Port and Polish Throttle Body? - JeepForum.com
post #1 of 24 Old 12-22-2010, 11:15 AM Thread Starter
run11rb
2011 JK Wrangler
like the title says... Has anyone tried to port and polish their TB? Or do you know anyone that has and what was the result? Similar to this http://www.ehow.com/how_4553230_port...ttle-body.html
I guess we dont have MAF so sorry about that.
run11rb is offline
post #2 of 24 Old 12-22-2010, 11:28 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
I think I read on another forum someone who had this done and they said they felt a bit lighter in the right hip pocket...yeah, that was it, lighter in the pocket.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 24 Old 12-22-2010, 11:36 AM
ronjenx
ronjenx's Avatar
What exactly do you mean by MAF?
The JK doesn't have a MAF sensor.
ronjenx is offline
post #4 of 24 Old 12-22-2010, 11:44 AM Thread Starter
run11rb
2011 JK Wrangler
O sorry i didnt know we didnt have MAF for some reason i just assumed it did.
run11rb is offline
post #5 of 24 Old 12-22-2010, 11:56 AM
RockyClymer
RedRock4Wheeler
What I am trying to say is that without a complete update of the "system" that just improving one part will not help - ie. one would need to improve air getting into the engine, through the engine and out of the engine. I think, from what I have read, you would be better off investing in a Superchip to tweak your engine tune, than all the rest of the stuff.
NRA Life member
post #6 of 24 Old 12-22-2010, 12:28 PM
Prot
Prot's Avatar
2014 JK Wrangler
Best bang for the buck as for as performance goes in my opinion is regearing the differentials, especially if you have an automatic.
There isn't a whole lot to be gained out of the 3.8L except for supercharging.
Flashpaq will get a little more power, but will give noticable improvement in throttle response, which is of course difficult to actually measure, but it's been accepted as one of those it feels better improvements.
There have actually been reports of decreased performance by the addition of some mods that were supposed to improve. I think that had a lot to do with bad combinations. The one that stands out most in my mind was substantially reduced torque with certain headers combined with something else. I just know I don't feel the need to spend money on something that makes an already marginal engine even worse.
Regearing will run about $1,200 -$1,300 and fixes most of what is wrong and is not detrimental.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #7 of 24 Old 12-22-2010, 01:06 PM
ronjenx
ronjenx's Avatar
This is the sum total of my thoughts on why regearing is the best way to get better performance out of the 3.8: (Each section came out of different sessions of sitting and thinking; once in a while, I just sit, though.)
Regearing doesn't ADD power. It allows the engine to put out more of its available horse power.
An engine turning 2200 rpm can make more hp than the same engine turning 1100 rpm.
Another way to look at it:
V6
Automatic in 3rd (1:1)
6 speed in 5th (1:1)
If rear axle = 2:1
You get 6 power strokes per tire revolution.
Change the rear axle to 4:1,
You get 12 power strokes per tire revolution, which feels like a bigger engine. You would go up the hill slower, (at the same rpm), but you could haul a larger load up that hill.
This may be over simplified, but regearing may in fact be nearly equal to going from a 3.8 V6 to a 5.0 V8.
V6 to V8 = a 33.33% gain in the number of engine power strokes for a given distance traveled.
4.10 to 5.46 (not an available ratio, but ok for this illustration) = a 33.33% gain in the number of engine power strokes for the same distance traveled.
I did some figuring, using the hp/torque charts at the Hypertech site. Those charts show numbers at the wheels.
These are with O/D off for simplicity, because the 4.7L chart, rpm scale didn't go low enough.
3.8L: 31" tires, 4.10 gears, 70 mph, = 3111 rpm @ 107 hp + 188 ft/lbs.
4.7L: 31" tires, 4.10 gears, 70 mph, = 3111 rpm @ 129 hp + 219 ft/lbs.
3.8L: 31" tires, 4.88 gears, 70 mph, = 3702 rpm @ 135 hp + 195 ft/lbs.
This is very unscientific, but, as you can see, regearing can be very similar to going to a V8.
ronjenx is offline
post #8 of 24 Old 12-22-2010, 03:07 PM
JTPhoto
JTPhoto's Avatar
For $136 you can put a 08 Viper TB on there pretty much plug and play. Air intake adapter and a line elbow is all thats required. Puts you from a 58mm bore to a 74mm. Of course running a programmable tuner will help you reap the most benefit from this. This will work better then any polishing.
Personally, up here in the cold I found a great benefit in running 91 octane rather then 87. Better performance and gas mileage..
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #9 of 24 Old 12-22-2010, 10:20 PM
Prot
Prot's Avatar
2014 JK Wrangler
Any dyno data showing the results of this? For some reason I am skeptical of the benefit of this.
Prot is offline
post #10 of 24 Old 12-23-2010, 12:02 AM
5-90
5-90's Avatar
1988 XJ Cherokee
Originally Posted by run11rb View Post
like the title says... Has anyone tried to port and polish their TB? Or do you know anyone that has and what was the result? Similar to this How to Port and Polish Throttle Body | eHow.com
You had me worried there - I thought that the silly Ford MAF idea had caught on at ChryCo and replaced the speed/density setup!
