Passenger-side air bag??? - JeepForum.com
post #1 of 20 Old 03-07-2007, 11:02 AM Thread Starter
SPDSNYPR
Junior Member
I read in the manual for my 07 unlimited wrangler that the passenger side air bag is supposed to have a scale that turns off the passenger side airbag if it thinks whatever in the passenger side is too light (like a kid). I have had both my 60-ish lb daughter and 75-ish lb son ride over there when the rear seats were folded (not at the same time), and the little light that says the pass airbag is off never came on.
Does anyone know the weight limit of the sensor? I have also carried things like a gym bag with some of my gear in it, and the light never came on. I was wondering if maybe mine just doesn't work right. Frankly, I would have preferred they left it like in the TJ where you just turned it off with a key - at least I knew when it was on and off.
SPDSNYPR is offline
post #2 of 20 Old 03-07-2007, 11:41 AM
scottyc
I don't know the exact limits, but I have noticed the light turn on when carrying my laptop bag or a couple bags of groceries in the front seat. Probably something like 5-20 pounds from time to time. I've never had anything in the 50 to 100 lb ranges, so I'm not sure about your kids, but I think the gym bag should have deactivated the airbag.
scottyc is offline
post #3 of 20 Old 03-07-2007, 12:00 PM
jeepers3
It's all described in the manual - give it a looksee.
jeepers3 is offline
post #4 of 20 Old 03-07-2007, 12:28 PM
scottyc
He says he read the manual. You sure it gives the weight limits?
scottyc is offline
post #5 of 20 Old 03-07-2007, 12:42 PM
jeepers3
Yeah, because I had the same questions and that's where I found the info. (: I believe that 40 pounds is the magic number, but I can't swear to it.
jeepers3 is offline
post #6 of 20 Old 03-07-2007, 12:45 PM
strykermp5
i had a heavy laptop case and miscellaneous equipment that activated the air bag off light... the manual says anything under 100lbs but over 5 lbs will turn off the airbag... my girlfriend is less than 100lbs but the airbag is still active... i really think the the "sensor" is a novel concept, but in reality... not very accurate
beside... you have seatbelts and a roll cage... good enough for me... and children are a lot more durable than people give them credit for!!
you get more fragile, the older you get...
when i was 80 lbs, i fell out of a tree about 2 stories up... landed flat on my back... caught my breath and walked away.
if i did that now... i would die flat out, probably before i hit the ground
2007 Wrangler Unlimited X
Jeep Green, Black Cragars, Black Windows
Optional Equipment:
M4 (x2)
Sig 226
strykermp5 is offline
post #7 of 20 Old 03-07-2007, 01:05 PM
scottyc
Based on this, it sounds to me like you ought to get your sensor checked out. It could just be the light malfunctioning, but there's no way to know. You'd hate for your airbag to deploy with a little kid in the seat.
scottyc is offline
post #8 of 20 Old 03-07-2007, 01:18 PM
jeepers3
I like this thread because at one time, I was convinced the sensor in my brand new Jeep was broken too. I had never had a car with airbags before, so I didn't really know what to expect and so forth. My brother, who has a lot of experience with such things, had to explain to me over and over that it wasn't broken, and why, and so forth. We did a couple of experiments, and he showed me that system was behaving exactly the same as the system in his Titan pickup, and so forth.
Eventually, I was forced to conclude that the system was working as designed, but the design is just plain stupid. The purpose of the light is to tell you that the airbag is off. Who cares if the bag is off? What I want to know is when the airbag is ON!! I argued with with my brother and his opinion was that most of the time, the airbag is off since no one is sitting there, so if the light was on in this case, then it would burn out more quickly. Whatever. I still think it would be more useful to have confirmation that the bag is definitely on, rather than magically turned off, when certain conditions are met. Personally, I think the old key-based system for turning the bag off and on was infinitely superior to the occupant classification system. (:
My guess is that the sensor is working as designed.
jeepers3 is offline
post #9 of 20 Old 03-07-2007, 01:41 PM
Agent 000
Agent 000's Avatar
The Occupant Classification System (OCS), does not operate on weight alone. there a a series of calibrated sensors in the passenger seat that measure weight, and also how the weight is distributed in relation to the sensors.
In layman's terms, kids sit on seats different than adults sit on seats due to their height. Try this trick to understand, sit on a chair with your feet touching the floor, then, lift your feet off the floor, and notice how the chair feels different as you are sitting on it. When your feet are touching the floor, a portion of your weight is transferred to your feet and lower legs. When you lift your feet, your weight is now centered on your butt.
Kids are shorter than adults, and as such, theeir weight is distributed differently on a seat than an adult in the same seat. The disigners did a lot of testing and calibration to make the OCS system work, and they did a great job on it (the federal guidelines are very strict for this safety system). There is no magical weight to activate/de-activate the system. If you do not have a red airbag fault indicator on your dash display, then the system is working properly. If the red light is on, go see your dealer ASAP!
Heritage Region Jeep Alliance
Chili Pepper Red 1998 Jeep Cherokee Classic
Agent 000 is offline
post #10 of 20 Old 03-07-2007, 02:40 PM
strykermp5
good thing i dont have kids.. and little kids shouldnt be inthe front seat anyway.... kinda like leaving strapping your baby to the luggage rack
Optional Equipment:
M4 (x2)
Sig 226
post #11 of 20 Old 03-07-2007, 02:43 PM
strykermp5
all hail the mighty roll cage and those pesky seat belts!!!
speaking of, i am in the habit of taking off my seat belt when i enter the driveway... while s till moving, is there anyway to get rid of that annoying warning bell???
Optional Equipment:
M4 (x2)
Sig 226
post #12 of 20 Old 03-07-2007, 03:23 PM
jeepers3
That's a good idea. I bet it makes for a more quiet ride, esp. on long trips.
jeepers3 is offline
post #13 of 20 Old 03-07-2007, 03:49 PM
scottyc
Hey, I agree with you on this one. The reason it's stupid to me is that sometimes, no light means the airbag is on (when an adult is sitting there) and sometimes, no light means the airbag is off (when nothing or something light is sitting there). That's just plain cornfusin'
I have to disagree. One of those objects he put in the seat -- gym bag, son, or daughter, should have triggered the system and turned on the light.
Regardless, I'd rather assume it wasn't working and get it checked out than assume it was working and have someone get injured.
scottyc is offline
post #14 of 20 Old 03-07-2007, 06:26 PM
studdboyz75
airbags on a jeep ? I'm scared!
wouldnt they be set off during trail driving?
those things are pretty violent when set off.
Being an ex-firefighter I've seen many people with an airbag pattern imprinted on their face.
studdboyz75 is offline
post #15 of 20 Old 03-07-2007, 06:30 PM
jeepers3
Yeah sure, if you run into something at a high rate of speed. Come to think of it, if that's what I am doing then yeah, I want it to go off. (:
jeepers3 is offline
Driver side higher than passenger side traderdan JK Wrangler Technical Forum 25 06-28-2010 05:16 PM
passenger side d44 on a YJ roccomonte YJ Wrangler Technical Forum 4 07-02-2009 10:26 AM
Can I swap passenger side wiper motor to drivers side? hartescout TJ Wrangler Technical Forum 4 12-31-2008 06:13 PM
Passenger side lower than driver side + more. Imped TJ Wrangler Technical Forum 2 11-19-2008 02:37 PM
Passenger side lower than driver side mezer TJ Wrangler Technical Forum 4 03-29-2006 02:08 PM
