Old Man Emu 4" Suspension Lift - JeepForum.com
post #1 of 22 Old 05-19-2012, 11:05 PM Thread Starter
Fluevog
I just bought myself a new 2012 jk and the new Old Man Emu complete lift kit. I am about to install it but I a friend just told me that it uses cam bolts (I think that what he called them). What are these? What are they used for? Will they work? If not, what is my best solution?
Fluevog is offline
post #2 of 22 Old 05-20-2012, 11:16 AM
Jodyblip
cam bolts are used to adjust the camber of the front axle alternative would be aev's control arm drop brackets
Jodyblip is offline
post #3 of 22 Old 05-20-2012, 11:34 AM
ncb
Cam bolts adjust the caster.
ncb is offline
post #4 of 22 Old 05-20-2012, 11:46 AM
Jodyblip
whoops! yah caster not camber
Jodyblip is offline
post #5 of 22 Old 05-20-2012, 12:10 PM Thread Starter
Fluevog
Well is it ok to use the cam bolts. I heard they come loose very easily
Fluevog is offline
post #6 of 22 Old 05-20-2012, 12:28 PM
Jodyblip
cam bolts are fine i think the brackets are better but cam bolts are fine some people swear wheel spacers are dangerous and come loose although i have never heard anyone say it has happened to them
Jodyblip is offline
post #7 of 22 Old 05-20-2012, 12:30 PM Thread Starter
Fluevog
Alright thanks what type of brackets are the best
Fluevog is offline
post #8 of 22 Old 05-20-2012, 12:34 PM
Jodyblip
i dont know of these are the best but this is what i use on my jeep
http://www.aev-conversions.com/shop/...ckets-frt.html
Jodyblip is offline
post #9 of 22 Old 05-20-2012, 12:35 PM Thread Starter
Fluevog
How big of a lift do you have?
Fluevog is offline
post #10 of 22 Old 05-20-2012, 12:38 PM
Jodyblip
i have AEV 3.5 lift on a 2 door automatic rubicon
Jodyblip is offline
post #11 of 22 Old 05-20-2012, 01:30 PM Thread Starter
Fluevog
Alright sounds good man thanks
Fluevog is offline
post #12 of 22 Old 05-20-2012, 01:56 PM Thread Starter
Fluevog
Well other than the cam bolts, does the lift kit that I am interested in look nice?
Fluevog is offline
post #13 of 22 Old 05-20-2012, 02:06 PM
Jodyblip
i think so but for about the same price you can get the aev 3.5 kit not saying its better but i do think its more complete
Jodyblip is offline
post #14 of 22 Old 05-20-2012, 02:10 PM
Jodyblip
Jodyblip is offline
post #15 of 22 Old 05-20-2012, 02:24 PM
jmb6420
Engr. & Mechanic 08 Rubi
jmb6420's Avatar
I'm curious about the 'complete lift kit'. My OME lift kit came with adjustable front lower control arms among other things. What kit did you get? and from where?
Mike
08 Rubicon
"You can't fix stupid" Ron White
¡ɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
jmb6420 is offline
Another view of a 3" body lift, on a 5" suspension lift YJ. moonshinefuel Wrangler General Discussion 7 02-28-2011 04:49 PM
Confused. Why 4" suspension lift plus body lift instead of taller suspension lift? ezgoin TJ Wrangler Technical Forum 34 02-12-2011 06:04 PM
2" OME suspension lift w/ shocks & Springs. Not theBB or the2.5" lift CCJ TJ Wrangler Technical Forum 46 08-27-2009 01:44 AM
98 tj wrangler (4" suspension lift + 3" body lift) jeepster069 TJ Wrangler Technical Forum 5 05-03-2009 04:28 PM
1" or 2" Spring Spacer with 4" Suspension Lift on 2000 TJ iBkickinit TJ Wrangler Technical Forum 12 03-20-2006 08:25 AM
