Oil Pan Drain Bolt head size? - JeepForum.com
post #1 of 12 Old 07-27-2010, 01:02 PM Thread Starter
JeffinWesternWA
2010 JK Wrangler
2010 JK...did a search, no luck. With a flashlite I can see metric strength markings of 4.8. on the bolt head. Looks abot 1/2" in size so I'm guessing it's either: 12, 13 or 14mm?? What is correct oil pan drain bolt head size?? thanx.....
Transmission/Xfer case drain and fill plugs. These appear to be a special 5 point type of plug (?). Can one verify 1) the location of drain and fill plugs for each the 6 speed and xfer case AND what are the sizes/types fo plugs and the ensuing "tool" that is needed to open them? thanx...
JeffinWesternWA
JeffinWesternWA is offline
post #2 of 12 Old 07-27-2010, 01:06 PM
McKBrew
JK Wrangler
According to the write-ups on a couple of other sites it's a 13mm bolt.
McKBrew is offline
post #3 of 12 Old 07-27-2010, 01:10 PM Thread Starter
JeffinWesternWA
2010 JK Wrangler
thanx, several searches here was no luck, go figure,it must be "common knowledge 'cept to me", .....
JeffinWesternWA
post #4 of 12 Old 07-27-2010, 01:28 PM
1398653
2017 JK Wrangler
yep, 13mm. I changed my oil 2 months ago and had to go buy one this size since it isnt all that common and didnt come with the 2 socket sets I have.
Steve, Allegany NY, 2017 JK Unlimited Rubicon
1398653 is offline
post #5 of 12 Old 07-27-2010, 01:31 PM
Dronac
AFAIK, most car's oil plug is 13mm.
2008 Jeep JK X: auto trans, 3.73 gears, D44 rear, D30 front
Mods: 2'' Rusty's coil lift, Superchips 93 octane tune, Cobra 75 CB radio, 33'' Duratrac's, onboard air compressor
My Build Thread! ---> http://www.jeepforum.com/forum/f96/dronacs-build-thread-1104134/
Dronac is offline
post #6 of 12 Old 07-27-2010, 01:39 PM Thread Starter
JeffinWesternWA
2010 JK Wrangler
most of mine (GM and Mazda) last two have been 15 OR a large 17MM!!
JeffinWesternWA
post #7 of 12 Old 07-27-2010, 01:41 PM
GPV
What!? Where on earth do you buy your tools?
Sean
2008 Jeep JK Rubicon Unlimited (Bought for Wife)
2007 GMC 2500HD Duramax (Work Horse)
1982 Honda CB 900F Supersport
2001 Honda RC51
GPV is offline
post #8 of 12 Old 07-27-2010, 02:57 PM
1398653
2017 JK Wrangler
I actaully have 3 sets, two from tractor supply 3/8 and 1/2 inch drives and one from autozone 3/8 drive (dont remember the brand) Not one of my sets included a 13 mm. I had to go and buy one at tractor supply individually.
1398653 is offline
post #9 of 12 Old 07-27-2010, 03:34 PM Thread Starter
JeffinWesternWA
2010 JK Wrangler
yea, I had set w/o a 15mm, think it was a craftsman.....
JeffinWesternWA
post #10 of 12 Old 07-27-2010, 04:56 PM
fernjack
My 07' is 13mm , I bought a Snap-on 6 point comb wrench just for doing the changes ..... no chance of stripping the plug head .
On metric tools .... some sets are more European 12mm,15mm,18mm .... some are more Asian 13mm,16mm no 18mm . And some just don't make sense ..... I bought shallow and deap sockets in 15mm & 18mm in 3/8" & 1/2" drive in hand tool and impact along with combination wrenches to keep in my Jeep tools . I also bought "Flex-head combo gear wrenches ..... kinda over board but being a life long tradesman I never pass up a chance to toolup if there is need ... and usually over kill it ...LOL !
07' Rubi Unlimited 6spd. , Rescue green #64 CDN , 35x12.5 mudders
Rick .
fernjack is offline
post #11 of 12 Old 12-13-2010, 02:47 PM Thread Starter
JeffinWesternWA
2010 JK Wrangler
Are the factory lug nuts on the 17" metric? look about 18 or 19mm??
JeffinWesternWA
post #12 of 12 Old 12-13-2010, 11:20 PM
No_Return
JK Lug Nuts are 19MM...
I think they exclude popular sizes Like 13MM as a cheep attempt to get you to buy the missing socket for an extra few bucks = Lame.
One does not establish a dictatorship in order to safeguard a revolution; one makes a revolution in order to establish a dictatorship. - Orwell
No_Return is offline
JK Wrangler , oil drain plug , oil pan drain , wrangler
Hex head size on NP231 Fill/Drain plugs? RedTeej TJ Wrangler Technical Forum 14 01-17-2010 06:57 PM
TC drain bolt size? tufmar YJ Wrangler Technical Forum 2 12-28-2006 06:39 PM
Transmission drain bolt size? BChamberlin TJ Wrangler Technical Forum 4 05-14-2006 03:38 PM
AX-15 drain/fill plug head size? bryris YJ Wrangler Technical Forum 2 03-01-2006 12:40 AM
t-case drain plug head size? yesterdaylight YJ Wrangler Technical Forum 4 12-25-2005 09:53 PM
