Ok others with a Spiderweb Shade, I got some questions? - JeepForum.com
post #1 of 31 Old 07-10-2013, 05:58 PM Thread Starter
ironbike
2011 JK Wrangler
Just got it today, installed it per the Spiderwebshades.com video. The rear was extremely difficult but I got the cord eventually to stretch enough.
1st might sound stupid but this is meant to be extremely tight from being new?
2nd the center holes where the freedom top screws go through, are they supposed to just fall directly over the holes in the roll bar/sound bar or did it take you some pulling and tugging to get it all lined up for the screws to make it through the holes?
Generally this thing that looked like it should take me 15 minutes to put on took me an hour to pull and stretch over the JKU and get all the spider ball cords hooked up, plus the center holes proved to be tough? Is this all normal for a new shade? (yes I did call Spiderwebshades but they were closed for the night)
Thanks
ironbike is offline
post #2 of 31 Old 07-10-2013, 06:04 PM
SoCal_HEMIHead
It was tight the first time, but loosened up each time I did it again.
... now let the jokes begin.
SoCal_HEMIHead is offline
post #3 of 31 Old 07-10-2013, 06:08 PM Thread Starter
ironbike
2011 JK Wrangler
That's what she said
Good to hear but I plan on leaving it on and not taking it off anytime soon if ever
ironbike is offline
post #4 of 31 Old 07-10-2013, 06:14 PM
SoCal_HEMIHead
Yes, I'm sure it will stretch. I haven't used my holes so I can't speak about how easy they line up, but now that I have it figured out I'm able to install it in about 5-10 minutes.
post #5 of 31 Old 07-10-2013, 06:22 PM Thread Starter
ironbike
2011 JK Wrangler
So how do you put the freedom top screws back in?
I am sure if I took the shade off and put it back on it would be easier but damn this thing took some coaxing and beer to get fitted nicely
ironbike is offline
post #6 of 31 Old 07-10-2013, 07:16 PM
Cooneys08JK
Cooneys08JK's Avatar
Mine was a ***** to get on. Definitely stretched out in a day or two. My "15 minute" project turned into an hour long project as well.
'08 Black 2door JK- DD
'99 Chilli Pepper XJ- Wheeler- BFG ATs, 2 " BB + bolt on stuff
Cooneys08JK is offline
post #7 of 31 Old 07-10-2013, 07:16 PM
MoonyJohn
I actually took the velcro strips that came with it and drilled a hole in the middle of the bottom one, and superglued it right above the hardtop holes. Havent put the hardtop on yet but it should line up no problem. I only did it because I was hoping it would stop the flapping sound hitting against the soundbar area, but no luck. I dont know the legit way of doing it but thats how I did it. Hope this helps!
MoonyJohn is offline
post #8 of 31 Old 07-10-2013, 08:32 PM Thread Starter
ironbike
2011 JK Wrangler
What are the Velcro strips for?
ironbike is offline
post #9 of 31 Old 07-10-2013, 08:39 PM
MoonyJohn
Im assuming to hold the web down above the holes, so thats what I did
post #10 of 31 Old 07-10-2013, 08:43 PM Thread Starter
ironbike
2011 JK Wrangler
I can see that if they had some sort of adhesive on them? Just odd
ironbike is offline
post #11 of 31 Old 07-10-2013, 09:51 PM
Ruby_Tuesday
The holes on mine didn't line up at all either, I just remove the SWS when I put the top on.
Ruby_Tuesday is offline
post #12 of 31 Old 07-10-2013, 09:56 PM
LukeTXAG
I have a buddies Spiderweb shade on my JKU right now and will be ordering my own very soon. It was a pain to get on the rear and I took a bungie cord to the face in the process! I didn't worry about lining the holes up because even when I have the hardtop on, I NEVER put those bolts in. I think the only reason to use them is if you are using the freedom tops without the remainder of the hardtop.
LukeTXAG is offline
post #13 of 31 Old 07-10-2013, 10:02 PM
Filthy-Beast
I don't have one, But would suggest, next time you put it on, drop the bolts through the grommets and then the holes in the sound bar. This will keep them lined up while you attach all the bungees.
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #14 of 31 Old 07-11-2013, 05:43 AM Thread Starter
ironbike
2011 JK Wrangler
Damn, My GF said the same exact thing and it would have been so much easier.
So is it normal to just leave the bolts out? I know most of the holding strength comes from the latches but just seems odd to leave the bolts out?
ironbike is offline
post #15 of 31 Old 07-11-2013, 11:23 AM Thread Starter
ironbike
2011 JK Wrangler
Ok so I got a call from Chris from spiderweb shade. Excellent guy to deal with. He explained that the velcro patches are supposed to just stick on the shade where the grommets are in the center so that the metal doesn't slap against metal. They are not supposed to hold the holes in place over the sound bar/roll bar just to protect the metal from hitting metal as a cushion. Everything is installed now and perfect......
ironbike is offline
