Power loss from 35's? & pwr mods - Page 5 - JeepForum.com
post #61 of 103 Old 05-03-2013, 03:36 PM
dualtjs
2011 JK Wrangler
Originally Posted by JIMBOX View Post
5.38s are the "top cat" move, but thats another story-
JIMBO
Isn't 4.88 the top gearing for the D30 or is this D30 dramatically different than the one found in the TJ?
dualtjs is offline
post #62 of 103 Old 05-03-2013, 03:53 PM
JTPhoto
JTPhoto's Avatar
Totally different D30 then the TJ.
5.13 is the highest ratio that is readily available for the D30, however, there was a company who did produce a D30 5.38 but I am unaware if it is still available.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #63 of 103 Old 05-03-2013, 03:57 PM
SubAtomicGenius
2011 JK Wrangler
Technically, the D30 and the D30JK are what they are called, they have subtle differences. The D30JK is definitely more robust, however it still suffers from a small ring and pinion size. Though most reference material classify them both as a "D30". IMHO, the lowest practical gearing on a D30JK is 4.88's (IMHO, if you plan on going offroad) due to the super-small pinion size of the 5.13's. Hell, even the D30JK 4.88 pinion is super small compared to stock gearing. Hence, the trend to go with larger axles as the gears go down (numerically higher). 5.13's, IMHO, should require a D44JK. I've heard of 5.38's for the D30JK, but I wouldn't touch them.
SubAtomicGenius is offline
post #64 of 103 Old 05-03-2013, 06:06 PM
Prot
Prot's Avatar
2014 JK Wrangler
5.13's work fine in my D30 up front and D44 rear.
As a matter if fact I recently had to get one differential rebuilt. Nope, it wasn't the front. My rear D44 had problems with the gears and the factory limited slip. I had the bearings and seals changed again, new Yukon gears replaced the superior gears, and since it was apart anyway, I had a Yukon zip locker installed which is an air locker very similar to an ARB but a few hundred dollars cheaper.
It is worth noting I don't crawl on rocks and I am a flat lander and mud bug. I also tow and enclosed trailer.
I haven't had a chance to really use the locker other than brief testing but it seems to a quality piece with smooth operation. I was expecting it to be clunky but is so smooth you can't feel or hear it engage.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is online now
post #65 of 103 Old 05-03-2013, 09:38 PM
dualtjs
2011 JK Wrangler
I'm quickly coming to the conclusion that 4.88 is ideal for my needs. My wife complains that the Jeep is too tall to get into. There's virtually no way that I'll move up to 35's.
Several people have said that 4.10's with 35's is a good combo for the 2012-2013 5 speed auto. With that set up at 2,200 RPM the Jeep should be doing 67 MPH, in 5th gear and 15 MPH in 1st. A 2007-2011 with auto tranny and 4.88 gears would do 67 MPH in 4th gear and 16 MPH in 1st at 2,200 RPM. Running 33's as I am now would have the RPM ~6% higher (2,333 RPM to be precise), which is manageable. If I ever decided to go to 35's it'll be set up to handle them.
dualtjs is offline
post #66 of 103 Old 06-13-2013, 08:33 PM
gunny40
1982 CJ7
I have a 2012 unlimited with3.6L 6speed manual and 3.21 gears. I have installed a 4" lift and 315x75x16 tires. I have lost a lot of power and torque. I want to regain the power without compromising gas mileage too much. I am either going with 4.56 or 4.88. Which is better with the 3.6 pentastar, 6speed manual, Dana 30 front, Dana 44 rear and the tires I have on the jeep? Also, does anyone have a reason why I should not go with detroit lockers?
gunny40 is offline
post #67 of 103 Old 06-13-2013, 09:35 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
I would do 4.56. That's plenty for a 35
I would not do a Detroit in the rear. It's no fun on a daily driver. Consider a selectable for the rear like an ARB or OX
My builds:
and
or follow us on
spyder6 is offline
post #68 of 103 Old 06-14-2013, 01:17 AM
1222
RIP John
1222's Avatar
Well itís a rare occasion indeed when spyder6 and me agree 100% on something and this is one of them.
Although the detroit locker is a little more user friendly on a long wheelbase vehicle like the JK it still will be annoying on the street plus you will have to adjust your driving habits to counter the way it makes your Jeep handle.
