pinion angle/caster... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > pinion angle/caster...
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineZONE 4.25" combo lift for TJ available at Rockridge4wTeraFlex Now at Rockridge 4WD! BEST DEALS around!
Unread 09-02-2011, 09:53 PM   #1
Rdlynch2
alright, so i got a few questions here...
i am a newbie, so bear with me....
2 weekends ago, i installed the rock krawler 2.5 inch stock mod kit with some dudes that have done numerous lifts in the past, so they at least knew what they were doing, unlike me, unfortunately, but i am learning, slowly but surely...., im currently running on 33 inch km2s and 17 inch rims,...
i want to make sure that everything is set correctly, in reference to the geometry, steering, alignment, etc...so that i will not run into any issues down the road
with that said, i plan on getting a proper alignment done this upcoming week...
so my question is this, how important is it for me to check my pinion angle, caster, etc etc..
i honestly dont even really now what pinion angle and caster is. i know that pinion angle refers to the driveshaft and that caster refers to tire angle...but beyond that i dont know sh*t.
can someone help explain all this to me? or recommendations on what i should do? i have done numerous searches, but cannot find anything that explains it in layman, idiot proof terms..
so far, my jeep is driving fantastic,..no vibrations, no wobble, seems to be no major issues with alignment, steering....
08 JK/6 speed/2 Door/soft top--35x12.5x17 GY MTR's--ATX slot's--R.K. Stock Mod--Smittybilt rocker guards--PSC evap skid--PSC tramp stamp--Hella 500 black magic's--RK drag link. Pure Jeep axle knuckle/gusset kit.
Rdlynch2 is offline   Reply With Quote Quick reply to this message
Unread 09-02-2011, 10:06 PM   #2
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
At only a 2.5 in lift you need not be concerned with caster or pinion angle. That being said, the answer to your question in very, very simple terms:
Pinion angle is the angle between the drive shaft and the pinion shaft (the shaft coming out of the differential).
Caster angle is the angle between a vertical line through the axle and a line drawn between the upper and lower ball joints. Caster angle is what makes the tire want to self center and track in a straight line.
Since your running mice and smooth with no wobble I think you are good to go as is.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote Quick reply to this message
Unread 09-02-2011, 10:16 PM   #3
ronjenx
ronjenx's Avatar
Come on, now! The 3.8 isn't THAT bad.
ronjenx is online now   Reply With Quote Quick reply to this message
Unread 09-02-2011, 10:18 PM   #4
Rdlynch2
cool thanks man. also, im thinking that next spring i will upgrade my stock mod kit to the max travel....how much would i expect to gain in suspension quality/flex from adding the r.k adjust lower control arms?? would it be worth investing in?....
i mean i assume there is a reason why their is a 500 dollar difference between the max travel and stock mod kits but....just wanted to access what i would expect to gain....
that is one of many reason why i am very happy with my decision to go with rk. their upgrades options seem to be limitless. and i have yet to hear one negative comment about there products, except the fact that they are expensive, but as i add begin to add more mods, the slogan "you get what you pay for" continually comes to mind.
Unread 09-02-2011, 10:19 PM   #5
Rdlynch2
hahaha. i just got that! jk lol!
Unread 09-02-2011, 10:40 PM   #6
RockyClymer
RedRock4Wheeler
Let's have a round for spell checker on the iPad lol.
NRA Life member
Unread 09-03-2011, 03:38 PM   #7
Rdlynch2
Unread 09-03-2011, 10:16 PM   #8
JLC08JK
What was I thinking?
JLC08JK's Avatar
You will not gain any height though you may gain slightly in articulation because of the more flexible control-arm joints.
The price of the "Max travel kit" includes the front and rear lower control-arms and the longer stainless braided brake-lines. When bought separately the CA's cost about $279 per pair and the brake-lines are $110 per pair.
The main reason for changing the control-arms to an adjustable type is to make changes in pinion and caster angles. As said earlier in this thread you really don't need to adjust these points with a 2-1/2" lift. You can if you want but the changes will be hardly noticeable.
However you do it you can't go wrong
JLC08JK is offline   Reply With Quote Quick reply to this message
Unread 09-03-2011, 10:43 PM   #9
Rdlynch2
so all that would be gained is a lil added flex huh? alright....sounds good, ill add it to my future mod list. thanks!
Unread 09-03-2011, 11:07 PM   #10
JLC08JK
JLC08JK's Avatar
If you keep an eye on the J/F classifieds, ebay, C/L, sometimes you can get a great deal on parts that were bought and never installed.
I bought my rear lowers for $150 off ebay and front lowers for $100 from the J/F classifieds. These were all brand new Currie Rock Jock and would have totaled about $700 retail.
Keep your eyes open, the deals are out there
Unread 09-04-2011, 12:15 AM   #11
Rdlynch2
thanks dude. although i would be suprised to see any rock krawler "mid arm" control arms for much cheaper than retail, being that fact that their products seem to be so desired by members of our esteemed community.
either way, is it just because the joints on their control arms are adjustable and articulatable?? (i know thats not a word), that allows for more flex vs the stock arms? also, how much longer are the rock krawler mid arms vs stock? just curious....if you happen to know that is......
Unread 09-04-2011, 12:34 AM   #12
JLC08JK
JLC08JK's Avatar
The mid arms are named as such because they are longer than the arms on TJ Wranglers. They are however adjustable +/- approx. 1/2" to 1" the stock factory length on a JK. (I don't know the exact numbers) they should be called standard arms but "MID" makes you think you're getting something more!
The joints pivot and the length of the arms are adjustable.
Unread 09-04-2011, 10:09 AM   #13
Rdlynch2
another question guys, since I installed this lift I have not yet brought my jeep in to get an alignment done, do you think that this is necessary after a 2.5 inch lift?
after the install we did adjust the steering wheel, because after the first test drive the esp went off and blah blah you guys know the story, but i understand that that has nothing to do with alignment.....
i do not really fully understand the concept of toe-in, and how to properly set it on your own so... (not very mechanically inclined).
Unread 09-04-2011, 10:09 AM   #14
Rdlynch2
basically do you guys think that it is necessary for me to bring it in to get an alignment done?
