Planning frankenstien lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Planning frankenstien lift
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep parts, deals and more at JeepHut.comTJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 10-06-2014, 07:03 PM   #1
Jodyblip
What brand coil spring would you use and why? ( I already have my own opinions but I would like to hear from others to possibly add to , reinforce , or change my opinions.
I am looking at springs in the 2 inch to 3.5 inch lift range for 2 door I wanted 2 inch but the 3 inch (minimum best I can tell) is where you start being able to use geometry goodies like drag link flip track bar brackets etc
help me plan my frankenlift!! lol lookin for spring advice only at this point
Jodyblip is offline   Reply With Quote Quick reply to this message
Unread 10-07-2014, 03:55 AM   #2
SLADE
Metalcloak, Synergy, Teraflex, and OME.
Which ones and why depends more on the setup of the Jeep and what you want to achieve more than just picking a name.
If you have plans of flipping the draglink and raising the track bar, you'll need to run 3" bump stops without notching the frame. Youll have to have a long coil to accommodate the extended length of the longer shocks that the 3" bump stop will allow for. 2 doors are at a disadvantage when looking for a long coil for a small lift.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline   Reply With Quote Quick reply to this message
Unread 10-07-2014, 05:24 PM   #3
Kolak
Vendor
Kolak's Avatar
I recommend OME as they have a selection of spring rates. That way you can choose the correct one for the way your JK is equipped.
PM me if you'd like pricing or have any questions - I've been an OME dealer forever
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
kolak@aol.com or kolak@kolakperformance.com
Kolak is online now   Reply With Quote Quick reply to this message
Unread 10-07-2014, 05:42 PM   #4
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
ditto - for a frankenlift, which I have, the OMEs have been absolutely great over the years with NO sag. I went with the 2.5 HDs and obtained about 3.2 inches and holding. I used the leveling puck in the front to take the rake out of the JK.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote Quick reply to this message
Unread 10-07-2014, 05:42 PM   #5
reichard117
reichard117's Avatar
2014 JK Wrangler
Consider his use as well, some people bash AEV, but I have nothing but great things to say. I got the 2.5" dualsport with Bilstiein 5100's and it handles amazing on road and flexes great.
Originally Posted by Maertz View Post
In that case go for gold jeffy.
'14 JK - My JK Build
'00 XJ - Currently unwanted project
Follow me on Instagram - thereich
reichard117 is offline   Reply With Quote Quick reply to this message
Unread 10-15-2014, 12:25 AM   #6
nickbol9
2009 JK Wrangler
If you want a good ride on road ome all the way they ride absolutely amazing its what I'm getting for my lift
nickbol9 is offline   Reply With Quote Quick reply to this message
