Plastic slider - JeepForum.com
post #1 of 2 Old 04-01-2013, 02:46 PM Thread Starter
nursekerri
Plastic slider
Sorry if I am posting in the wrong place, if so plz direct me.
I recently purchased my long awaited for JEEP. a 2011 2 door wrangler. My question is regarding the top and sun rider top. There is a small plastic slider that holds the "elbow" joint in place when the sun rider is not open. One of mine is split and the dealer is ordering me a new one, but after I used the sun rider top back the first time the "elbow joint does not seem to line up equally again and both the driver and passenger sides are a bit off and the slider does not fit over them. Is there a trick or am I doing something wrong?
Thanks for any advice
nursekerri is offline
post #2 of 2 Old 04-02-2013, 09:49 AM
HighandLow
HighandLow's Avatar
2010 JK Wrangler
You may have bent the frame tubing a little bit. At least that's what happened to mine when my wife tried to open the sunrider not knowing about the sleeves. Press down on the top as you try to push the sleeves over the joint. Eventually mine started to fit right.
2010 Rubicon, Auto, Stone White, 3.5"Synergy Coils, DL and TR, MetalCloak TB's and CA's Fr/Rr, 37"Coopers 18" Ions , Adams 1310's, G2 5.13 gears, Synergy Sleeves and Gussets, ORF, PSC, JCR, PIAA,Rancho equipped...
HighandLow is offline
