"PHOENIX" AWINSKI's build in memory - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > "PHOENIX" AWINSKI's build in memory
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 04-15-2013, 12:45 PM   #31
awinski
Originally Posted by john304 View Post
How long do you plan on running the 37's before beefing up the axle?
doing the truss, gussets, and lca skids asap, shafts, regear and a better locker will come as it breaks, or as money allows. biggest thing will be wheeling carefully until i can afford to break something.
Originally Posted by KrawlOff-Road View Post
Man, that stuff is showing up quick!! This is going to look great...
-Jason
i was surprised at how fast everything came last time too. just can't wait to get the lift on there so i can get the tires on!
The ONLY chlorophyll JK
one more horse power than the average pentastar; [URL="http://www.jeepforum.com/forum/f22/plus-1-horse-power-after-build-2157673"]http://www.jeepforum.com/forum/f22/plus-1-horse-power-after-build-2157673[/URL]
twitter/IG - @Becauseracejeep
awinski is offline   Reply With Quote Quick reply to this message
Unread 04-15-2013, 12:50 PM   #32
awinski
rubber rocker liners, shocks, and AEV procal showed up today!
Unread 04-15-2013, 01:00 PM   #33
J33PNSL33P
The cut fenders look good! Did you follow a write up or "how to"? I know there's one on project jk and a few on here as well. Or did you just do your own thing? I'm cutting mine as soon as the snow stops falling.
J33PNSL33P is offline   Reply With Quote Quick reply to this message
Unread 04-15-2013, 01:22 PM   #34
awinski
it was simple, i left them on, used painters tape to mark out the lines, using reference points already on the fenders. i had done it on my previous jeep so it was simple. if someone really wants to know to copy my design, i can give pictures with measurements, but it is honestly very simple. used a cutting wheel and a die grinder
Unread 04-15-2013, 01:31 PM   #35
Dumpsterfish
Did you use any kind of door trim to finish them? If so, link to the stuff you used?
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
Dumpsterfish is offline   Reply With Quote Quick reply to this message
Unread 04-15-2013, 01:42 PM   #36
awinski
stuff i used was black door trim, comes in a roll from auto zone. had to get two rolls to do all four
Unread 04-15-2013, 02:44 PM   #37
BigBlue7
2010 JK Wrangler
Excited for you man! Post up a ton of pictures!
Rock Krawler | TeraFlex | Synergy | Fox | Poison Spyder | Genright | Nemesis |Beer
BigBlue7 is offline   Reply With Quote Quick reply to this message
Unread 04-15-2013, 03:41 PM   #38
Dumpsterfish
thanks!
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
Unread 04-16-2013, 01:05 PM   #39
awinski
no problem guys, ill probably do a small write up on everything i do from now on, i didn't have a camera on me when doing the fenders, so i was unable to do that, if you guys want info, i followed a few write ups found by simply googleing then just modified it to fit now i wanted it to look. on another note tf exhaust spacers came in today, not the most exciting mod but i have plenty of tie on my hands to get it done.
Unread 04-16-2013, 06:35 PM   #40
awinski
installed my exhaust spacers today, very simple and straight forward, but very much of a pain trying to get one lined up without knocking the other crooked. just used one 1/2" socket with a 1/4" drive to get the upper on the drivers side, the other three bolts came out like cake. after that it was simply putting them in, getting the drivers side in and finger tight, then i moved to the passengers side where i got that tightened down. moved back over to the drivers side where it was now a little crooked, using my breaker bar as a pry bar against the frame rail i was able to move it into place while i tightened down the bolts with the other hand, a bit of a pain and took a little muscling it into place, but this being my second time i knew what i was in for.
exhaust-spacer-install-001.jpg   exhaust-spacer-install-002.jpg   exhaust-spacer-install-003.jpg   exhaust-spacer-install-004.jpg   exhaust-spacer-install-005.jpg
Unread 04-16-2013, 06:38 PM   #41
bhoch
Thanks for the spacer pics. I'll be doing this to my JK this weekend asmim putting on my rk lift this weekend.
Bill
bhoch is offline   Reply With Quote Quick reply to this message
Unread 04-16-2013, 06:44 PM   #42
awinski
Bill
very nice, im really hoping this week my lift comes in so i can get it on.
Unread 04-17-2013, 03:22 PM   #43
awinski
started wet sanding my rockers today, not trying to get anything too shiny so 150 grit is probably the highest ill go. now time to find a nice clear to use on all the aluminum, that or powder coat. plan to install them this weekend most likely. more pictures then!
Unread 04-17-2013, 03:55 PM   #44
Tanimal
Don't powercoat, in my opinion it's an absolute waste of money and scrapes off just as easy on the rocks as spray paint does. Also touching up powedercoat sucks and I've never had it blend correctly and it just comes out spotty and crappy looking.
[URL="http://www.jeepforum.com/forum/f96/tanimals-2008-2d-jk-build-thread-1397184/"][COLOR="Blue"][B]-=-CLICK HERE FOR MY JK BUILD THREAD-=-[/B][/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f11/tomimal-tanimals-1993-cherokee-country-build-thread-1440379/"][COLOR="GREEN"][B]-=-CLICK HERE FOR MY XJ BUILD THREAD-=-[/B][/COLOR][/URL]
[B][I]Learning as I go and it's worth every penny![/I][/B]
Tanimal is offline   Reply With Quote Quick reply to this message
Unread 04-17-2013, 03:58 PM   #45
Walle
Soccer Mom and Jeep Hater
Walle's Avatar
This!
| Walle's Build | 2014 JKOTY | Instagram |
Walle is offline   Reply With Quote Quick reply to this message
