Oil smells like gas in my 07 JK - JeepForum.com
post #1 of 4 Old 04-24-2013, 08:43 AM Thread Starter
dstu30
My 07 JK is running really rough at low rpm, and the oil has a strong smell of gas, I've changed the oil and spark plugs #2 was really dirty and oily. Any suggestions on the issue? I'm hoping its not a piston ring
dstu30 is offline
post #2 of 4 Old 04-24-2013, 08:50 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
If your injectors are malfunctioning they could be wetting the cyls. Excess fuel can solvent wash the cylinders and take out the rings! Have it checked by someone who is good with fuel side work - and do a compression check.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #3 of 4 Old 04-24-2013, 09:09 AM
222Doc
222Doc's Avatar
rings are known issue on the 07-08. has it been burning oil?
222Doc is offline
post #4 of 4 Old 04-24-2013, 09:14 AM Thread Starter
dstu30
Not burning any oil since last oil change
dstu30 is offline
jk
