oversize tire on spare tire carrier?
| GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
for all of you that managed to fit a 35" tire on your stock spare carrier, can you please tell me in detail how you did it. i am at a loss.
#2 |
Locked @ both ends
I used a 1.5" wheel spacer. a stock wheel with a 35 needs help. No problems. Over 18k and not a rattle, and yes I do wheel my Jeep.
#3 |
that is mounted on your stock carrier?
#5 |
Gold Member
Mine bolted right on with no special tricks. It's at a bit of an angle, but it's solid when the gate is open, or closed. I am excited to get it off o there though, if my purejeep bumper ever shows up.
#6 |
hey igofshn - besides the spacer, did you need longer studs as well?
#7 | |
Locked @ both ends
#8 |
Gold Member
Mine bolted right on. If the wheel has the right backspacing for the axle, it will also have the right backspacing for the tire carrier. I did not need longer studs or anything. If you are using stock wheels, then you will need a spacer, just like you need a spacer to run 35's on stock wheels on the axle.
2007 Black Unlimited Sahara, Black Hard Top, Khaki Soft Top, Khaki Interior, 3" Black Diamond Springs and sway bar links, Rancho Steering Stabilizer, Helo Black Maxx 6 17 X 9 wheels, BFG AT TA KO 315/70-17 Tires, Poly Peformance High Steer Kit, Poly Performance Upper and Lower Front and Rear Adjustable Control Arms, Poly Performance Rear Track Bar Bracket, Poly Performance Chromoly Tie Rod, Offset Upper Ball Joints, Mopar Front and Rear Bumpers and Skid Plate, Warn 9.5ti winch, ARB High Output Compressor with tire inflation kit, PIAA 510 SMR Fog Lights , Silverstar Headlights, Bilstein 5100 series shocks, 5.13 gears, Alpine IDA-X001, Infinity 6020CS, Infinity 6022si, Alpine MRP-F250, JBL P1024, Alpine MRP-M650 http://www.jeepforum.com/forum/f129/hothead-headliner-1237401/ http://web.me.com/stevenpeltierjr/Living_It_Up/Welcome.html |
#9 |
and you have no sag at all in your tail gate?
#10 |
yep mine bolts right up as well. No sag in the tail gate with 19k miles and plenty off road
#11 |
Gold Member
It's just the same as it was when I had the stock tire/wheel on there.
#13 |
i haven't actually tried to do it myself yet, but the mechanic that installed the lift said he tried and the tire hit both the 3rd tail light and the bumper. by the way my new tire is a 35/13.5/17 toyo open country at. i also think the tire/wheel setup probably weighs around 190 lbs. prot , are you running your stock bumper?
#14 |
I also have a 35"x12.5" tire mounted on the stock wheel. It's a tight fit to compress the rubber nubbies the tire fits up against, but I want the wheel mounted as tight and solid as possible. A wheel spacer would work or I could cut the nubbies back, but I figure that would add leverage to any movement (particularly offroad) and potentially cause stress fractures in the alloy tire mount.
I cut the 3rd brake light off with a sawzall. It's not legal, but they don't check for that here during inspections. Bill
2003 Rubicon auto w/3" TeraFlex System & 33" Goodyear MTR's TJ Ruby Pic 1 TJ Ruby Pic 2 2007 Unlimited X 6sp 4dr w/3" lift and 35" Pro Comp X-AT's JK X Pic 1 JK X Pic 2 2009 Grand Cherokee Laredo 4x4 2009 JK Sahara auto 4dr 4x4 |
#15 |
Gold Member
That 13.5" width seems odd. Most 35's are 12.5" wide. For example, I'm running 315/70-17 which is a 34.3" tall, 12.5" wide. If your tire is in fact 13.5", then that may be what the problem is.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
