is it possible to adjust the speedometer for bigger tires? - JeepForum.com
post #1 of 13 Old 12-21-2009, 04:19 AM Thread Starter
mudman1
i read when you put on bigger tires, the speedometer will be inaccurate.
is it possible to have the speedometer adjusted? if so, could myself or the average mechanic do this? and how much would it cost? the jeep is a 2007 wrangler.
also, when the speedometer is inaccurate, does it create inaccurate mileage for the car too? or is just the speedometer incorrect? if the odometer would be incorrect too, is there a way to adjust both the speedometer and odometer?
thanks
mudman1 is offline
post #2 of 13 Old 12-21-2009, 04:46 AM Thread Starter
mudman1
i think i found the answers here:
Changing Your Jeep Speedometer Gear
but i have a new question. how do i find out my "R&P"? that info + new tire size is needed to find out which new speedometer gear i need.
and what does "R&P" stand for?
thanks
mudman1 is offline
post #3 of 13 Old 12-21-2009, 05:28 AM
SETXWarrior
Your JK does not use the gear, it's electronic and needs to be re-programmed.
There are several brands that provide different levels of functionality and priced accordingly.
I used the Pro Comp Accu Pro that only corrects tire size and gear ratio, and was less than $200. Other types are made by SuperChips and AEV.
Yes, your odometer will be off until it is re-programmed.
SETXWarrior is offline
post #4 of 13 Old 12-21-2009, 06:26 AM
TurtleSlinger
2009 JK Wrangler
I used the AEV procal. Think it was $130. That did the trick for me and also fixed a couple other issues. Great tool to have for tire size and many other things.
Check it out!
American Expedition Vehicles - Wrangler ProCal Module - Additional Vehicle Features and Calibration Tool
Current stable:
09 JK Rubicon 35's and 5" lift - modded
09 WK Limited 5.7 Hemi OVERLAND - stock
07 MB AMG E63 "My 11 sec sedan" - modded
11 HD NightRod Special - modded
TurtleSlinger is offline
post #5 of 13 Old 12-21-2009, 07:26 AM
twobit
What year did they stop using the gear and switch to eletronic? I have a 2006 TJ with six speed transmission.
06 Solar Yellow TJ X obtained 10-2009 with 3400 miles
99 Cherokee Sport, bought new, now @ 223,000 miles
Southwest Texas
twobit is offline
post #6 of 13 Old 12-21-2009, 08:20 AM
Seanie
thanks
It depends on the size of the wheels as well. If they are 32 inches or smaller, the dealer can do it for like 50 bucks, but if they're over 32's, it'd probably be better just to order something to do it yourself.
Don't drink the water, there's blood in the water... DMB
Seanie is offline
post #7 of 13 Old 12-21-2009, 09:37 AM
Scooter_Trash
Why would that matter? It's a computer. If they can adjust for 32's they should be able to do 33's, 35's, even 40's.
Scooter_Trash is offline
post #8 of 13 Old 12-21-2009, 10:52 AM
DeepSky
From what I understand the dealer's equipment (whether software or hardware) limits them at 32" because that is the largest tire that comes on the Wranglers from the factory.
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way.
2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(
DeepSky is offline
post #9 of 13 Old 12-21-2009, 11:45 AM
jeepinmichguy_
you have no life
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
post #10 of 13 Old 12-21-2009, 02:07 PM
DeepSky
Originally Posted by jeepinmichguy View Post
you have no life
haha, looks whose talkin! Plus, I've been busy today...for the most part...
DeepSky is offline
post #11 of 13 Old 12-21-2009, 02:11 PM
Liquor
BOUNTY HUNTER
Liquor's Avatar
2008 XK Commander
AEV procal worked for my regear and 39" tires. also recalibrated the steering for dead center so the ESP didnt go crazy. i recommend it since it was easy to do, quick, and 0 issues with my build.
5.5" RK coil over, 5.13 gears, 39" tires. on stock v6 and 6 speed.
2007 Unlimited Sahara Steel Blue - I call it "CAIN"
2002 TJ Sport - Sold
"CAIN" '07 Jeep JK 426 HEMI 685 HP & 650 ft lbs
Your Jeep and Gaming Social Network
2012 Sponsors:
Magazine Feature:
Liquor is offline
post #12 of 13 Old 12-21-2009, 02:14 PM
md41969
The odometer will be off as well as the speedometer when you add larger tires. As mentioned above you will need an aftermarket programer in order to change the tire size in the computer with anything larger than a 32. I went the AEV Procal route, only 129 and worked very well. R&P is ring and pinion which refers to your gear ratio. Depending on the model/options you have it will be 4.10, 3.73 or 3.21 I believe.
Current:
2008 Rubicon Unlimited
Sold:
1995 Wrangler
White Jeep Club Member #81
Originally Posted by FourbyFour View Post
"....you know what hurts the most, it's the lack of respect, that hurts the most.....and, and the the other thing hurts too, BUT not as much as the lack of respect..disgusting.."
Originally Posted by Rob99 View Post
Your dog's head doesn't look like it belongs on his body. Is it an aftermarket head?
md41969 is offline
post #13 of 13 Old 12-21-2009, 04:22 PM
jeepinmichguy_
not me 10 char
ΜΟΛΩΝ ΛΑΒΕ
Bigger tire-mileage/speedometer? ZeroGravity YJ Wrangler Technical Forum 38 09-15-2014 06:47 AM
Bigger tires, no spedo adjust, true mileage math problem bigred33 Wrangler General Discussion 12 07-15-2009 07:12 AM
new bigger tires/wheels, do i need to adjust anything? chrisjep97 TJ Wrangler Technical Forum 5 07-26-2008 07:32 PM
Bigger tires...what piece do I need to correct my speedometer? 05 Rocky Mounta TJ Wrangler Technical Forum 11 02-21-2007 08:00 AM
31" Tires, how do I adjust the speedometer? rockon1202 TJ Wrangler Technical Forum 7 06-14-2004 03:35 PM
