Play tunes off my android phone +/- hands free phone support - JeepForum.com
post #1 of 11 Old 05-01-2013, 01:41 PM Thread Starter
tturkstra
My search came up empty.
I just got a new android phone with enough memory to hold my entire music library. Unfortunately, my radio won't pair to phones since when I press the button, I get an error that the uconnect is not installed.
The dealer says they can install uconnect for $600, but that will just be for phone calling. An add-on is available to play from your iPhone, but not my Android. The half dozen threads on the subject don't clarify if the add-on uconnect is just for handsfree will allow music access as well.
Is there any aftermarket widget that will pair with a bluetooth phone and broadcast to the radio over FM? I assume that would also mute the music when talking on the phone. I'd rather not swap out my entire head unit and make it attractive to break into my jeep.
I'd be willing to use the aux-in jack, but the connector on the radio isn't great and introduces static, whateve sourse I use.
Thanks, Tim
08 JK unlimited Yellow
"When all is said and done, it seems a lot more gets said than done."
tturkstra is offline
post #2 of 11 Old 05-01-2013, 04:00 PM
maniacal_rick
Do a search on Crutchfield.com for bluetooth enabled radios for music playback. You should be able to pick one up cheap (<$200).
2012 2Dr JK - Metalcloak - Currie - Prorock - ARB - Poison Spyder - RCV - Synergy - Etc...
maniacal_rick is offline
post #3 of 11 Old 05-01-2013, 04:34 PM
toxicwaste29
I have u connect and can play Bluetooth off my droid hands free including switching songs but the speakers seem to crackle when this happens. If you plug in with an aux into the radio, the crackling goes away and the sound it better however you lose the ability to change songs with the radio or steering wheel controls, you have to change using your phone.
toxicwaste29 is offline
post #4 of 11 Old 05-01-2013, 08:10 PM
thebgkoolio
I use uconnect to stream music from my droid razr with no problems. Sound quality is decent. But since mine is a 2013 it may only be an option on the newer jeep radios. IDK. Probably the cheapest option would be an aftermarket radio. It will still run you a couple hundred but will be cheaper than buying a upgraded factory radio.
13 JKU -33's, afe exhaust, more to come
Sold: 94 zj -3.5" on 31's, bunch of other mods.
thebgkoolio is offline
post #5 of 11 Old 05-02-2013, 06:00 AM
cyberpyrot
Samsung Note 2 the soud quality is amazing it streams directly from the device. One thing to remember Plug the device into power my internal amp ont the phone cuts in half when using the line in this does not happen when streamin blue tooth.
I have attention defiiiii hey is that a rabbit?
Thought of the day
Trust people who like big butts they cannot lie...
cyberpyrot is offline
post #6 of 11 Old 05-02-2013, 06:19 AM
Grimscale
2011 JK Wrangler
I've tried streaming from my Droid Razr as well as from a Samsung Galaxy 2. The sound isn't bad...but it only comes out from the front speakers.
Any ideas how to make it use the whole sound system?
Grimscale is offline
post #7 of 11 Old 05-02-2013, 04:34 PM
joedaman1999
HTC bluetooth adapter
I belive you are looking for this
joedaman1999 is offline
post #8 of 11 Old 05-02-2013, 06:08 PM
CoriolisSTORM
WHAT?!
CoriolisSTORM's Avatar
2010 JK Wrangler
If your '08 model has MyGig, no matter if it has bluetooth or not, '11s and onwards are capable of A2DP, the bluetooth standard for streaming audio. '07s through 10's are not, otherwise this would be simpler for you and me. You can probably find another line in kit from crutchfield and use it. It is much harder to find radios compatible with android phones. (probably due to no manufacturers caring to have to figure out how to make it work with the monstrous amounts of them that exist. Not flaming, I love my Note 1 and Atrix before it)
1998 TJ Wrangler SE - Stone White, 2.5Ls of screaming lifter clacking power, AX5, 31" BFGoodrich All Terrain T/A KOs
2010 Wrangler Unlimited Sahara - Deep Water Blue, 3.8Ls of oil consuming fury, NSG-370, BFGoodrich Rugged Terrain T/A 265/70/R18s
CoriolisSTORM is offline
post #9 of 11 Old 05-04-2013, 06:36 PM
Firejoe2006
2011 JK Wrangler
Hey guys I'm on the process of buying a 2011 wrangler unlimited and was wondering if I should have them install a uconnect while its at the dealership. Any thoughts?
Firejoe2006 is offline
post #10 of 11 Old 05-05-2013, 07:41 AM
rirrgang
I use an external Bluetooth device plugged in the aux input on my 07 with nav and uconnect. I got it on eBay for around $25.00
I can stream from my ipod or my HTC Inspire phone. Both will pause if a call comes in.
Normally I have phone connected to MyGig and the ipod connected to the external bluetooth plugged in to the aux input
-Rick
07 Sahara Unlimited
rirrgang is offline
post #11 of 11 Old 05-07-2013, 06:35 AM
xsdbs
I would suggest it. Using hands free for making and receiving calls without having to have your phone in the hand is great and lets you keep your eyes on the road. Not to mention the ability to stream you audio files from the phone to thru the stereo. Also driver distraction laws are becoming stricter and in some areas you can get a ticket for using the phone itself.
xsdbs is offline
