Out of ideas, need advice for what to do next - JeepForum.com
post #1 of 36 Old 09-20-2014, 11:40 AM Thread Starter
yoda13
Force Wheeler
yoda13's Avatar
OK. I am at my wits end. I had a bunch of parts worn out this summer . Both of my trac bars gave up the ghost after years of abuse, control arms too. So, now I have all new teraflex trac bars and adjustable control arms. Alignment is set to exactly what it was before parts wore out. It has been verified by two different shops on computers. It's set for the lift, not for stock. I also had the ball joints replaced with the Polyperformance ball joints. I have checked all my bolt holes up front to make sure they are not wallowed out and bolts are torqued to proper specs. If the pavement is glassy smooth it tracks perfectly. I can take my hands off the wheel. However, if the pavement is rough, if it has grooves, or is wavy... The jeep is all over the place. Or, if it's windy, the pavement doesn't matter, it's all over the place. Even if it's glassy pavement and calm winds, it will periodically every mile or two grab and pull left or right. I can't flat tow it behind my RV anymore either, because it wags the dog when it grabs. Again, the specs are checked and verified as to what they were previously to part replacements. It used to drive great...tracked good, wind only bothered it an appropriate amount for a lifted jeep, flat towed it 20K miles with zero issues since I got it properly aligned. So, somebody help, where do I go from here? Thanks!
2007 White Jeep Wrangler X-auto, black freedom top, 15x8 Pro Comp Rock Crawlers, 33x12.5x15 BFG KM2s, Superchips Flashpaq, 2" OME Spring Lift, Bilsteins, Rusty's Adjustable front and rear trac-bar, JKS Quicker Disconnects, Rusty's adjustable lower control arms (front and rear), PolyPerformance adjustable upper control arms (front and rear), OEM Rubicon Rock Rails, Finishlinewest Stonehenge Series rear bumper, Smittybuilt winch, Body Armor Front High Clearance Bumper w/ KC Highlights mounted, Roadmaster towbar, Valley 2" receiver hitch, Skid Row Engine Transmission skid, sPod switching system, KC Highlights windshield mounted lights, Delta replacement non-quadbar xenon headlamps, and Bestop saddlebags-Member of the United Four Wheel Drive Association and Blue Ribbon Coalition, †John 3:16†
RIP Mrs. yoda13... My life is better for having had you in it and you made me a better man...I can't wait to see you again...I love you always and forever, and for all eternity
If you want to help the sport of off-roading, and protect your right to do so, please visit the
forum...
yoda13 is offline
post #2 of 36 Old 09-20-2014, 11:47 AM
ncb
Can you post the alignment specs?
ncb is offline
post #3 of 36 Old 09-20-2014, 12:02 PM
Jodyblip
check and make sure track bar mounting locations are not "wallered out" and have a hole bigger than the bolt
Jodyblip is offline
post #4 of 36 Old 09-20-2014, 12:44 PM Thread Starter
yoda13
Force Wheeler
yoda13's Avatar
I did check these. They are not.
forum...
yoda13 is offline
post #5 of 36 Old 09-20-2014, 12:47 PM Thread Starter
yoda13
Force Wheeler
yoda13's Avatar
Left front caster was 2.8, right front caster was 2.6. Left front toe was 0.05in and right front toe was 0.06in for a total toe of 0.11in. Steer ahead was 0.00.
These are the specs I have had the last three years with zero problems. They are the specs I have now and it's scary to drive.
forum...
yoda13 is offline
post #6 of 36 Old 09-20-2014, 12:50 PM
Jodyblip
are the wheels different than you had before? sometimes those little retainer clips mess people up when they change stuff around on wheels and or spacers
Jodyblip is offline
post #7 of 36 Old 09-20-2014, 12:51 PM
Jodyblip
if the track bars are adjustable make sure they aint slipping
Jodyblip is offline
post #8 of 36 Old 09-20-2014, 01:01 PM
222Doc
222Doc's Avatar
Over pressured tires?
What are the caster numbers?
I know when i put in the new Synergy ball joints. They were TIGHT I mean very tight. it took a few hundred miles for them to break in. On first few miles the jeep would not want to return to straight. but i did the tie rod and drag link as well so all those parts were very tight. be VERY sure you greased the new joint's, they are not pre lubed and only come with assembly lube.
222Doc is offline
post #9 of 36 Old 09-20-2014, 01:02 PM
222Doc
222Doc's Avatar
Those caster number are VERY low. Should be more like 4-5.5.
222Doc is offline
post #10 of 36 Old 09-20-2014, 01:08 PM
Jodyblip
99 dollars AEV control arm drop bracket should fix that caster right doc?
Jodyblip is offline
post #11 of 36 Old 09-20-2014, 01:16 PM Thread Starter
yoda13
Force Wheeler
yoda13's Avatar
I agree. However, it's been fine for 3.5 years. Why is it all of a sudden driving so badly? Plus, a driveshaft and two different alignment shops, plus the local 4wd shop all told me not to set the caster higher because then my pinion angle would be too high...that is why they are set where they are. Again, no problem for over three years.
forum...
yoda13 is offline
post #12 of 36 Old 09-20-2014, 01:18 PM Thread Starter
yoda13
Force Wheeler
yoda13's Avatar
Over pressured tires? What are the caster numbers? I know when i put in the new Synergy ball joints. They were TIGHT I mean very tight. it took a few hundred miles for them to break in. On first few miles the jeep would not want to return to straight. but i did the tie rod and drag link as well so all those parts were very tight. be VERY sure you greased the new joint's, they are not pre lubed and only come with assembly lube.
Jeep returns to straight when I make turns, no problem.... With decent force. The ball joints are greased. They have about 500 miles on them since the install.
forum...
yoda13 is offline
post #13 of 36 Old 09-20-2014, 01:19 PM Thread Starter
yoda13
Force Wheeler
yoda13's Avatar
Tire pressure is at 30 psi.
forum...
yoda13 is offline
post #14 of 36 Old 09-20-2014, 01:22 PM Thread Starter
yoda13
Force Wheeler
yoda13's Avatar
I looked these up... I'm unclear if they work with aftermarket control arms?
forum...
yoda13 is offline
post #15 of 36 Old 09-20-2014, 01:24 PM Thread Starter
yoda13
Force Wheeler
yoda13's Avatar
They are adjustable. Axles are way off center without them. They are tight.
forum...
yoda13 is offline
