Old Man Emu 2.5" lift - JeepForum.com
post #1 of 22 Old 05-13-2013, 02:43 AM Thread Starter
PrinceBondar
So, I installed this supposedly 2.5" lift this weekend. I got the "heavy" load kit (http://www.quadratec.com/products/16090_02X4_PG.htm), considering I have an AEV front bumper with Warn 9500ti winch and AEV skid plate, Mopar off-road rear bumper and AEV corner guards. All of that adds up to the 300 pounds of additional capacity this lift kit is supposed to provide. I ended up with 3" of lift in the front, and 4" of lift in the back. That's way too much, and way more than I want. Before I "undo" all of this and put it back to stock, and besides the standard "it will settle some" commentary, is there anything I should try to get this lift down to the 2.5" it is supposed to be?
PrinceBondar is offline
post #2 of 22 Old 05-13-2013, 06:28 AM
S1L3NT_WH33L3R
2005 WK
Pictures?
'05 WK Limited, QD-II, 5.7L HEMI, Volant Cold Air Intake, Aries Taillight Guards, Rola Roof Rack, Cobra CB, Firestik Antennas, Magnaflow Performance Exhaust, OME HD lift, 285/70-17 GY Duratracs, Spidertrax Spacers, Superchips Programmer, Steel Armadillo Super Sliders
~Jeep makes it HEMI shakes it~Ain't Nothing Humble about that HEMI Rumble~
S1L3NT_WH33L3R is offline
post #3 of 22 Old 05-13-2013, 07:43 AM
jopolly3
Originally Posted by S1L3NT_WH33L3R View Post
Pictures?
Agreed, I would like to see this too. I have the same lift sitting in the garage and I want to see what I am dealing with here. I seem to be seeing a lot of "this lift is way taller than advertised" going on...
Joe
2013 JKU Rubicon 6spd: ARB Dana 44 covers F&R, Expedition One front bumper & swaybar skid, Hella driving lamps, JKS adjustable track bars F&R, MBRP SS off-road exhaust, OME HD springs and shocks, OME relocated SS, Rock Hard 4x4 gas tank skid, Rock Hard 4x4 oil pan skid, Rock Hard 4x4 rock sliders, Rock Hard 4x4 transfer case skid, Spidertrax wheel spacers, Superwinch LP8500 Gen 1
2002 Subaru WRX: Cobb intake, Mishimoto aluminum radiator, Kartboy short throw shifter and bushings
1960 CJ-6: Never ending project rig
Build Threads:
JKUR -
CJ6 -
WJ -
"BFG makes some good rubbers, if they sold condoms I'd buy them" -Owen Horner
jopolly3 is offline
post #4 of 22 Old 05-13-2013, 08:11 AM
tyvanwie
You should never buy an old man emu lift based on the supposed lift height, because it's all general. Each jeep is different and weighs different, you obviously don't need the heavy springs. At least not in the rear.
Sent from my iForum using JeepPhone
tyvanwie is offline
post #5 of 22 Old 05-13-2013, 08:23 AM
222Doc
222Doc's Avatar
about all spring lifts will be taller than spec. You could add more weight. steel front fenders, full plated sides. on board air and tanks sport cage. 300pounds of gear ect. My 3.5 was at least 4 font 4.5 rear.
222Doc is offline
post #6 of 22 Old 05-13-2013, 08:39 AM
jopolly3
What is the numeric spring rate difference between the stockers and OME HD's?
Joe
Build Threads:
JKUR -
CJ6 -
WJ -
jopolly3 is offline
post #7 of 22 Old 05-13-2013, 08:59 AM
COLOUXJ
2010 JK Wrangler
If you got the HD springs then yes you will get around that amount of lift. Everyone who has installed the HD springs has had this happen. I would take out the HD springs and go with the SD, that should lower it a little bit.
COLOUXJ is offline
post #8 of 22 Old 05-13-2013, 09:01 AM
COLOUXJ
2010 JK Wrangler
Not sure if you have the JK or JKU. Here is a JKU on 35's with the HD 2.5" OME springs.
COLOUXJ is offline
post #9 of 22 Old 05-13-2013, 09:02 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
From an old post by Border Dave:
OME spring rates:
Front light duty: 150 lbs./inch
Front heavy duty: 150 lbs./inch (The only difference is these are a little longer)
Rear light duty: 140 lbs./inch
Rear heavy duty: 160 lbs./inch
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #10 of 22 Old 05-13-2013, 09:19 AM
JoonHoss
2011 JK Wrangler
Not just OME, but a point about all spring lifts
Stock Jeep coils are numerically rated, anywhere 13 to 19 upfront, and 54 to 60 out back. The higher the #, the stiffer (higher capacity/spring rate-not length) of the spring.
I've heard comments of anywhere from 1/3" to 1/2" difference in realized height per each numerical increase factory spring height.
Even using the 1/3" increment, that means that here could be almost 2" difference in the stock height of any given jeep from the factory, depending on springs and the weight of vehicle options.
The only reference point any of the manufacturers can make is a generalized one. My guess would be that they shoot for the average, or middle of the pack, but that still doesn't account for differently optioned vehicles.
I think this is one of the biggest factors we see so many 'what lift/what size tire?' threads- because there are so many variables from the start.
I see alot of conversations about lifts, and a lot about stock spring heights, but hardly ever a thread with both points together.
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #11 of 22 Old 05-13-2013, 10:44 AM Thread Starter
PrinceBondar
I didn't. I bought it on the supposed "300 pounds of additional weight capacity" - and it was rated at 2.5" of lift. Frankly, 0" of lift would have been fine with me - I wanted the weight capacity.
post #12 of 22 Old 05-13-2013, 12:02 PM
RockyClymer
RedRock4Wheeler
The HD OME rear springs at 16 lb/in, would give you 320 lb of load with a theoretical drop of 1 inch...I say theoretical because a small portion of the load, even in the rear, would ride on the front. The closer over the rear axle, the more on the rear axle. The rear seat is fwd of the axle, so friends weight would be distributed.
NRA Life member
post #13 of 22 Old 05-13-2013, 12:20 PM
jonballi
I am looking to purchase this exact same lift for my JKUR. Did you run into any issues with the OME HD lift?
jonballi is offline
post #14 of 22 Old 05-13-2013, 12:27 PM
RockyClymer
RedRock4Wheeler
I had no issues at all, still run it and like it a lot. Great ride on and off road. I installed JKS adj track bars and Teraflex adj control arms rear and Rock Krawler front.
NRA Life member
post #15 of 22 Old 05-13-2013, 12:58 PM
Noxian
2011 JK Wrangler
i am running the HD lift on mine, but with my bumpers, extra armor etc it settled down to exactly 2.5" of lift
Noxian is offline
