Oil puddle inside air intake tubes - JeepForum.com
post #1 of 12 Old 06-03-2013, 09:33 PM Thread Starter
Jeep Kid
Is oil inside the air intake tubes normal? RIPP Stage 2 supercharger installed on 2008 JKU automatic
Jeep Kid is offline
post #2 of 12 Old 06-03-2013, 11:08 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
No. What exact tubes are you talking about? Sounds like a seal in the RIPP Vortech unit is leaking/blown. This happens if the Vortech vent is not installed...?
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 12 Old 06-04-2013, 12:31 AM Thread Starter
Jeep Kid
These are pipes between the intercooler output side and the throttle body. I'll check the oil level tomorrow when there's light out.
Jeep Kid is offline
post #4 of 12 Old 06-04-2013, 12:33 AM Thread Starter
Jeep Kid
I'll also check the tubes coming directly off the supercharger
Jeep Kid is offline
post #5 of 12 Old 06-04-2013, 12:35 AM
MTBlue
It sounds like (off-hand guess here) a plenum gasket leak. Happens in Magnum engines on a regular basis. It will require a full intake tear-down/rebuild and simply a new gasket. That is, if it is actually a plenum gasket leak... But don't quote me on that. Superchargers are uncharted territory for me.
-Evan
Dirt Deprived
MTBlue is offline
post #6 of 12 Old 06-04-2013, 11:12 AM
RockyClymer
RedRock4Wheeler
Dumb ? But I gave to ask. Is the PCV valve that Ripp supplies installed correctly? If backwards then it would pressurize the crankcase and shoot oil mist back in air filter and intake. Check intake to SC and see if oil is at inlet or as above from air plenum.
NRA Life member
post #7 of 12 Old 06-05-2013, 02:25 PM Thread Starter
Jeep Kid
Thanks for the info everyone.
And I do have good news for whom ever comes across this similar issue. I contacted RIPP, and they came back within 10 minutes (email) saying this is indeed normal.
Is this normal?
"Yes, if you have the PCV system hooked up normally this will happen. All engines from the factory recycle its crank case gasses, and this "sludge" oil is what you get. You can look into a catch can if you'd like, but we don't make them." -Chris from RIPP
Jeep Kid is offline
post #8 of 12 Old 06-05-2013, 02:34 PM
mello
Turbo systems do the same thing.
mello is offline
post #9 of 12 Old 06-05-2013, 03:48 PM
brianjw
Yes, pretty common thing to find in turbo cars.
brianjw is offline
post #10 of 12 Old 06-05-2013, 09:13 PM
RockyClymer
RedRock4Wheeler
Tnx for the info, I will check mine out tomorrow and see if I have oil accumulation in the air tube....
NRA Life member
post #11 of 12 Old 06-05-2013, 10:19 PM
HappyTrails
HappyTrails's Avatar
Maybe this explains the mysterious 1 quart of oil per 1000 miles that Jeep claims is normal? J/K!!
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #12 of 12 Old 06-06-2013, 10:27 AM
RockyClymer
RedRock4Wheeler
Checked my air intakes, no notice of oil buildup that I can see yet. Also, my engine does not see high oil consumption either, maybe 1 qt every 100 hrs at most.
NRA Life member
