Potential 2012 Pentastar issue? - Page 15 - JeepForum.com
post #211 of 650 Old 03-31-2012, 12:36 AM
6806goats
Originally Posted by 73azbronco View Post
I owned a 2002 BMW M3 that had engines blowing up at about 5000 miles and our website identified the build dates to be in a three month range. We identified that the failure rate was 1000% higher than expected, and resulted in about 25 per 100 motors failing. It took over two years for BMW to come out and admit the problem (bad lower bearings) and fix the motors.
I was all hot to buy a BMW car and a bike until I went to the respective forums. Engine reliability and high maintenance costs took me out of the car/suv aspect (still wonder how a X5 diesel would work out).
Differential problems on the bikes took me off that list. I don't really trust German engineering any more. Fine tech but it's over done to the point that leasing one is the only option and I don't lease. I think the Swiss said it correctly. If it can be built with 1 component, the Germans will use 3.
Kinda limits the field to USA or Japanese.
Retired USN now working in Iraq but home is in SE Idaho. CANCELED First Jeep. 2012 Deep cherry red Rubicon, black dual top and fenders, auto w/ 4.10 gears
Well maybe next year or 2014. Bring us a diesel and we'll talk.
6806goats is offline
post #212 of 650 Old 03-31-2012, 06:50 AM
LIJeepJC
I completely agree regarding the german engineering part. Though I do respect their innovation and technological aspect, they are not very reliable on the every day driver. I've had a number of Jetta's, a Mini, and my sister has had BMW's... and I will say that we all had problems with them. Now i know that every car or truck can and wil have issues, but the problems with these in particular should NOT be happening considering they are not cheap to buy as well as repair. I have a better feeling with American cars and trucks now.
LIJeepJC is offline
post #213 of 650 Old 03-31-2012, 10:40 AM
chrisjsmith4
Back on track please.
Capability wrapped in AWESOMENESS!!!
chrisjsmith4 is offline
post #214 of 650 Old 04-02-2012, 08:11 AM
LIJeepJC
Really? I think this thread is pretty much done considering we know what the cause and fix is.
LIJeepJC is offline
post #215 of 650 Old 04-03-2012, 07:47 AM
AZBob
Don't keep it a secret - tell us!
It looks to me like even Jeep doesn't know what the cause or the fix is.
AZBob is offline
post #216 of 650 Old 04-03-2012, 08:03 AM
LIJeepJC
No secrets here. We're all family. Check out the thread posted a few days ago regarding the tapping noise and fix. Looks as tho the left head is the culprit.
LIJeepJC is offline
post #217 of 650 Old 04-03-2012, 10:11 PM
AZBob
But what about when the right head is the culprit? And what's the cause? And when did they correct the problem, if they have? And what do you do when your dealer says the noise is normal, as many seem to be saying. I think this issue is closer to the beginning than the end.
AZBob is offline
post #218 of 650 Old 04-04-2012, 06:06 AM
LIJeepJC
At this point it's looking like the left cyl head is the problem. Unfortunately it's hit or miss at this point regarding repairs. Dealers are either receptive to the concerns of the customer and knows about the problem, or they tell you the noise is normal. Good luck
LIJeepJC is offline
post #219 of 650 Old 04-04-2012, 07:10 AM
SeaKing
2012 Wrangler Rubicon Light
As per dozens of other posts, I have had multiple check engine lights (MIL). Brand new 2012, 1230 miles, first light last Thursday. Took it to the dealer, they reset it. Drove 9 miles. Next morning, light on again. Dropped it oiff. said code showed an oil sensor switch. Reset wires, reset light. Drove 9 miles light on again. Dealer is clueless and wants to start tesaring the engine down to "inspect" it. Wish I had not gotten rid of my 2006 which went for 6.5 years with only a radiator replacement. I have been sending copies of these forums to the dealer but I think I have a case of head in the sand. Anyone else have the check light problem and a workable solution?
SeaKing is offline
post #220 of 650 Old 04-04-2012, 07:16 AM
LIJeepJC
If this is "just" a light pointing to an oil sensor, REPLACE the sensor. This is fustrating, but at this point at least you are not dealing with the tapping noise.
LIJeepJC is offline
post #221 of 650 Old 04-04-2012, 07:32 AM
SeaKing
Oil Pump
dealer is saying the code indicates a problem with either the two stage oil pump or the oil injector nozzles that spray onto the cylinder. Supposedly another 2012 had this here in Newport News and that fixed it. We'll see but I'm not feeling the love here. Perhaps too much pessimism as a helicopter pilot who alwyas fears the worst. Just hope te dealer actually knows what they are doing because so far they have been grasping. Anyone else out there had this problem/fix?.
SeaKing is offline
post #222 of 650 Old 04-04-2012, 07:44 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
SeaKing -
did they mention the specific code - the number?
JeepCares is online now
post #223 of 650 Old 04-04-2012, 08:32 AM
AZBob
I've seen reports of right side, or both sides, and of course the cylinder number 2 problem is right side. It certainly looks to me like there's multiple issues here, which is why I objected to the declaration that the mystery was solved and over.
AZBob is offline
post #224 of 650 Old 04-04-2012, 10:10 AM
LIJeepJC
I see what you are saying. Let me ask you, are the heads interchangable? In other words, are their orientations to them; left and right? Or can do they fit either side?
LIJeepJC is offline
post #225 of 650 Old 04-04-2012, 01:44 PM
TheBoss
This is an overhead cam engine so I would have to say the castings are different.
TheBoss is offline
The definitive 2012 Wrangler 3.6 Pentastar Thread BRICKTOP2 JK Wrangler Technical Forum 189 08-24-2011 11:16 AM
Official!! Pentastar in 2012!! blue-coupe JK Wrangler Technical Forum 92 02-19-2011 12:59 PM
2012 Pentastar Jeep run11rb JK Wrangler Technical Forum 118 02-07-2011 09:41 PM
potential issue????? rlj JK Wrangler Technical Forum 41 03-30-2007 07:38 PM
potential REBB install issue fish4life TJ Wrangler Technical Forum 11 09-08-2006 02:10 AM
