Persistent front end creaking sound - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Persistent front end creaking sound
Clayton Off Road WJ Long Arm Kits!Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiClayton Off Road - JK Prototype Gas Tank Skid
Unread 08-22-2014, 04:53 PM   #1
VegasMatt
VegasMatt's Avatar
Iíve been getting a creaking sound which appears to be coming from somewhere in the front end. At times, it sounds almost like clutch chatter (weird since I have an auto), other times like a squeaky spring compressing & unloading in resonance. I find it happens mostly at low speeds around town.
After searching the forums a bit, I greased the front sway bar rubber bushings with white lithium grease, then hit the sway bar end links and the spring perches with WD-40. No change. Nothing appears to be loose and there is nothing else to grease. Any other ideas?
08 JK Rubi (toy)
97 328i (DD)
01 TJ Sport (sold)
97 TJ SE (RIP)
97 R850R (sold)
98 CBR 600F3 (sold)
VegasMatt is offline   Reply With Quote
Unread 08-22-2014, 07:57 PM   #2
1222
Make mine a Jeep!
1222's Avatar
Check to see if the sway bar end links are tight. It took me forever it seems to locate an annoying noise which turned out to be loose links. It happened once on my í08 and twice on my 2012.
Use a wrench to check because just grabbing them wonít tell you much unless they are ridiculously loose.
1222 is offline   Reply With Quote
Unread 08-22-2014, 08:14 PM   #3
JIMBOX
Don't forget the Trackbar bushings and the lower front shocks bushings-
As 1222 says, check for tightness, ESPECIALLY the shock lower attach bolts)(50/60 FtLbs)-
Good luck
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is offline   Reply With Quote
Unread 08-22-2014, 10:59 PM   #4
matttruj
I have the same cracking/popping problem on my '08 but mine seems to be coming from the drivers side A pillar or dash
matttruj is offline   Reply With Quote
Unread 08-22-2014, 11:12 PM   #5
sherman07
Check your ball joints, hubs and axle shaft u joints.
sherman07 is offline   Reply With Quote
Unread 08-22-2014, 11:49 PM   #6
LeighP
On a different 4WD, I had a similar noise...turned out to be the springs moving against the spring mounts....I sprayed some WD40 on them occasionally for a quiet ride.
Regards,
Leigh
2013 JK Overland/Sahara 3.6L
LeighP is offline   Reply With Quote
Unread 08-23-2014, 06:35 AM   #7
megawatt308
Would you by chance have an aftermarket bumper and leave the shackles mounted on the front. I have seen many shackles make noise and drivers think its the suspension needing lubrication. I was reminded about this since you said.
Originally Posted by VegasMatt View Post
...I find it happens mostly at low speeds around town....
Remove the shackles or get daystar isolators for them.
megawatt308 is offline   Reply With Quote
Unread 08-23-2014, 01:47 PM   #8
VegasMatt
VegasMatt's Avatar
Thanks for the ideas all. This morning I checked a few things:
Took off track bar to inspect bushings. Didn't see any that were obviously bad:
I re installed bolts & torqued to spec.
Next, I checked sway bar links, and could not budge any with a wrench. It's hard to get a torque wrench in there without removing the whole assy.
On the sway bar links - on the passenger side link, it appears the PO replaced a flange nut with a regular nut and washer. Unsure if thatís an issue. Pics below:
I also checked lower shock mount bolts. They were good.
Then I had an idea to bounce all 4 corners to see if I could recreate the noise. I was able to recreate the spring creak on the passenger front & driver rear corners. I hadn't previously lubed the rear swaybar bushings, they seem easy enough to get to so i'll give that a try.
Factory bumper, but i do have a winch + winch mounting plate. The winch hook is secured to the factory tow hook, and doesn't have much play at all.
08 JK Rubi (toy)
97 328i (DD)
01 TJ Sport (sold)
97 TJ SE (RIP)
97 R850R (sold)
98 CBR 600F3 (sold)
Unread 08-23-2014, 03:13 PM   #9
1222
Make mine a Jeep!
1222's Avatar
Good luck
JIMBO
This just reminded me about the shocks. I was again having problems with front end noise but as usual was having trouble locating the source until out of dumb luck I found it; the upper shock stem on the pass side was loose from a backed off nut.
On another occasion when I was absolutely sure it was a front spring making noise it turned out to be a bad sway bar link joint, it was tight and all but dry and squeaky and clicked all rolled into one.
I guess the point to all of this is that sometimes the source is where youíd least expect it.
Unread 08-23-2014, 04:30 PM   #10
JIMBOX
Heh Heh, YUP_
Sometimes it's the wife sitting next to you !
JIMBO
Yellow Jeep No. 683
Unread 08-23-2014, 05:53 PM   #11
1222
Make mine a Jeep!
1222's Avatar
Heh Heh, YUP_
JIMBO
True enough but the IS expected.
Unread 08-24-2014, 10:52 AM   #12
222Doc
Heh Heh, YUP_
JIMBO
That is an easy one to diagnose. Remove wife and test drive.....
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is offline   Reply With Quote
Unread 08-24-2014, 11:29 AM   #13
VegasMatt
VegasMatt's Avatar
So first thing today I checked the upper shock mount bolts, they were tight.
Then I checked the lower shock mount bushings, looked good so I retorqued to spec.
Then I took off the sway bar links and think I found the culprit. The side that the PO had used a regular nut in place of a flange nut has a tweaked bushing. The rubber is misshapen and when I put them side by side on the bench you can see how the bushing sticks out. Iím assuming if the bushing is tweaked then the metal has been warped torsionally as well.
Looks like Iím ordering some new swaybar end links and a flange nut.
08 JK Rubi (toy)
97 328i (DD)
01 TJ Sport (sold)
97 TJ SE (RIP)
97 R850R (sold)
98 CBR 600F3 (sold)
Unread 08-24-2014, 01:19 PM   #14
1222
Make mine a Jeep!
1222's Avatar
Glad you found it. I had to remove mine also to confirm it was the culprit.
Unread 08-24-2014, 03:30 PM   #15
megawatt308
Way to bird dog it .
Let us know when you replace the swaybar end links if it cures the problem.
