Please help me get to 70 mph on the Hwy- - JeepForum.com
post #1 of 22 Old 05-21-2010, 01:38 PM Thread Starter
carcam
or at least keep me there.
Just put a 2.5" RC lift and 35" BFG AT's on a 2010 Rubicon. It looks amazing and rides surprisingly well. I have a 3 hr hwy drive I have to do occasionally and it's no problem at 65mph- speedo reads 60 but it's actually 65. But at 70mph, it's a struggle and wants to downshift at the slightest headwind or small hill. At 65, I'm getting 16.5 mpg but at 70 it drops to 14.
I knew the lift and bigger tires would have trade-offs and expected some of this. It's actually better than I thought around town. But I would sure like to be able to cruise just a little bit faster on the highway without the big drop in mpg or constant downshifting.
Any ideas? I tried a Superflow muffler but had to take it off- not a pleasant sound, drone at 2k rpm and the reduced back-pressure decreased the low end torque so it was noticeable slower around town.
I'm thinking I may have to change the gear ratio from 4.10 to 4.56's. That would take care of the gear ratio difference but may not help with the extra weight of the 35" tires which must be a big strain on the little 3.8L. Anyone tried this- couldn't find it in a search. The adds for Superchip and maybe a cold air intake sound like a possible solution to pick up enough HP to get me to 70 comfortably but I've heard mixed results and there's the hassle of re-flashing when taking it back to the dealer for warranty work.
Short of an AEV Hemi conversion, I may be stuck in the slow lane forever unless you have some ideas. Thanks for any thoughts.
carcam is offline
post #2 of 22 Old 05-21-2010, 01:53 PM
toyota4x405
Put in the new gears and you won't have any problem. Cold air won;t do anything. It is hard to get any HP out the minivan engines. Just change gears and go.
Green Jeep Club Member #254
2007 Jeep Wrangler Unlimited, Jeep Green
Originally Posted by GonzoTJ View Post
'REAL Jeepers don`t cry about other Jeepers not waving at them!'
toyota4x405 is offline
post #3 of 22 Old 05-21-2010, 02:02 PM
ncb
New gears and program computer so the shift points and tire size are correct.
ncb is offline
post #4 of 22 Old 05-21-2010, 02:18 PM
owtdorz
2009 JK Wrangler
How many miles are on it?
I have a 4dr Rubi 35s and loaded down and have no problems reaching 85-90.
No performance mods!
Drive it like you stole it so the computer adjusts to driving style and is past 2000-2500 miles.
The PCM is detuned until then.
'09 Detonator Yellow 4dr Rubi, Bestop Element doors, Rugged Ridge XHD w/stinger, Warn 9.5ti, 3.5 Rock Krawler, Woods driveshafts, Hella 500 aux lights, 35x12.5x17 BFG KM2<< THEY SUCK
owtdorz is offline
post #5 of 22 Old 05-21-2010, 02:22 PM
RMiksits
you have 5.13 gears that helps a lot bud.
RMiksits is offline
post #6 of 22 Old 05-21-2010, 02:25 PM
owtdorz
2009 JK Wrangler
They are still in my garage.
I am still running 4:10s
owtdorz is offline
post #7 of 22 Old 05-21-2010, 03:12 PM
DeepSky
carcam:
Expensive but Perfect Solution - Regear to 5.13-5.38 + AEV ProCal to calibrate shift points and gear ratio
Cheaper but Less Effective Solution - AEV ProCal to calibrate shift points + occasional use of the O/D off button
I've personally run 35"s with 4.10s and an automatic transmission (plus hundreds of pounds of add-ons) for over 35,000 miles now and I'm only planning on regearing if $1200 bucks lands in my lap. Granted I live in FL where there isn't a whole lot of hills but the hills I do drive (e.g. bridges) are overcome by turning off OverDrive.
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way.
2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(
DeepSky is offline
post #8 of 22 Old 05-21-2010, 03:23 PM Thread Starter
carcam
Sounds like some new gears are in my future and maybe a computer re-program. Makes more sense than engine mods (on a minivan engine? never heard that but makes sense). Thanks a lot for the tips!
carcam is offline
post #9 of 22 Old 05-21-2010, 03:30 PM
Colockum
Get on a looong down hill...
Don't go with the Cold Air Intakes, the really don't do anything especally for the price. Check out this thread http://www.jeepforum.com/forum/f9/fa...intake-558437/
Colockum is offline
post #10 of 22 Old 05-21-2010, 03:32 PM
N2rock
N2rock's Avatar
I know your pain. My X had 4.10's, and I ran 35's with the 4.10's for a year. It wasn't bad around town. But on the highway at 70mph, it was in and out of OD so much it was annoying. Any little incline or wind and it had to drop out of OD. And the cruise control was completely useless.
I have 5.13's now, and it is much better. It will hold 70+ with cruise control no problem, even on most hills.
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #11 of 22 Old 05-21-2010, 03:40 PM Thread Starter
carcam
N2 Rock- why 5.13's and not 4.56's which is what would take it back to stock?
carcam is offline
post #12 of 22 Old 05-21-2010, 03:56 PM
N2rock
N2rock's Avatar
Honestly- I felt the 4.10 with stock 32's was barely adequate. Even with the stock setup, it still had a lot of downshifting. Going up to 4.56 is such a small change, it wouldn't be worth the expense. I had a friend that went to 4.88's and he felt it still was not enough gear.
In the various JK forums, the general consensus amongst all owners that have regeared, is that 4.88 for manual, and 5.13's for auto is ideal for running 35" tires.
So with all that, I opted to go with 5.13's. And the performance is where I feel it should be. Gas mileage is the only negative. I get the same mileage around town, and about 2-3mpg less (than stock) on the highway.
N2rock is offline
post #13 of 22 Old 05-21-2010, 05:51 PM
1222
RIP John
1222's Avatar
You need to re-gear. There is no debate. As soon as you added larger tires you also changed you your final drive ratio. If I were you I would listen to what the vast majority on this forum and the other forum are saying and go with 4:88ís for your manual trans.
(2011-2016)
1222 is offline
post #14 of 22 Old 05-22-2010, 09:49 AM Thread Starter
carcam
Re-gear it is- thanks for all the advice!
carcam is offline
post #15 of 22 Old 05-22-2010, 03:53 PM Thread Starter
carcam
OK- so I'm going to put in 5.13's. Is this something I can do myself? How involved is it- special lubes, gaskets, etc. I'm assuming it has to be front and back. It's got to be easier than the lift with spring compressors. I have a lift, tools, some basic mechanical ability- not like most of you (day job is a root canal guy). Should I send it out? Do like getting my hands greasy (when it turns out). Any advice is appreciated.
carcam is offline
