P2173 Code – Lightning Bolt – Rough Idle - JeepForum.com
post #1 of 5 Old 09-11-2012, 11:16 AM Thread Starter
fisher836
fisher836's Avatar
Ran a search online for this code that’s being thrown on my 2008 Wrangler Rubicon Unlimited. Saw to check large vacuum hoses, intake etc. and make sure everything is nice and snug. Everything seems to be in order. If I shut the Jeep off and restart it, it runs fine for a while. Could it be a faulty EGR valve? Just looking for ideas. If you find/have better links then I’ve found on yahoo, post em for me. Thanks in advance
Definition of Rubicon:
A limit that when passed or exceeded permits of no return and typically results in irrevocable commitment.
fisher836 is offline
post #2 of 5 Old 09-11-2012, 02:14 PM
ronjenx
ronjenx's Avatar
P2173-HIGH AIRFLOW/VACUUM LEAK DETECTED (SLOW ACCUMULATION)
When Monitored:
Ignition on and engine running with no MAP Sensor DTCs.
Set Condition:
A large vacuum leak has been detected or both of the TP Sensors have failed based on their position being 2.5 volts and the calculated MAP value is less than the Gas Flow Adaptation value is too high. One trip fault the code will set within 5 seconds. ETC light will flash.
Possible Causes
VACUUM LEAK [see "Vacuum Leak", below Possible Causes list]
RESISTANCE IN THE (F856) 5-VOLT SUPPLY CIRCUIT
(F856) 5-VOLT SUPPLY CIRCUIT SHORTED TO GROUND
RESISTANCE IN THE (K1) MAP SIGNAL CIRCUIT
(K1) MAP SIGNAL CIRCUIT SHORTED TO GROUND
RESISTANCE IN THE (K900) SENSOR GROUND CIRCUIT
RESISTANCE IN THE (F855) 5-VOLT SUPPLY CIRCUIT
(F855) 5-VOLT SUPPLY CIRCUIT SHORTED TO GROUND
RESISTANCE IN THE TP SENSOR SIGNAL CIRCUIT
TP SENSOR SIGNAL CIRCUIT SHORTED TO GROUND
RESISTANCE IN THE (K922) TP RETURN CIRCUIT
MAP SENSOR
TP SENSOR
POWERTRAIN CONTROL MODULE (PCM)
VACUUM LEAK
NOTE: This code is enabled on engines with a plastic intake manifold and is intended to limit the maximum engine speed if a large crack occurs.
NOTE: A large vacuum leak is most likely the cause of this DTC.
Inspect the Intake Manifold and Throttle body for leaks and cracks.
Inspect the Power Brake Booster for any vacuum leaks.
Inspect the PCV system for proper operation or any vacuum leaks.
Inspect the MAP Sensor for proper installation.
ronjenx is online now
post #3 of 5 Old 06-03-2013, 09:14 PM
Jeep Kid
Ever find the problem to your code? I'm having the exact same issue and having issues finding the source. Checked all vacuum areas with starter fluid and propane multiple times, no luck on my end.
Jeep Kid is offline
post #4 of 5 Old 06-03-2013, 11:10 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Check the EGR connection/gasket at the top of the intake plenum. Also, check MAP sensor and make sure O ring is good and that it is locked into position.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #5 of 5 Old 06-04-2013, 08:18 AM Thread Starter
fisher836
fisher836's Avatar
Yup, ended up being the $13 egr valve. Good place to start especially money-wise
intermittent rough idle getting code 21... new o2 sensor!!! kornonthekob99 YJ Wrangler Technical Forum 7 10-07-2014 10:07 AM
Jeep wont start.. Red lightning bolt? omgyesihavethos JK Wrangler Technical Forum 19 09-10-2012 07:22 AM
Dies at stops, rough idle after running = power steering code? tiburonimbus TJ Wrangler Technical Forum 2 06-20-2012 12:33 PM
Rough idle/stalls & Error code P0135?? gtimms TJ Wrangler Technical Forum 7 03-12-2011 06:31 AM
rough idle, code 15, speedometer works kornonthekob99 YJ Wrangler Technical Forum 8 11-22-2009 05:01 PM
