#1 |
Operation Jk Mirrors: Bye Bye
I hope this helps anyone that hates the jk mirrors!!!
Okay so if any of you are like me, from day one I have hated the jk mirrors on the doors. They look like they just dont belong on a jeep and as you know there arent many options out there but the relocation kit(but you still have to keep them god ugly 747 size mirrors),or motorcycle mirrors etc.. , . I came up with a plan.... operation get this **** off my jeep!, lol.. I failed the first time (that will come in a while). I found what fits perfect after my error so here it is!!! What is needed to make it right!--- 1, 2 70s style left hand (driver side) mirror arm and mount brackets, they are 9.99 on ebay..(here was my mistakeDo not get the ones that fit the tj's they dont work, thank God I have a tj too so they went on that rig!!LOL)(Do not get the passenger cj bracket, it has a crazy bend on it and wont line up right to see! ) DRIVER SIDES ONLY!!! 2, 2 5 inch round mirrors from agri supply, trator supply, or any farming dealer. If you prefer the also have square ones too!! 3, a drill bit or step bit and a little silicone 4, Warrior products mirror plug kit to cover the factory holes that kit is like $23 bucks ![]() Figure out the holes you need to open up some just one size larger to accomodate the windshield bolts and drill them ![]() use a little silicone on what you drilled as rust preventer and mount them on the winshield where you want them, the passy side fits the same just mirrored ![]() once you have done this its time to put the mirror on the bracket, they come with a L bracket on them just discard that and use the mounting bolt ![]() Now with the doors full open with strap stops on of course, you can see the mirrors dont hit ![]() you can use the passenger mirror too just the corner is not seen by the door, they can swing in a whole lot further to see full mirror but the door will hit at full open! ![]() I have to say these are much better than the jk stockers! and the cj brackets line up perfect with no modify!!
#2 |
Gold Member
![]() ![]() I dig it. |
#3 |
Make mine a Jeep!
Nice mod.
Those mounts look like the ones from a CJ. If so, you should probably get a couple of spare plastic clamps. I’ve broken a few with my CJ over the years. I’m probably one of the few that happen to like the stock JK mirrors. They have been hit hard several times now and other than being scratched up, they’re still tight as new. ![]()
#4 |
Great mod and great looking rig!!!
OP...what did you spray your grill with? Looks very nice!
Joel |
#5 |
durabake on the grill krutj
#6 |
DW victim # 7,471,643
The Jeep in the decal has a broken C on it's front axle. |---\
![]() Almost as noticeable as a wall-eyed Hummer with a broken tie rod. |
#7 |
Thanks...getting ready to do mine, just deciding on what to spray it with.
Joel |
#8 |
[/QUOTE]What type of fender flares are those? I like them a lot. love the mirror mod also... very cool |
#9 |
I, for one, don't mind the jk stock mirrors at all. In fact, when I take my doors off I think it looks weird without the mirrors.
Nice mod though.
'08 X, Jeep Green, 6 speed, 32" BFG MT's, power options, rubi rock rails, front grab handles, soft top all year round ...oh yea and dirt. |
#10 |
nice jeep!!!!!!!!!!!!
#11 |
#12 |
not to changethe subject,but can you give me some specs on your mods like size tires,rim size and offset,spacers?and lift type and height.gears? looks great.
#13 |
Like it! Very Jeep retro!
#14 |
rims are 17x9 procomps with 4.7 backspace which is perfect with no rub, tires are 35 1250 17s 4 inch rough country, extended brake lines and extended breather lines, auto with the stock 410s, rockslide engineering outer bombshell sleeve welded on front axle, terraflex gussets welded in front, and a rock krawler truss welded on front, warrior tube fenders, smittybilt sliders, smittybilt bumpers rear xrc tire carrier, xrc10 winch, tranny cooler, durabak bedliner inside and out on grill and hood, oil temp and tranny temp glow shift guages, cherrybomb brand flowmaster style exhaust, benchmark evap skid, neoprene covers, man thats all I can think of right now
#15 |
I don't know about those mirrors, to me they look weird and not something I would have done.
| Tags |
| JK Wrangler, mirror brackets, mirror relocation, retrofit, wrangler |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
