Popping noise under jeep - JeepForum.com
post #1 of 15 Old 10-10-2011, 03:57 PM Thread Starter
Jeremijdt
I have a popping sound under the rear of my 2007 JK. It only happens when I take off from a dead stop but not all the time. I have checked the rear pads to make sure they are not sticking. The Jeep is all stock with 95,000 miles now. Has anyone else run into this problem? Calipers? Any thoughts would be great.
Jeremijdt is offline
post #2 of 15 Old 10-10-2011, 05:24 PM
jmb6420
Engr. & Mechanic 08 Rubi
jmb6420's Avatar
With 95K miles, have you replaced your shocks? That would be the first place I looked. Check and make sure your trackbars and control arms are tight.
Mike
08 Rubicon
"You can't fix stupid" Ron White
ɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
jmb6420 is offline
post #3 of 15 Old 10-10-2011, 06:38 PM
oldballz
oldballz's Avatar
2011 JK Wrangler
Maybe you should check out your rear drive shaft as well look for a rotting, cracked CV boot. I'm no expert but I've heard quite a few cars with bad CV axles that pop under load I'm wondering if this is the noise you're hearing.
oldballz is offline
post #4 of 15 Old 10-10-2011, 08:59 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Do you have the limited slip differential?
I had a pop sound that I believe was the l.s.d. unlocking or locking when starting from a dead stop. It didn't happen all the time and have never heard a sound since changing to a selectable locker.
Check all of the suspension components but if it is the l.s.d. there is really nothing you can do other than practice driving the way you do when it doesn't make the noise
Jim
JLC08JK is offline
post #5 of 15 Old 10-10-2011, 09:20 PM
1222
RIP John
1222's Avatar
Another thing to look at is the rear springs. Depending on how much droop you have the bottom of the spring can come separated from the axle side spring pad and the not seat correctly. It happened to me a couple of times and it would make a popping sound too.
1222 is offline
post #6 of 15 Old 10-10-2011, 09:39 PM
Prot
Prot's Avatar
2014 JK Wrangler
Look at your control arms.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #7 of 15 Old 10-12-2011, 05:27 PM
ckaffer85
I have an 09 with 21000 miles on it doing the same thing it's not a constant as in it happening every time but it does happen frequently.
ckaffer85 is offline
post #8 of 15 Old 10-12-2011, 05:49 PM
1AAdam
love the psycho avatar above!! i was thinking shocks too. check the bushings and see if they are worn also.
Adam
1aauto.com
888-844-3393
1AAdam is offline
post #9 of 15 Old 10-12-2011, 05:53 PM
MGDWJ
X2 on the rear drive shaft. Ours started doing that and a few weeks later it went out. I took it off and drove it in 4wd until the upgrade came in. Ours also has a 4" lift so we had to get adjustable upper control arms to eliminate driveline vibs.
MGDWJ is offline
post #10 of 15 Old 10-12-2011, 06:11 PM
WXman
I had popping in my KJ rear end with Trac-Lok. Turned out it was because I used synthetic gear oil. Switched to cheap regular dino oil and the noise went away.
Also check your brake shoes. If the friction material separates from the shoe it'll knock around in there after you sit still for a minute or two.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #11 of 15 Old 10-12-2011, 08:01 PM
Jeeprin
I was thinking the same. I had a Detroit TT LSD installed in my front Diff when I re-geared and I have the same sound. I have just learned to expect it. In my opinion it is well worth it when it matters, so the noise is not too troubling on the road.
08" X, 2DR, Jeep Green, RIPP Gen II Supercharger, Custom painted graphite MB Stryker 16" wheels, 35" Dura-Tracs, flat fenders, XRC Front bumper w/ XRC 8 winch, Superchips Flashpaq, Safari Straps, OME/ARB MD coils, Bilstein 5100's, JKS front and rear track bars, Superior 5.13 gears, Detroit True Trac LSD, A to Z Fab Rock Sliders
Jeeprin is offline
post #12 of 15 Old 10-13-2011, 09:55 AM
ckaffer85
Mine will be going into the shop this weekend I'll keep you all posted on what is found
post #13 of 15 Old 11-24-2013, 08:25 PM
Jackie66
Popping Noise
Let me Know what you find out CKaffer85!
Jackie66 is offline
post #14 of 15 Old 11-24-2013, 08:29 PM
Jeremy7
Popping Noise
Jeremy7 is offline
post #15 of 15 Old 11-25-2013, 05:32 PM
COLOUXJ
2010 JK Wrangler
That post was from 2 years ago. I think its fixed now...
COLOUXJ is offline
popping noise
1994 Jeep YJ Popping noise in Reverse? 1994JeepMan YJ Wrangler Technical Forum 6 01-05-2011 08:09 PM
Jeep Stalls and makes Popping noise xloza TJ Wrangler Technical Forum 1 09-27-2010 10:57 PM
Popping noise from rear of jeep BlackOpsJeep TJ Wrangler Technical Forum 2 09-23-2006 12:57 PM
the popping noise on my jeep is driving me insane incubus2012 TJ Wrangler Technical Forum 1 06-08-2004 03:32 PM
Popping noise from Rear of Jeep Mr Ouija TJ Wrangler Technical Forum 16 11-24-2002 09:49 PM
