Pinch Seams (cut off wheel; Thanks 1222) - JeepForum.com
post #1 of 7 Old 11-14-2010, 06:16 PM Thread Starter
240Dbio
2010 JK Wrangler
Well I got the 35s in my little storage hole near my front door. I've been itching to put these 35s on. So I'm starting to prepare.
Tools:
Light (it always comes in handy)
dremel and metal cut off wheel (a few come in handy I bought a pack of five)
tape (not needed, but helps protect what you dont want to cut into and for measurement)
Silicon
ruler or measuring tape (not in picture)
Oh i forgot.....a
Clean area...probably not necessary, but dremeling into dirt and going into your face....probably not pleasant
I put tape on plastic material so it could easily be ripped off and measured an inch from the edge of the tape. Then put that onto the vehicle. It was difficult to measure the inch on the curve. So I said "the hell with it". The two pictures below is what it looked like when I thought I was finished
Then I dug down deep found my balls and made it look a a little big better.
Dont forget the silicon. I wasn't shy with it, I was more concerned with rust then the way it looked.
Special thanks to 1222 and his pinch seam thread. Gave me the courage to tackle it. Wish I had a plasma cutter.
Notes: Cut-off wheel is not very stable. In order to cut metal you'll need high rpms...which makes it more uncontrollable. Be prepared for mess ups. I scratched places I didnt want to, but oh well its a jeep. It will see worse.
240Dbio is offline
post #2 of 7 Old 11-14-2010, 06:25 PM
1222
RIP John
1222's Avatar
Iím glade I was able to help in some small way. If this is the first time ever cutting into the body of your Jeep it can be very intimidating at best. That first cut is a *****. Glad you went back and cleaned up the original cut. Iím sure you just gave a few others the nerve to do the same. Great Job.
Almost forgot, you're welcome.
(2011-2016)
1222 is offline
post #3 of 7 Old 11-14-2010, 07:57 PM Thread Starter
240Dbio
2010 JK Wrangler
Yup very first cut into the jeep. It was intimidating. You reach that point of aggravating where you say eff it and typically it works out or you fail miserably. This time I wasn't to aggravated I just thought it looked like poop. It still looks like poop, but with the silicon on it worked out pretty nicely. I only did the driver side passenger tomorrow. Anyone know a website forfreeshipping for rims to Alaska? This guy wanted 195 (each) for some standard steel hubs. I laughed in his face and walked out.
240Dbio is offline
post #4 of 7 Old 11-14-2010, 09:31 PM
1222
RIP John
1222's Avatar
Have you tried Northridge 4x4 yet? I know he has free shipping just not sure if it includes Alaska though.
(2011-2016)
1222 is offline
post #5 of 7 Old 11-14-2010, 11:12 PM Thread Starter
240Dbio
2010 JK Wrangler
heck yeah....they saved me when I didnt read install instructions for the RE express. I drove like an hour north when i was in washington to pick up some wheel spacers.....installing my first lift without plenty of time was a PITA. 4wd has free shipping....so they say. They have military discount I'm going to give them a call tomorrow.
How do i know if the rim will fit my tires. I got the wrangler mtrs kevlar 17. (35s) I see 17inches that are 8s and 9s. 5x5 is the bolt pattern little confused between the 8s and 9s. just want to make sure they fit before I buy. I bet 4wd can solve my problem.
240Dbio is offline
post #6 of 7 Old 11-15-2010, 12:39 AM
Warlord2
Im assuming you mean 8 or 9 inch width, if thats the case you can use either. I went with 8 inch to help with keeping a bead while aired down. The 9 inch isnt bad either and might help the tread wear a little more even. Cant go wrong with either one....if you ever wanted 37inch tires later you might want the 9 inch though sense they tend to be a little wider of a tire.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #7 of 7 Old 11-16-2010, 12:12 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Made it to the F.A.Q.
Jim
JLC08JK is offline
Seams coming apart on soft top SETXWarrior JK Wrangler Technical Forum 9 07-15-2010 09:35 AM
Soft top leaking at seams! how to fix? MC_NickP TJ Wrangler Technical Forum 5 04-11-2009 12:31 PM
Soft top coming apart at the seams ? TNseabee Wrangler General Discussion 0 02-25-2009 06:23 PM
Pinch Weld Trimming in front of Rear Wheel PSYCH0 JK Wrangler Technical Forum 3 03-30-2008 10:41 AM
seams? kennyk YJ Wrangler Technical Forum 7 07-26-2007 09:29 AM