"Port and polish" should really be restricted to head ports and possibly intake runners. You're not going to get anything out of doing the TB - and if you screw up and open the bore up, you're going to have to get a new butterfly to fit (and probably take it in to have the bore trued so the butterfly works.) The ECU will pitch a b**** if the throttle valve can't close all the way - idle air is supposed to go just about entirely through the IAC passage.
As far as perceived performance benefits - they're right, you'll note an increase in pep from having a lighter wallet. Putting on a bored throttle body doesn't even improve performance - it improves part-throttle response, but doesn't actually do anything for power output. Ergo, the old "butt dyno" gets confused. (The OEM throttle body is perfectly capable of supporting airflow for even a mid-grade stroker - say, 285ci or so - without any trouble.)
Leave it alone, and put your nickels in a jar until you have enough to get a CAI kit - that will have more effect.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #11 of 24 Old 12-23-2010, 08:19 AM
JTPhoto
JTPhoto's Avatar
Prob is the factory air system works good enough that even a aftermarket CAI really has no benefit.
Here is a lengthy discussion on the Viper Throttle body. VIPER THROTTLE BODIES FOR JK's - JkOwners.com - The Community for Jeep JK 4x4 Owners Dyno tests are likely to come shortly as there are many folks switching over. It must be noted that a programmer and proper tune must be used to get full benefit of the TB otherwise the factory ECU will control it as stock and only increased throttle response will be noticed.
The Supercharger is still by far the best performance increase.
^^Jeff^^
JTPhoto is offline
post #12 of 24 Old 12-23-2010, 09:30 AM
Prot
Prot's Avatar
2014 JK Wrangler
I just read through seven pages of b.s. which was mostly guys arguing and not one dyno chart, horsepower figure, torque number, or anything tangible showing the benefit of that throttle body was posted. Furthermore, that us the same throttle body used on a Commander as well as another unsexy vehicle. Using the Viper name makes it sell better, but it's the same damn throttle body on more mundane vehicles.
Repeatedly what was said in summation is buy it because it is better and when asked why, the answer was repeatedly it just is. Granted $136 isn't a lot if money for an upgrade these days, but at least a better answer should be given than what has been. They might as well have said paint your jeep pink because it will make it more powerful. Just do it because it's a fact and we don't need to prove anything. BTW we are having a sale on pink paint. The color is Viper Pink, which we all know Vipers have the fastest colors.
You know, I really want to believe this will help, but seven pages of asking for numbers and none being provided sounds like b.s. to me.
Prot is offline
post #13 of 24 Old 12-23-2010, 10:09 AM
Ravik
2010 JK Wrangler
Well, I just bought one... Like ya said, $140 is pretty cheap - that and the $50 in 3" intake parts falls into my 'experimental' budget for next year.
The programmer is another $300 - I'm kicking that around as I type... Been wanting one since I bought the Jeep just to take out the throttle lag.
I've got a bunch of data from some timed runs up Floyd Hill here in CO... Things like time to point, rpm at point, speed at point, air temp, etc. While it won't be a true dyno, I can probably state with some certainty if the ECU in the JK understands that there is more air available and therefore more fuel is needed - and therefore more power is being made.
The thing I worry about is the ECU not figuring out the 16mm bigger hole and running the engine lean.
If I get the tuner I'll have to do a few runs with just the TB, and then the tuner just to see which is making what difference.
And, if it doesn't work, putting the old TB back on isn't exactly 'hard'.
2010 2dr Rubicon
Ravik is offline
post #14 of 24 Old 12-23-2010, 10:38 AM
Prot
Prot's Avatar
2014 JK Wrangler
Funny thing is, I was reading about this and posting in this thread while at the dealer getting the brake recall done. That is all I wanted done. The service manager comes up to me later and tells me my throttle body has a lot of carbon build up and needs to be cleaned. I have no idea why they would be messing with my throttle body, but whatever. I ask him how much to have it taken care of. He says $107. Now I am thinking I could buy a lbrand new larger one for only $20 more. Needless to say I told him no and that I would do it myself instead.
Prot is offline
post #15 of 24 Old 12-23-2010, 10:50 AM
muttytruckster
Excelent question as why they were in there when you were in for the recall.
I too had carbon build up on the back side of the butterfly valve found inside the throttle body. They also said it would cost something like that, so I had the mechanic show me how they would go about cleaning it, and then took it home and did it myself. Little Seafoam, no problem all clean.
2007 Jeep Wrangler Unlimited Rubicon -JKUR
Rescue Green 6-Spd, 33" KM2s- 17 x 8 BlackRock Series 909 wheels, Stainless Steel Gibson Exhaust & AFE Air Intake, Superchips, Aberle Front Bumper&10.5K Winch, PiAA ATP Lights
muttytruckster is offline
JK Wrangler , polishing , porting , spacer , throttle body , wrangler
How Do You Remove the Throttle Cable to the Throttle Body? JustChillin TJ Wrangler Technical Forum 3 10-23-2010 01:52 PM
Port and polish cylinder head Pitbullcustoms YJ Wrangler Technical Forum 3 09-09-2009 07:44 PM
throttle body and throttle body spacer laxin15 TJ Wrangler Technical Forum 11 08-24-2009 02:47 PM
throttle cables on throttle body eep3 TJ Wrangler Technical Forum 6 10-03-2005 04:03 PM
port and polish irontj04x TJ Wrangler Technical Forum 7 01-28-2005 09:42 AM
