"PHOENIX" AWINSKI's build in memory - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > "PHOENIX" AWINSKI's build in memory
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 04-28-2013, 08:27 PM   #76
TheBoss
Now that's looking much better.
TheBoss is offline   Reply With Quote Quick reply to this message
Unread 04-28-2013, 08:56 PM   #77
Tanimal
Looks good, when I installed that rear trac bar bracket I noticed afterwards that the bolt was a little long and was actually making contact with my rear coil so make sure you check that.
[URL="http://www.jeepforum.com/forum/f96/tanimals-2008-2d-jk-build-thread-1397184/"][COLOR="Blue"][B]-=-CLICK HERE FOR MY JK BUILD THREAD-=-[/B][/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f11/tomimal-tanimals-1993-cherokee-country-build-thread-1440379/"][COLOR="GREEN"][B]-=-CLICK HERE FOR MY XJ BUILD THREAD-=-[/B][/COLOR][/URL]
[B][I]Learning as I go and it's worth every penny![/I][/B]
Tanimal is offline   Reply With Quote Quick reply to this message
Unread 04-28-2013, 11:40 PM   #78
TJeep32
2009 JK Wrangler
I got the same decal, we're like twins lol
Sent from my GS2 using JeepForum
TJeep32 is offline   Reply With Quote Quick reply to this message
Unread 04-29-2013, 04:21 AM   #79
awinski
i noticed the same thing on my last jeep, two very thick washers fixed that
The ONLY chlorophyll JK
one more horse power than the average pentastar; [URL="http://www.jeepforum.com/forum/f22/plus-1-horse-power-after-build-2157673"]http://www.jeepforum.com/forum/f22/plus-1-horse-power-after-build-2157673[/URL]
twitter/IG - @Becauseracejeep
awinski is offline   Reply With Quote Quick reply to this message
Unread 04-29-2013, 07:56 AM   #80
BigBlue7
2010 JK Wrangler
Good Work!
Rock Krawler | TeraFlex | Synergy | Fox | Poison Spyder | Genright | Nemesis |Beer
BigBlue7 is offline   Reply With Quote Quick reply to this message
Unread 04-29-2013, 08:42 AM   #81
Remmy18
Looks awesome man! I'd bet your Dad would proud. Love your Genright bumpers. That's the route I want to eventually go. Lets see some wheeling pics now!
Remmy18 is offline   Reply With Quote Quick reply to this message
Unread 04-29-2013, 10:44 AM   #82
Tanimal
I decided to try to cut a grade 8 bolt and let me tell you.....I burned so many blades up it was a mistake, probably should have just went with the washers.
Unread 04-29-2013, 12:48 PM   #83
awinski
haha my friend helping me said lets just cut it, i looked at the head and said you wanna cut this? thats when he said okay we'll just get washers
Unread 04-29-2013, 12:50 PM   #84
awinski
Attachment 617737
haha looking good
Originally Posted by BigBlue7 View Post
Good Work!
thanks blue
thanks! and i love them, great quality i just can't wait to see ho it all holds up on the trail!
Unread 04-29-2013, 05:05 PM   #85
KrawlOff-Road
Vendor
KrawlOff-Road's Avatar
Attachment 617737
LOL Nice!!
AWINSKI, build is looking great! Nice to see you bounce back so quick with this one. Cant wait to see where it goes from here! And, of course, thank you once again for allowing us to be part of such a great build...
-Jason
Serving all your "KRAWLER" needs...
Poison Spyder Customs, Rock Krawler, RIPP MODS, Dynatrac, River Raider, Warrior Products, Rock Hard 4x4, Poly Performance, Max-Bilt, TERAFLEX, and MANY MORE...
Tires-FREE SHIPPING!!
KrawlOff-Road is offline   Reply With Quote Quick reply to this message
Unread 04-29-2013, 06:09 PM   #86
awinski
Originally Posted by KrawlOff-Road View Post
LOL Nice!!
-Jason
couldn't have done it without your help jason! ill be back for more soon enough!
Unread 04-30-2013, 05:22 AM   #87
HOKIES2010
HOKIES2010's Avatar
2011 JK Wrangler
Good build thus far
HOKIES2010 is offline   Reply With Quote Quick reply to this message
Unread 05-05-2013, 08:19 PM   #88
awinski
got my brake lines and memorial vinyls done this weekend. spent a lot of time helping my friend with his truck, so no major updates
Unread 05-07-2013, 01:40 PM   #89
awinski
okay so the brake line install was pretty simple, followed the write up on another forum from another planet right down the street. all you need is a 15 and 10 mm socket. and 11, 12, and 17 mm open ended wrenches. i pinched off the line, unbolted the bottom, let the little bit drain out. then moved to the top, where you use the 11mm open ended wrench, don't take out the bracket bolt first, itll just make it a PITA. bleeding was also a simple process, start at the rear passenger, don't remember what the bleeder is in metric size but i just used a 7/16''. worked great. pump the brakes 3 times on the 4th hold, i was alone so i used the extension from the stock jack to hold the pedal down by wedging it between the pedal and the seat. then just go bleed the valve. repeat for each caliper. only used about half a pint of fluid in the end. make sure to leave the engine off while doing this.
everything-done-today-006.jpg   everything-done-today-007.jpg   everything-done-today-008.jpg
Unread 05-07-2013, 02:12 PM   #90
BigBlue7
2010 JK Wrangler
Hey man, you skipped the brake lines earlier? There's a penalty for that! (good job)
