Only one rear wheel spins when jacked up in Neutral? - JeepForum.com
 1Likes
  • 1 Post By jwmbishop
post #1 of 8 Old 06-28-2017, 11:22 AM Thread Starter
SteelBlueTJ
I jacked my rear up today to change brakes on my 2012 JK Sport and noticed only my drivers side rear wheel spins freely when the vehicle is in Neutral both tranny and t case and e-brake is off. Is this normal? The passenger side rear wheel seems locked up. Or does my Jk have something I never knew about? It's mostly stock as far as I know. Thanks
SteelBlueTJ is offline
post #2 of 8 Old 06-28-2017, 11:44 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Not normal - you need to determine if its the service brake (disc/caliper) stuck or park brake on the right that is over adjusted. The service brakes easy - have a helper pump the pedal and you should see the caliper tense and relax. Pull the calipers and see if its still tight on the right - if so its the park brake and that's either a sticky cable (follow the cables and see if there is slack at the front end) or you will have to de-adjust it with a brake spoon to get the drum/rotor off.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is online now
post #3 of 8 Old 07-06-2017, 08:54 PM
40gearhead
2016 JK Wrangler
I also concur.. My guess is Prob be the parking brake shoe cable .
40gearhead is offline
post #4 of 8 Old 07-10-2017, 07:53 AM
jeepjeepster
Unfortunately I once dated a person that had an 08 JK. Seemed like it was a monthly ordeal replacing seized up calipers on that thing. It was at the point where all calipers had been replaced twice so three calipers per corner counting the originals. Just kept the receipts so after the first go around they were free.
1994 ZJ-I6 w/216,000 mi
1998 ZJ 5.9 w/65,155 mi Slate Black
2004 KJ w/90,300 mi
jeepjeepster is offline
post #5 of 8 Old 08-22-2017, 07:06 AM
suffolklou
With both rear tires off of the ground, can you turn both sides by hand?
Sent from my iPhone using Tapatalk Pro
suffolklou is offline
post #6 of 8 Old 08-22-2017, 08:42 AM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Yea I feel for ya, I wouldn't date anyone with anything older than a 2010....
propped1 likes this.
post #7 of 8 Old 08-22-2017, 09:11 AM
propped1
Originally Posted by SteelBlueTJ View Post
...It's mostly stock as far as I know.
Im not saying this is THE problem... but this is a problem
._______
/_l__[___],
l--|--|--L
-OlllllllO]
(o)_) (o)_)o-)_)
propped1 is offline
post #8 of 8 Old 08-25-2017, 04:01 PM
Rudinater
2009 JK Wrangler
I have a 09 have not had any problems with my brakes. 87K miles on it so far. Rears pads replaced around 55K and fronts at 87K.
Thanks
Rudy Ackerman
In Oregon for now
Red 09 Unlimited Rubicon - Teraflex 4inch long arm lift, Elka shocks, 5:38 gears, 37inch GY MTR's, Expedition Core front bumper with Warn PowerPlant HD, RS-E rear bumper and carrier, RS-E step rock sliders.
Rudinater is offline
