OME 4 inch lift - JeepForum.com
post #1 of 20 Old 02-27-2013, 12:14 PM Thread Starter
smith0200
2009 JK Wrangler
OME 4 inch lift
just wondering if anyone had input on Old man Emu's 4 inch kit. I heard something about the springs wearing out and dropping to stock height after 6 months. also pictures would be nice. thanks everyone
smith0200 is offline
post #2 of 20 Old 02-27-2013, 12:31 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Not sure about the 4 in, but I installed the 2 in four years ago and the springs are just fine. The only thing I noted is that I used the HD springs and ended up with about 3.2 in lift...you might get more also. Check with Dave at Northridge for
good details, but I doubt the springs will sag, and in fact, this is the first I have heard of this...now RC, then yes.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 20 Old 02-27-2013, 05:44 PM
thedirtman
thedirtman's Avatar
I have never heard of OME coils sagging over time, teraflex and rough country yes but never seen a post of problems with OME. Most people get more lift then expected with the kit. If you are looking at the 4" be prepared for 5"+ if you have a light rig. The HD 2" coils gave me 3.25"
If you learned something new today, you had a good day.
thedirtman is offline
post #4 of 20 Old 02-27-2013, 06:00 PM Thread Starter
smith0200
2009 JK Wrangler
thanks alot, this sounds great. however do you have an aftermarket bumper? i plan on getting both front and rear
post #5 of 20 Old 02-27-2013, 06:12 PM
thedirtman
thedirtman's Avatar
I had a heavy steel bumper and warn 8000 lb winch.
Looks a bit different today, running coil overs and a long arm stretch.
post #6 of 20 Old 02-27-2013, 06:20 PM
wilywillie
If you go much over 2.5", you're going to need to refit a lot more than just your coils. It stresses your steering, driveshafts, control arms, axles, gears.....you're talking about major mods, not just a quick coil swap
I'm just here for the gasoline. --Max
wilywillie is offline
post #7 of 20 Old 02-28-2013, 07:57 AM Thread Starter
smith0200
2009 JK Wrangler
dirtman are those mt/r kevlars? if so do you like them? those are the tires i want to get but i have had people try talking me out of it...
post #8 of 20 Old 02-28-2013, 07:59 AM
thedirtman
thedirtman's Avatar
They are a great tire if you off road a lot, I go a couple times a month. I have run them in 37" and 40".
post #9 of 20 Old 02-28-2013, 08:07 AM Thread Starter
smith0200
2009 JK Wrangler
well the jeep is my daily driver. im in the coast guard now not too much time for it;however, while on leave i go all the time aaannd im getting out very soon and this is when i plan on building it. So you have the tires i want, and the lift. Any complaints on either? and the kit gives you everything needed correct? i appreciate your time, thanks alot
post #10 of 20 Old 02-28-2013, 08:22 AM
thedirtman
thedirtman's Avatar
I assume you are talking the OME lift, my current lift is all custom. OME makes coils and shocks which ride great. You will need other components though to complete the lift. front and rear extended sway bar links, longer brake lines or relocate the mounting brackets, front adjustable track bar and a rear raised track bar bracket on the axle or a rear adjustable track bar, adjustable front lower control arms and rear upper adjustable control arms at a minimum. Full set of 8 ams would be best to recenter the axles.
Northridge 4x4 has a OME lift set up with other components that you may need with several options and if you give them a call they can talk you thru it.
post #11 of 20 Old 02-28-2013, 08:49 AM Thread Starter
smith0200
2009 JK Wrangler
post #12 of 20 Old 02-28-2013, 08:59 AM
n3tfury
That's hot.
n3tfury is offline
post #13 of 20 Old 02-28-2013, 09:00 AM
thedirtman
thedirtman's Avatar
Thats one of the new kits, if you are looking at it I would get adjustable front lower control arms instead of the cam bolts they use. The kit also does not address the steering problems you are going to have at a 4" height. Really a drag link flip should be added if using that kit. Keeping the lift a 2.5" you will not have to do a drag link flip and will have more suspension travel then the 4" lift with a drag link flip.
post #14 of 20 Old 02-28-2013, 09:05 AM
thedirtman
thedirtman's Avatar
Originally Posted by n3tfury View Post
That's hot.
Thanks, it is currently going thru a new build. Double triangulated long arm rear with relocated fuel tank and 16" travel coil overs.
post #15 of 20 Old 02-28-2013, 09:34 AM
n3tfury
Very very cool. One day!
I also like that color blue against the silver. Might need to steal that. Was that on purpose? Did the kit come that color?
n3tfury is offline
jeep jk , lift , old man emu , saggy springs
