Parking Light wiring - JeepForum.com
post #1 of 8 Old 01-09-2007, 06:14 PM Thread Starter
jpaddict
Does anyone know which wire on the parking lamp circuit is for the parking lamp, and which is the turn signal?
MB E55 AMG
Dodge/Cummins 400 rwhp
Now driving the new Rubi!!
Moderation in the pursuit of justice is no virtue, extremism in the defense of liberty is no vice.
jpaddict is offline
post #2 of 8 Old 01-09-2007, 09:30 PM
BeerMonkeY
park lights are a white/blue wire is coming from under driver seat, its a + trigger. be careful if you are hooking something to it, id use a relay
'92 YJ
'98 ZJ 5.9
'13 WK2 HEMI
BeerMonkeY is offline
post #3 of 8 Old 01-09-2007, 11:01 PM
jdrogers
I don't think so... here is the front parking lights wiring info:
All the lights in the JK are driven from the TIPM. The switch on the steering column talks to the TIPM using the LINbus. Not like the TJ at all.
2002 WJ Limited, Stone White, 4.7L H.O., Quadra Drive
OME Springs, MX6 Shocks, BFG 265/70R17 All-Terrain, Level 8 Tracker Wheels
Scottsdale, AZ
jdrogers is offline
post #4 of 8 Old 01-11-2007, 07:18 PM
BeerMonkeY
well that where you tap into them for a remote start.
'92 YJ
'98 ZJ 5.9
'13 WK2 HEMI
post #5 of 8 Old 01-11-2007, 07:46 PM
jdrogers
All the lights are driven directly from the TIPM. The box right in front of the battery. It has many connectors coming off the bottom of it.
You would pretty much have to tap into the wiring harnesses there or into the appropriate ones as there head toward the front and rear of the vehicle. I can post some pictures of the FSM showing where they run if needed.
Scottsdale, AZ
jdrogers is offline
post #6 of 8 Old 01-11-2007, 08:16 PM
scottyc
Please do.
Why don't the fender lights flash with the turn signal?
scottyc is offline
post #7 of 8 Old 01-12-2007, 02:55 AM
jdrogers
From the wiring diagram above you can tell this since the side marker lights are simply connected to the same feed as the parking lights. No connection with the turn signal lights.
Scottsdale, AZ
jdrogers is offline
post #8 of 8 Old 01-12-2007, 01:02 PM
scottyc
Yeah, I got that. I'm wondering why Jeep did it that way. I expected those things to blink with the turn signals.
scottyc is offline
parking brake light yj jordan TJ Wrangler Technical Forum 4 12-20-2009 03:21 PM
Parking Light Wiring Diagram nckm126 TJ Wrangler Technical Forum 1 12-25-2006 01:52 AM
parking light problem ClemsonJeepGC TJ Wrangler Technical Forum 4 01-03-2006 01:34 PM
CJ parking lamp wiring Polaris TJ Wrangler Technical Forum 4 08-28-2005 06:20 PM
Parking Brake light todnshay YJ Wrangler Technical Forum 12 04-23-2004 11:44 PM
