMAhead is offline   Reply With Quote Quick reply to this message
Unread 07-30-2013, 01:43 AM   #77
brianjw
5.38s on 35s with a 2012 will be real low. Hope you're not running freeway speeds a lot!
On a side note, either get a trans skid plate with a beefier crossmember or get the poison spyder crossmember. I was surprised that the stock skid plate held on while I drag mine over rocks but the crossmember is bent up a bit.
brianjw is offline   Reply With Quote Quick reply to this message
Unread 07-30-2013, 11:04 AM   #78
HappyTrails
Registered Voter w/ID
HappyTrails's Avatar
I am using Motive Gears. Stock axle shafts...for now. Will upgrade to chromolies when the $$ is available.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline   Reply With Quote Quick reply to this message
Unread 08-02-2013, 01:38 AM   #79
TRAUMAhead
2010 JK Wrangler
2010.
Went with Motives. Disappointed with going from 4:10s to 5:38s on 35s/Auto/3.8L. Living in a flat town and keeping OD off, the 4:10s were fine. I mainly regeared for the few times I travel out of town and for less stress on the drivetrain. Felt like the power gain was minimal, and now it feels worse around town as keeping OD off keeps the RPMs too high, so I leave it on and now in 4th unless I'm above 2k, it's still sluggish. If I ever get a new Jeep, I'm learning how to drive stick.
Unread 08-02-2013, 03:37 AM   #80
HappyTrails
I'm on 37's, 5.38's, and an auto, too. However, I went a step further. Also added a RIPP SC. No power problems now. Hehehe
Unread 08-02-2013, 11:36 AM   #81
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
The two R's of more performance from a 3.8 - Regear, RIPP it....unless you want a hemi that is.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote Quick reply to this message
Unread 08-02-2013, 11:52 AM   #82
bluerockymtn
Do the ripp long tubes not help?
bluerockymtn is offline   Reply With Quote Quick reply to this message
Unread 08-02-2013, 11:54 AM   #83
RockyClymer
RedRock4Wheeler
Not much without the RIPP SC first....
NRA Life member
Unread 08-02-2013, 12:33 PM   #84
takeitsleazy
I like this thread. Lots of good insight. To spare me clogging up the forum with another thread ill ask here:
I have a completely stock setup at the moment (3.21, auto, 3.6), and have planned on getting 33s for a while. Its my DD, but I do plan on mild off roading once i get out of this flat *** country. However, I feel like i might want 35s over time. As of now I have a TF leveling kit. Would anything need to change besides upgrading to 4.88? Runnning the stock d30/44, gussets in the front. If it isnt too much trouble, i may just skip the 33s and upgrade my gearing sooner than planned. I fear ill need a bigger lift, though, even with trimming my flares.
USAF RHS
takeitsleazy is offline   Reply With Quote Quick reply to this message
Unread 08-02-2013, 01:44 PM   #85
TRAUMAhead
2010 JK Wrangler
Look for some springs off a Rubicon, there's a couple threads floating around that have the spring #'s for the tallest ones.
I'm running 35s, leveling kit, cut flares, no rubbing.
Unread 08-02-2013, 03:08 PM   #86
takeitsleazy
awesome, loving it. i saw the posts talking about rubi spring #s, already written down haha. thanks!
USAF RHS
Unread 08-02-2013, 07:42 PM   #87
HappyTrails
Don't forget to paint the springs...adds at least an additional 5 HP.
Unread 08-06-2013, 07:33 AM   #88
JeepMahn08
Only commenting to read this tomorrow xx. Lmao
JeepMahn08 is offline   Reply With Quote Quick reply to this message
Unread 10-29-2013, 08:11 PM   #89
JLC08JK
What was I thinking?
JLC08JK's Avatar
Post #18 has been edited to include the 2012+ 3.6 liter gear ratio charts.
JLC08JK is offline   Reply With Quote Quick reply to this message
Unread 10-30-2013, 01:12 AM   #90
spinlock
Nice! 3.8 vs 3.6 resolved
This thread can live on
spinlock is offline   Reply With Quote Quick reply to this message
3.73 gears , 35" tires , JK Wrangler , power loss , stock gears , wrangler
