Please Help - JeepForum.com
post #1 of 9 Old 08-13-2015, 09:16 PM Thread Starter
yungjk
2011 JK Wrangler
Please Help
So I got some angry eyes for my jeep that are stuck to the body with some 3m type tape. I no longer want them and have no clue how to get them off, I've tried pulling them off, prying them off, using a razor blade to cut the adhesive off... nothing works. Please help me
yungjk is offline
post #2 of 9 Old 08-13-2015, 09:29 PM
1222
RIP John
1222's Avatar
How about a heat gun or hair dryer to soften up the sticky stuff?
(2011-2016)
1222 is offline
post #3 of 9 Old 08-13-2015, 09:37 PM
ronjenx
ronjenx's Avatar
Is it something you can pull floss under to cut the glue?
2008 JKU Rubicon
42RLE Auto
ronjenx is offline
post #4 of 9 Old 08-13-2015, 09:59 PM Thread Starter
yungjk
2011 JK Wrangler
Thank you both for your quick responses... those are good ideas i never thought of trying. thanks
yungjk is offline
post #5 of 9 Old 08-14-2015, 10:30 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
I kinda want the back story of how they got from the venders hand to needing to be unbonded ...
I think the ring will absorb too much heat to soften the bond at the body but try it - floss is step two, use acetone or "goo gone" to remove adhesive remaining.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #6 of 9 Old 08-14-2015, 12:05 PM
1222
RIP John
1222's Avatar
Won’t acetone hurt the paint or clear coat? I know goo b gone doesn’t but it seems like acetone would.
(2011-2016)
1222 is offline
post #7 of 9 Old 08-14-2015, 01:15 PM
YATZI1980
2011 JK Wrangler
Regular old alcohol isopropyl will cut through the glue also
YATZI1980 is offline
post #8 of 9 Old 08-15-2015, 09:16 AM Thread Starter
yungjk
2011 JK Wrangler
I was able to finally get them off... Used the floss to loosen them up, then a flat head to pry it up enough to get my hand behind it cut the remaining adhesive with a knife. All thats left is to get rid of the adhesive with goo be gone.
yungjk is offline
post #9 of 9 Old 08-15-2015, 09:27 AM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Acetone evaporates real fast - so simply work with small spots and move quick - it wont stay behind and continue to solvent work. I have not seen it damage any of the clear coats I have messed with. That said I wax heavily on em when fresh... so my problems are more along the lines of getting stuff to stay on - not come off...