Best to invest in a selectable locker and have the best of both worlds; it will be money well spent.
1222 is offline
post #69 of 103 Old 06-14-2013, 05:55 AM
spyder6
spyder6's Avatar
2010
That said, my running favorite combination of lockers is a Detroit in the front and an ARB in the rear
My builds:
and
or follow us on
spyder6 is offline
post #70 of 103 Old 06-15-2013, 08:11 PM
gunny40
1982 CJ7
Does detroit make a locker that is not a limited slip differential (trutrac). I have been told that they have lockers that are truly open when not engaged and locked when engaged. True they are electronically activated and not air like the ARB, but wondering if they will hold up like ARB? Kinda new to the forum and Jeep community. Loving all the smiles and waves I get from other Jeep wranglers going down the road. It truly is a "JEEP THING".
gunny40 is offline
post #71 of 103 Old 06-15-2013, 08:40 PM
spyder6
spyder6's Avatar
2010
What you're referring to is an Eaton E-locker, which are ok - but no where near as strong as then other options. You also have the genuine Detroit torsion locker, which is an auto locker.
My builds:
and
or follow us on
spyder6 is offline
post #72 of 103 Old 06-15-2013, 09:27 PM
gunny40
1982 CJ7
Thanks for the information. I guess ARB is the way to go. Spend the money once and be done! Sometimes it's better to spend a little extra and be safe with a quality product.
gunny40 is offline
post #73 of 103 Old 06-16-2013, 04:53 AM
Rtone1583
2009 JK Wrangler
Originally Posted by dualtjs View Post
So what these charts are telling us is that the creator of the chart believes that 99.9% of all JK's, with 3.8L motors, were improperly geared when built (I'll leave room for 0.1% to be "properly" geared due to customer orders)? I'm having trouble believing that.
The charts are very, very general.
If you want specific information there is always this site http://www.grimmjeeper.com/gears.html or others like it.
Here http://www.quadratecforum.com/showthread.php?t=109284 you can find all the numbers you need to plug into the above site.
Rtone1583 is offline
post #74 of 103 Old 07-28-2013, 09:34 AM
rock-rocker
Still contemplating
I picked up a 2013 JKU Rubicon 10A which stock it has the Auto Trans with 4:10's in the pumpkins. My wife uses the Jeep for her daily driver (for the time being and she needs a dependable snow driver for the winter) but I live 45 minutes from the Rubicon so I'll be using it for my weekend 'Con runs. I thought my plans were to install 4:88's with 35" tires which I felt the 4:88's would leave enough meat on the gearing because I'm concerned breaking pinions due to the lack of strength/meat left on that kind of tall gearing. After reading this thread I'm on the fence now. Has anyone changed out their gearing to 5:13's and use it for their DD along with good off-roading?? Have any problems?? Any suggestions?? I've had quiet a few 4WD's and I'll have to admit this is the one that is spoiling me the most. Wish they covered more with skid plates the way I drive off-road but we'll fix that. One of the problems I'm having with it is trying to get it away from my wife. At first she wasn't interested in driving it but now... Thanks in advanced.
rock-rocker is offline
post #75 of 103 Old 07-28-2013, 09:38 AM
HappyTrails
HappyTrails's Avatar
Rock-Rocker, I would not worry about the pinion being too small. At 4.88 the pinion is still very thick.
I am running 5.38's and have snapped the rear D44 axle shaft, but the pinion did just fine. Honestly, I have rarely heard of anyone snapping a pinion, even 5.38's. Others may have different stories, though. Usually, it is the axle shaft that goes first. You should be fine with 4.88's, unless you are attacking Moab like a monster truck on Red Bull & Crack.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
3.73 gears , 35" tires , JK Wrangler , power loss , stock gears , wrangler
loss of power... Shinitenshi TJ Wrangler Technical Forum 17 12-30-2007 12:16 AM
Serious power loss shinigami YJ Wrangler Technical Forum 14 09-01-2007 03:29 PM
loss of power echoes TJ Wrangler Technical Forum 11 07-31-2006 06:58 PM
a/c on big power loss KKiowaTJ TJ Wrangler Technical Forum 2 07-30-2006 08:10 PM
4.2L power loss COSourdough YJ Wrangler Technical Forum 11 05-13-2006 04:51 PM
