Potential 2012 Pentastar issue? - Page 9 - JeepForum.com
post #121 of 650 Old 02-23-2012, 03:07 PM
LIJeepJC
Originally Posted by DavidC View Post
auto tranny
Noise at idle and increases in speed with engine rev's while Jeep is sitting still.
Not mine but here's examples
http://www.youtube.com/watch?v=9ifuqSsBivU
http://www.youtube.com/watch?v=2s3GW-2gS-4
Just to clarify... I'm a gear head and have rebuilt a few engines in my day.(even an ol 1952 Dodge M-37 army truck straight 6)
Most definately valve train noise. And it's getting louder.
could be fuel injectors clicking as they use small solenoids that open and close the valves. sounds similar to valve train noise.
LIJeepJC is offline
post #122 of 650 Old 02-23-2012, 03:29 PM
badtux
Originally Posted by DavidJeep View Post
Ball Bearings ? Ah No ! Metal shards that do not go through the oil filter ( remember 80% doesn't )while the engine is operating so that 80% of the oil that is contaminated with the metal ( Aluminum AND STEEL ) can score bearing surfaces AND destroy the hydraulic VVT cam positioners among many other items
Which is why every single engine I've owned over the past 30 years, every single one of which had fine metal particles in the oil that made it past the oil filter (picked up by the magnetic oil plug on the cars I bothered installing those plugs on), disintegrated. Eventually. Like the Honda Civic that eventually disintegrated at 340,000 miles when it threw a piston rod thru the crankcase. Err, yeah .
Aluminum isn't going to score bearing surfaces or hydraulic cam positioners, and nothing that gets through the filter qualifies to be a "shard".
Dog: Man's best friend. Cat: Man's weird reclusive roommate who poops in a box.
badtux is offline
post #123 of 650 Old 02-24-2012, 06:03 AM
DavidJeep
How about we
Well lets make this crystal clear YOUR theory is aluminum is harmless to a engine ? It won't clog a oil passage ? it will not get stuck in a oil filter check valve ? Well I could go on and on so to make this simple why not make a video of you pouring some aluminum directly into your engine ??? if as YOU say it is harmless then put your money where your mouth is ! I also if you bothered to read the whole thread said other dirt foreign to the engine can enter during the replace/rebuild process also the lifters are NOT made of aluminum steel and other metals which can be destroyed while the lifter is banging around the lifter bore If you are going to try to justify your point of view then get the video camera out and start pouring Oh and news flash your magnetic doodads you used on your engines do not pick up aluminum AND your engines that went 300,000 plus miles did NOT bang and rattle at 700 miles either !!!!! Geeeeez
DavidJeep is offline
post #124 of 650 Old 02-24-2012, 06:25 AM
ncb
Nvmnd.
ncb is offline
post #125 of 650 Old 02-24-2012, 12:11 PM
nyrangersfan19
Oil Filter ?? LOL Nice try a oil filter has a micron rating and it will not pick up all of the metal frags Also by the time the oil filter has filtered ALL of the engine oil the damage will already be done ( a oil filter only is filtering about 20% of the oil while the other 80% is lubricating all the conponents during a operating engine) once a oil filter is dirty a check valve inside the oiling systems close to the filter and opens a by pass around the oil filter to ensure proper oil pressure inside the engine
That's just 100% false.
nyrangersfan19 is offline
post #126 of 650 Old 02-24-2012, 12:23 PM
ncb
Not a dirty filter, but a plugged filter will open the bypass.
ncb is offline
post #127 of 650 Old 02-24-2012, 12:24 PM
nyrangersfan19
Plugged completely, yes. Dirty, no.
post #128 of 650 Old 02-24-2012, 10:53 PM
AZBob
In retrospect it should have been obvious that Chyrsler would not be able to build a 280ish HP 3.6 liter V6.
AZBob is offline
post #129 of 650 Old 02-25-2012, 07:16 AM
BadTrainDriver
What??
2012 Jeep Wrangler Unlimited Rubicon
Stock, for now...
BadTrainDriver is offline
post #130 of 650 Old 02-25-2012, 12:02 PM
chrisjsmith4
Did anyone with this issue have a vibration of the engine while at idle? Mine started to vibrate. I can hear it inside the vehicle and when I put my hand on the engine cover it it is very noticable.
Capability wrapped in AWESOMENESS!!!
chrisjsmith4 is offline
post #131 of 650 Old 02-25-2012, 12:59 PM
JSG1518
Question, if the tapping noise was serious would the noise get faster as you accelerate, or rev the engine in neutral?
JSG1518 is offline
post #132 of 650 Old 02-25-2012, 01:48 PM
base704
Poll?
So...
Has anyone, by chance, initiated a poll to come up with some numbers/percentages on how many 2012 Pentastar's have this problem vs. the number of them that don't?
I tried a search, but no luck. Not that I'm a pro on that function...
If not, let's do it.
I'd like to see what my chances look like...
-704
base704 is offline
post #133 of 650 Old 02-25-2012, 02:49 PM
AZBob
Originally Posted by BadTrainDriver View Post
What??
What? What do you mean "what?"
AZBob is offline
post #134 of 650 Old 02-25-2012, 04:11 PM
BadTrainDriver
Sorry.
I should have said, why do you say that?
Please explain.
Stock, for now...
post #135 of 650 Old 02-25-2012, 07:00 PM
Rivet
1968 C101
Yes
Rivet is offline
The definitive 2012 Wrangler 3.6 Pentastar Thread BRICKTOP2 JK Wrangler Technical Forum 189 08-24-2011 11:16 AM
Official!! Pentastar in 2012!! blue-coupe JK Wrangler Technical Forum 92 02-19-2011 12:59 PM
2012 Pentastar Jeep run11rb JK Wrangler Technical Forum 118 02-07-2011 09:41 PM
potential issue????? rlj JK Wrangler Technical Forum 41 03-30-2007 07:38 PM
potential REBB install issue fish4life TJ Wrangler Technical Forum 11 09-08-2006 02:10 AM
