Power loss from 35's? & pwr mods - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Power loss from 35's? & pwr mods
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 07-19-2010, 08:33 PM   #1
takeda54
How much power loss can you expect from going to 35's from the stock tires(255/70/17) "32" on a stock JK X with 3.73 gears. I plan on doing exhaust and cold air intact with predator , I hope this will help. I have been told by a local shop this will be good up to 35 horses.
takeda54 is offline   Reply With Quote Quick reply to this message
Unread 07-19-2010, 09:04 PM   #2
fernjack
Most guys on here will tell you to save your cash and use it for gears .....the intake & exhaust thing just doesn't make ponies on this engine . Probably would need a cam and a retune to be able to use the intake & exhaust . Are you auto or 6spd. ?
fernjack is offline   Reply With Quote Quick reply to this message
Unread 07-19-2010, 09:08 PM   #3
stanware
I went to 35" from stock and also got a Volant Exhaust and intake and there is power loss, it was only after my Superchips tune that I got some real power back.
stanware is offline   Reply With Quote Quick reply to this message
Unread 07-19-2010, 09:17 PM   #4
fan45acp
2010 JK Wrangler
Really save your money and REGEAR...
fan45acp is offline   Reply With Quote Quick reply to this message
Unread 07-19-2010, 09:25 PM   #5
GPV
Yep regear it and be done with it.
Sean
2008 Jeep JK Rubicon Unlimited (Bought for Wife)
2007 GMC 2500HD Duramax (Work Horse)
1982 Honda CB 900F Supersport
2001 Honda RC51
GPV is offline   Reply With Quote Quick reply to this message
Unread 07-19-2010, 09:32 PM   #6
Benderff
Benderff's Avatar
You will not lose any engine power by changing tires. (So why would you waste money fixing something that's not broken?) Changing tire size affects the rate your drivetrain can turn your tires. If you want to be able to turn the tires the same as before you need to regear the axles.
Benderff is offline   Reply With Quote Quick reply to this message
Unread 07-19-2010, 09:33 PM   #7
MilitaryJK4455
2010 JK Wrangler
about a 20% power loss in take off and about a 5% loss in mid speed (2500 rpms runnin up to about 65) and then about a 15% loss in anything over 70-75mph. Thats about the best I can describe it in terms that ppl on the interwebz can understand.
MilitaryJK4455 is offline   Reply With Quote Quick reply to this message
Unread 07-20-2010, 02:10 AM   #8
Armycop
2014 KL Cherokee
The Superchip can give you a couple more HP and a better throttle response, but regearing is the best way to get the engine in the sweet spot for power.
2014 KL SPORT BILLET SILVER l 9-SPEED l 25% TINT l MB ICON WHEELS l OEM SPLASH GUARDS
Armycop is offline   Reply With Quote Quick reply to this message
Unread 07-20-2010, 02:16 AM   #9
1222
Make mine a Jeep!
1222's Avatar
Yup, re-gear first. If itís an auto go with 5.13ís. Maybe even 5.38ís.
1222 is offline   Reply With Quote Quick reply to this message
Unread 07-20-2010, 02:37 AM   #10
JLC08JK
What was I thinking?
JLC08JK's Avatar
Just to give a real world example; I just came back from a road trip on 35" tires and stock 3.21 gears. In fifth gear at 2k rpm it was at 65 mph, there was absolutely no power available to accelerate without down shifting into fourth gear. I ended up running 90% of the 600 mile round trip in fourth gear at 75 mph with an occasional shift to third to climb the hills.
I have the 4.88 gears and they will go in as soon as I get my ARB locker for the rear.
The Flash Pack could have helped but it won't change the rpm/mph ratio!
JLC08JK is offline   Reply With Quote Quick reply to this message
Unread 07-20-2010, 03:08 AM   #11
MilitaryJK4455
2010 JK Wrangler
With my 3.73's I just got back from a trip with 35's also... 4th gear at 65 im running 2500 rpms, I did have power to accelerate and I was getting about 18.5 mpg and I could go up to 5th gear and run about 2k rpm unless I was going up hill, then I would drop into 4th.... That shows you the change just up to 3.73's... I only have to hit 3rd gear when traffic got slow or I was decelerating.
Unread 07-20-2010, 03:12 AM   #12
Warlord2
screw gears, just buy a hemi and call it good
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline   Reply With Quote Quick reply to this message
Unread 07-20-2010, 02:20 PM   #13
1222
Make mine a Jeep!
1222's Avatar
Ok, but Iíll have to sell my kids first. Ooh, this is starting to sound better already.
Unread 07-20-2010, 02:27 PM   #14
Rafi
2010 JK Wrangler
i just got back from a 400 mile round trip on 35's with 3.73's too. I was only able to really put it in 6th gear down hill. but most of my time was spent in 5th and needing 4th up hills. You think you would get better gas milage in 4th gear revving higher than 5th? Probably what a 300-400 rpm difference? just because it would be "trying less" even though the rpm's were higher? i was at 15.8mpg's or so. but i was going up to the moutains...
Rafi is offline   Reply With Quote Quick reply to this message
Unread 07-20-2010, 04:54 PM   #15
MilitaryJK4455
2010 JK Wrangler
It just depends on how you drive man... I try to run about 65-70 in fifth gear where I can and I drop to 4th for inclines to keep the motor from working too hard... good mpg's and giving it hell dont go together
Not to mention I was driving to the beach... Not too many hills, I was able to run 5th pretty much the whole way unless traffic lights or idiots ended up in front of me.
3.73 gears , 35" tires , JK Wrangler , power loss , stock gears , wrangler
