Parking Brake Is Self Adjusting - JeepForum.com
post #1 of 2 Old 03-12-2010, 09:32 PM Thread Starter
ronjenx
ronjenx's Avatar
I went out to the JK ('08) and did the following test;
I checked the parking brake's effectiveness. It took 5 clicks to prevent forward movement at idle, and 6 clicks to prevent forward movement with a little throttle.
I then ran in reverse a few mph, and slammed on the parking brake to stop (pulled up on the lever a little harder than usual). Did the same thing forward. I repeated this 5 times.
The next effectiveness check yielded the following results:
It now takes 3 clicks to prevent forward movement at idle, and 4 clicks to prevent forward movement with a little throttle. The lever feels better, too.
My conclusion:
The parking brake is self adjusting...to a point.
What's actually happening is, by exercising the parking brake in both directions, it is equalizing the two cables, and the four shoes, making the brake more effective with less handle pull.
If you are able to pull the handle way up, and the brake still is weak, you may need to adjust the brakes at the wheels. There is a star wheel on each brake that will adjust the shoes.
If the brakes are still weak, take the drums off to inspect the shoes for wear.
If the lever can be pulled all the way up with no brake action, the spring clutch arm in the lever assembly is probably broken. A new assembly is needed.
ronjenx is offline
post #2 of 2 Old 03-12-2010, 09:40 PM
daggo66
2009 JK Wrangler
Wow deja vu. I just read this on JKF and asked you to clarify if you stopped with the regular brake or the hand brake. Thanks for clarifying. The procedure for manually adjusting it is a major PITA.
Tom
daggo66 is offline
Adjusting Parking Brake on TJ scutter9 TJ Wrangler Technical Forum 9 03-27-2011 10:24 AM
Adjusting parking brake system today and... thejafe TJ Wrangler Technical Forum 12 02-25-2009 04:58 AM
Adjusting the parking brake ohhpe YJ Wrangler Technical Forum 9 02-10-2006 10:09 AM
self-adjusting parking brake? Mac26Mac TJ Wrangler Technical Forum 22 07-05-2005 11:58 AM
Adjusting Parking brake: Shawno TJ Wrangler Technical Forum 2 10-24-2003 07:03 PM
