Passenger seat rear access - JeepForum.com
post #1 of 3 Old 04-02-2012, 09:31 AM Thread Starter
McC2430
When we bought our '07 Rubicon the passenger seat would 'fold' and move forward when the top lever (of the two on the side) was rotated. Then for some reason the seat would no longer move forward. It would still 'fold' but it wouldn't move.
So, today I finally looked under the seat and everything looked ok. The cable that hooks up to the seat release bar is connected, the slide mechinism is released on the door side of the seat but, the side next to the transmission tunnel seems to have a piece missing. The tab that is welded onto the crossbar has a hole drilled in it and there is nothing there.
I looked online for a diagram of the seat release mechinism but, I guess I'm not smart enough to find it. The slide release lever toward the transmission looks like it is too tall to have the 'tab' move it down. It looks like there should be a ramp (???) of some kind to depress the tranmission side slider lock.
So, there it is. Has anyone else had this issue or do you have a diagram that might show me the seat release mechinisim? A pic of someone elses trans tunnel side of the seat release would even be nice to see if mine is jacked up or not.
Thanks guys and girls.
McC2430 is offline
post #2 of 3 Old 04-02-2012, 01:13 PM
jstrubberg
2009 JK Wrangler
There is a pin down there that has slid out of position, It's a dumb design, but an easy fix.
http://www.jeepforum.com/forum/f96/2...enger-1104397/
jstrubberg is offline
post #3 of 3 Old 04-03-2012, 08:04 AM Thread Starter
McC2430
Thanks jstrubberg. That really is a silly design for something that moves all the time.
McC2430 is offline
diagram , passenger seat
2 Dr JK - Seat won't fold & slide for rear passenger carnut08 JK Wrangler Technical Forum 34 05-28-2016 07:11 AM
Rear access with Corbeau seat bracket? econstantin YJ Wrangler Technical Forum 11 02-12-2012 08:44 PM
Access to passenger side topmost bellhousing bolt jb4 TJ Wrangler Technical Forum 6 03-02-2008 06:02 PM
97 TJ - does the passenger seat "rise" for access to the rear? Black Hole TJ Wrangler Technical Forum 20 05-17-2007 08:23 AM
Rear passenger seat belts josephodrain TJ Wrangler Technical Forum 2 04-26-2006 07:37 AM
